Nexus Collaboration: YWNexus Blackhawk
Discussion in 'Performance and Tuning' started by Mooseditty17, Jan 21, 2022.
  1. Jul 1, 2022 at 4:10 PM
    #741
    Maxx
    Maxx Well-Known Member
    I’m coming from KDMax Pro. Just flashed the Regular WW file. Cleared PCM and TCU. Letting it idle with A/C for a bit then will test drive after work. I drive pretty slow around town and usually get pretty good MPG considering all the weight I have. Hoping for smooth low end to putt around with. Also, hoping to solve the engine lugging under 2k RPM when I’m in higher elevation. We shall see.
    FCL30, Mooseditty17[OP] and ktbell444 like this.
  2. Jul 1, 2022 at 4:22 PM
    #742
    hkdtaco
    hkdtaco Active Member
    WA
    2018 Cement Tacoma TRD Sport 4x4
    Blackhawk Tune, KING 2.5, RRW, 295/70R17, S&B
    @Mooseditty17 adjusted mine down and a bit and now its perfect. My guess is with the added low end torque from Blackhawk it made the tip in a little aggressive vs Nexus. Reach out to the them and they'll be more than happy to adjust it for you.
  3. Jul 1, 2022 at 7:09 PM
    #743
    MountainManGuy
    MountainManGuy Well-Known Member
    Colorado
    2019 Toyota Tacoma TRD Off-Road DCSB
    Awesome thanks for the tip. I'll likely have him do that for mine as well.
    Mooseditty17[OP] likes this.
  4. Jul 1, 2022 at 7:57 PM
    #744
    Mooseditty17
    Mooseditty17 [OP] Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    There is another alternative I've been toying with, if the settings are too much for people.
  5. Jul 1, 2022 at 10:31 PM
    #745
    CO_Taco125
    CO_Taco125 Well-Known Member
    '17 TRD OR DCSB
    Blackhawk Tune, Falken Wildpeaks, Falcon Suspension, KMC XD, KC flexpods, KC Pro6 bar, Kicker speakers, Sound Ordnance sub, MTX amp, interior vinyl wrap
    80 mile update. Not sure if this has anything to do with the new tune or just a fluke, but figured I'd share here in case anyone else has the issue. I went into town to grab a load of mulch today and on the way home, the brake override malfunction light came on and the truck went onto limp mode. I was just driving normally up a slight incline when it happened. The mulch was heavy but definitely not the biggest load I've had in the bed.
    I limped her home at the max speed of 8 MPH, then checked the forums to find the fix. I have seen others with this issue and knew there was an easy solution but couldn't remember at the time (disconnect battery cables, touch positive and negative together for 30 seconds, reconnect and codes will be clear).
    The drive to work tonight went fine. Hopefully it was just a random occurrence, but only time will tell. Besides that, Blackhawk has still been running great.
    ChilliTaco likes this.
  6. Jul 2, 2022 at 5:10 AM
    #746
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    We have received very few reports from the AT RegOL users (~5%) with this issue. This does not affect premium or MT files. Luckily we were able to find someone who could easily replicate the issue. Using them, we were able to thoroughly verify the problem was eliminated. We are working diligently to release updated AT RegOL tunes to all previous customers, and only have a few minor things left to button up.
  7. Jul 2, 2022 at 9:47 PM
    #747
    Maxx
    Pretty great so far. Driving up to Sedona tomorrow. I-17 will be the true test.
  8. Jul 3, 2022 at 6:58 PM
    #748
    ChilliTaco
    ChilliTaco Well-Known Member
    Richard
    Alberta, Canada
    2017 AC TRD OR AT MGM
    Weird. This happened to me today… Twice. Had had a similar issue with the wife’s Highlander a couple years ago, so knew the work around, but didn’t think it might be related to the tune until reading this…
    CO_Taco125[QUOTED] likes this.
  9. Jul 3, 2022 at 7:37 PM
    #749
    Kevinpd325
    Kevinpd325 Well-Known Member
    Kevin
    San Diego
    2017 Tacoma TRD Sport 4x4
    Racks/Storage • Prinsu Cabrack w/ load panels • Leitner Designs ACS • Leitner Designs cargo pods (x2) • Leitner Designs accessory mounts (x4) • Leitner Designs Hi-lift mount • Rotopax mounts (x6) • Harbor freight roof mounted rifle case • FWP Fab bed rail shovel and axe mounts (modified for Leitner ACS) • FWP Fab bed corner mounts (modified for Leitner ACS & air fittings) Wheels/Tires • BFG 285/70 R17 KM3 • Pro Comp 61 series Cognos 17x9 wheels Electrical/Power • Genesis Offroad dual battery system • Odyssey group 34 AGM batteries • Renogy 100w solar panel w/ Voyager charge controller • Renogy 3000w pure sine power inverter • sPod4x4 BantamX • Warn winch isolator solenoid • Powertray x2 (right side modified for solar charger) • DC Power Engineering 270A alternator Engine/Performance • IS350 Custom tune • Revolution gears (5.29 ratio) • Eaton E-lockers (front & rear) • OME carrier bearing drop • Custom rear differential breather • K&N drop-in air filter • Dobinson snorkle • AC drain line mod • Start-X remote start • Redline tuning hood struts Exterior • Meso Customs Gashole • TRD Pro grille w/ LED lights • Pop & lock tailgate lock actuator • Anytime Backup Camera (modified for 2nd rear camera) • AVS in-channel weather guards • Expedition Essentials bedside compressor mount • Custom CMC & pinch weld mod • OEM spare tire well modified to fit 285/70 R17 • Goat armor (arachnid black) • Leitner Designs bed stiffeners • Black raised tailgate letters • Bed stickers removed • Debadged 100% • Herculiner bed liner • Mountain Hatch tailgate insert • Modified right side bed storage compartment for water and power connections • Vinyl wrapped hood & roof • Tacoma Twins Prinsu grab handles & Prinsu accents Interior • Meso Customs lower switch panel • Meso Customs interior chrome delete • Meso Customs extended fuse panel cover • Meso Customs overhead 3 switch panel • Relocated center 12vdc outlet • Dual USB outlet mounted in overhead console • Blue Sea dual USB outlet mounted on rear of lower console • Expedition Essentials 3TPAM w/ Blue Sea rapid charger • Doc Loco Molle rear wall panel • 67 Designs ball mounts • 67 Designs carbon fiber arms • 67 Designs universal device holder • 67 Designs sPod touchscreen mount • Ram Mounts Tab-tite iPad holder • ch4x4 cubby switch mount (water pump, winch power & air compressor switches) • Interior panels painted American flag pattern • Tuff skins glovebox letters • GPCA headrest grab handles • desert.does.it seat jackers Lighting • Caliraised LED dual function 40” light bar • Caliraised LED ditch light brackets & side shooters • Caliraised LED amber chase lights • SpartanX Customs stealth scoop light w/ Nitevision function • SDHQ Dual hidden light bar mount • Extreme LED 30" dual function light bar (x2) • Auxbeam 6x2 amber LED light pods (scene lights) • Opt7 Quantum rock lights • LED interior lighting upgrade • SpartanX Customs tricolor LED headlights & fog lights • yodaTEQ underhood LED lights • Meso Customs V2 Dome light • Meso Customs total tail lights Comms • Uniden Bearcat CB radio (mounted in center console) • Anytone AT878UV UHF/VHF radio • Rago antenna mount Armor • SSO slimline bumper w/ stage 2 • RCI sliders Suspension • Icon Vehicle Dynamics Stage 4 • Icon Vehicle Dynamics tubular UCA w/ delta joint • Icon Vehicle Dynamics RXT leaf springs • Overland Custom Designs swaybar disconnects Recovery • Smittybuilt XRC 9500 w/ synthetic cable (rewired for wireless remote) • Factor55 flatlink • 40” Hi-lift jack w/ Jack Mate • Rototrax • Vault hitch shackle block • Gear America recovery kit Audio • Kicker KS series speakers • Kicker CS dome tweeters. • Kicker 10” powered subwoofer • Subaru Kicker tweeters • Kicker Key 180.4 plug and play amplifier • Mat66 sound deadening (whole interior) Accessories • ARB twin compressor • ARB 35L fridge/freezer • Expedition Essentials propane mount w/ 11 lb tank • Outer Limit Supply first aid kit w/ magnetic mount • Rotopax Gen2 2gal fuel & water cans • Fuelpax 3.5gal cans • Quick release fire extinguisher mounts x2 • Fire extinguisher x2 (5lb & 1lb) • Seaflo series 33 water washdown pump • Custom ABS 5 gallon water tank • Roam Vagabond XL Rooftop Tent • OVS Nomad 270⁰ awning
    Unfortunately, we have had a few reports and have a fix. I will be sending out updates this weekend for any that were already sent files. Rest assured this is 100% corrected.
  10. Jul 3, 2022 at 9:40 PM
    #750
    Mooseditty17
    AJ
    WI
    Many people have had this issue never having been tuned. I believe it to be more vehicle based than the tune itself, but we've revamped the Reg_OL files just to be sure
  11. Jul 3, 2022 at 9:40 PM
    #751
    Mooseditty17
    AJ
    WI
  12. Jul 3, 2022 at 10:19 PM
    #752
    Maxx
    Just drove about 250 miles today through the mountains and off-road in 4LO. Dramatic improvement over the KDMax Pro map I was on. Running regular WW on 87. Still lugs under 2k RPM at elevation buy I think only gears are going to fix that. Shifting is smoother and power is really there. Still gear hunts with Constant Speed Cruise Control but it’s better. I ran it most of the day in S4+ECT and it was fantastic honestly. I can use 5th and 6th in town a bit but not on the highway in the mountains just the way it is until I go 5.29’s. The motor has never ran smoother and it really made the truck much more enjoyable to drive. MPGs we’re about the same as the old tune. Happy camper here so far.
  13. Jul 4, 2022 at 10:24 AM
    #753
    Mcbelen
    Mcbelen Active Member
    Maynard
    2022 Electric Lime Green Tacoma TRD PRO ( Manual Transmission )
  14. Jul 4, 2022 at 10:07 PM
    #754
    CO_Taco125
    '17 TRD OR DCSB
    Kevin got me the updated tune quickly and everything is working fine at this point. Will report back when I get some more miles on
  15. Jul 5, 2022 at 5:00 AM
    #755
    ChilliTaco
    Richard
    Alberta, Canada
    I am wondering if it might be related to the model year… Either way, the boys hooked me up with the revision, flashed it immediately. Will report back as needed. Thanks guys!
  16. Jul 5, 2022 at 9:47 AM
    #756
    Mooseditty17
    AJ
    WI
    The files I sent you had your name in them... How much more custom can ya get?
    :rofl:
    Bastek, FCL30, ktbell444 and 3 others like this.
  17. Jul 11, 2022 at 11:26 AM
    #757
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    @tonered do you have any suggestions? I updated over the weekend without any issue.
    tonered likes this.
  18. Jul 11, 2022 at 11:28 AM
    #758
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Did another new version drop that I missed? Think the latest came out a few weeks ago, no?
    SpeySquatch likes this.
  19. Jul 11, 2022 at 11:30 AM
    #759
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    I held off on updating for a bit. Was too busy opening up vF and getting straight to work, lol.
    mZiggy[QUOTED] likes this.
  20. Jul 11, 2022 at 11:31 AM
    #760
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The vF Software on my computer takes like 2min or longer to boot with a nice, long hang in the early stages of the progress. No big deal, just need to let it do its thing.
