Nexus Collaboration: YWNexus Blackhawk
Discussion in 'Performance and Tuning' started by Mooseditty17, Jan 21, 2022.
  1. Jun 5, 2022 at 7:39 PM
    #701
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Not yet. Been B2TW prepping for this release.
  2. Jun 5, 2022 at 7:48 PM
    #702
    ChilliTaco
    ChilliTaco Well-Known Member
    Richard
    Alberta, Canada
    2017 AC TRD OR AT MGM
    It was starting to write, according to the dialogue box, warned me not to touch anything, then errored.
  3. Jun 5, 2022 at 8:14 PM
    #703
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Ok, a force flash will likely get you back up and running. Do everything you would typically do to flash, but instead of selecting calibrate ECM, select the gen 2 force flash. If you have closed vF tuner, it may be necessary to select Calibrate ECM, and once it fails select the force flash. Use your stock file to get you back up and running before trying to flash an aftermarket tune.
  4. Jun 5, 2022 at 9:13 PM
    #704
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    :frusty: the closest to a brick emoji
    ChilliTaco and ktbell444 like this.
  5. Jun 6, 2022 at 4:43 AM
    #705
    ChilliTaco
    Richard
    Alberta, Canada
    Truck was still normal… didn’t affect anything…
  6. Jun 6, 2022 at 5:23 AM
    #706
    Chadr7858
    Chad
    Colorado
    That's good that it didn't brick
    ChilliTaco[QUOTED] likes this.
  7. Jun 6, 2022 at 6:05 AM
    #707
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    So won't flash but not bricked? Maybe this is what @mZiggy refers to as a soft brick.
    ChilliTaco[QUOTED] and mZiggy like this.
  8. Jun 6, 2022 at 6:07 AM
    #708
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    If it is indeed appearing to be soft bricked, I'd restart the laptop, open up the software, attempt flash. If unsuccessful, disconnect the battery for 30 mins, or disconnect and hold the cable terminal ends together for 5 mins or so. Reconnect and attempt reflash.
    ChilliTaco likes this.
  9. Jun 6, 2022 at 6:32 AM
    #709
    ChilliTaco
    Richard
    Alberta, Canada
    I am at work now, so no reliable interwebz for the laptop. Will try it again tonight when I get home.
  10. Jun 8, 2022 at 7:21 PM
    #710
    ChilliTaco
    Richard
    Alberta, Canada
    Finally got my shit figured out… Just installed the tune, and can’t stop grinning! This thing is ridiculous! Lmao
  11. Jun 8, 2022 at 7:23 PM
    #711
    Mooseditty17
    Mooseditty17 [OP] Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Glad to hear your enjoy it.
    :cheers:
  12. Jun 10, 2022 at 9:12 AM
    #712
    robourbon
    robourbon Member
    2017 Magnetic Gray TRD Sport
    Anyone in the Youngstown, Cleveland, or Pittsburgh area that would be able and willing to flash my truck if I purchase this?
  13. Jun 10, 2022 at 9:31 AM
    #713
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    @Netaco4 is in the NE Region
  14. Jun 12, 2022 at 6:41 PM
    #714
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    First post updated!
  15. Jun 12, 2022 at 6:50 PM
    #715
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Hell Yeah!!!
  16. Jun 13, 2022 at 8:46 AM
    #716
    ChilliTaco
    Richard
    Alberta, Canada
    Sooo just a bit of an update/review of my experience so far with Nexus Performance +P.
    Have put ~ 1500 kms on since install, and tried it out towing this past weekend. Towing was highway, high grade gravel, somewhat hilly drive. Couple long pulls through a river valley, with ongoing bridge construction, so no real chance to game the 2 mile pull off the bridge. Also had a different 2 mile pull from the campsite, on gravel, with steeper grade.
    First, just DD stuff, this tune is amazing! So much fun to drive, and passing at speed is a breeze!
    Pulling the trailer, a borrowed 25’ 98 Mallard, weighing ~5600 lbs with all the crap, 2 labs, me, the boss and the yard apes, was crazy. My wife actually looked behind us a few times to make sure the trailer was still there, lol cause the truck didn’t blink! I was excited for the big hills to see how well it would do. It didn’t disappoint. Into the construction we’re slowed to around 50 km/h, and then start climbing, about a mile up before zone ended. Back up to 100 BEFORE the top of the hill, and the truck was doing great. Pulled in 4th at about 4000 rpm to gain that speed, and still had lots left to give. Same result going home on that valley, with a little longer pull. Temp stayed in normal range.
    The hard pull out of the campsite was made exciting due to wheel spin, haha, gravel is awesome. Ended up stopping after a few hundred yards and engaged 4x4. Pulled out of that like a champ. Couldn’t be happier with this tune already, and am stoked to try out Blackhawk!
    Thanks guys! Keep up the amazing work!
    FCL30, Bastek, ktbell444 and 2 others like this.
  17. Jun 13, 2022 at 8:53 AM
    #717
    Mooseditty17
    AJ
    WI
    Happy to hear you're enjoying the tune. I'm working on distributing updates upon request. Ill consider this your notification.
    :cheers:
    ChilliTaco[QUOTED] and ktbell444 like this.
  18. Jun 20, 2022 at 8:32 PM
    #718
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Just wondering if anybody with a heavier truck came across this phenomenon.
    After installing Nexus +P, did a few trips on i78 in NJ. A few hills, 65 mph speed limit, nothing crazy. Trying to maintain ~70 mph, truck would shift up and down between 6-5-4 without significant throttle input. Very similar to how stock tune would behave. (can't really remember if original M+W tune behaved like that, but somehow I just don't think so).
    Besides for that, it's a lovely tune. Performed better than original M+W+tow when towing in S4. Pretty fun to drive, but unlike some other reviewers, I don't see any mpg improvement. Wasn't really looking for it though.
    BTW, I drive an overweight taco on 33s, and still on stock gears.
  19. Jun 20, 2022 at 10:08 PM
    #719
    MountainManGuy
    MountainManGuy Well-Known Member
    Colorado
    2019 Toyota Tacoma TRD Off-Road DCSB
    Anybody from Nexus +P try out blackhawk yet? I've got the updated files but I'm too lazy to flash em at the moment. Been too happy with the Nexus +p to get out and change it.
    SpeySquatch and ChilliTaco like this.
  20. Jun 21, 2022 at 3:26 AM
    #720
    Mooseditty17
    AJ
    WI
    Are you positive it was shifting, and not the TC locking and unlocking? Do you log at all when you drive? If so, would you be so kind to share some data?
    :hattip:
    Bastek[QUOTED] likes this.
