Nexus Collaboration: YWNexus Blackhawk
Discussion in 'Performance and Tuning' started by Mooseditty17, Jan 21, 2022.
  1. Sep 27, 2022 at 5:25 AM
    #841
    Ppagnotta
    Ppagnotta Member
    pat
    2020 tacoma
    I've had kd max tunes for the past 2 years, never heard of this one until now. Super interested if it gives me more power over the pro xt tune I currently have. I want to push this what's possible with this little engine. Side note though, I have urd extractor pipes, full catless exhaust too.
  2. Sep 27, 2022 at 6:36 PM
    #842
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Do you have the flash kit or would you need to meet with a tuner?
    Ppagnotta[QUOTED] likes this.
  3. Oct 4, 2022 at 10:10 AM
    #843
    758_Moto
    758_Moto Well-Known Member
    2004 LT Taco, 2019 Taco
    2019: Icon Coilovers/UCA/AAL, 16x8 Methods/285 Duratracs, URD Spec-U Exhaust, Nexus +P Tune 2004: Chaos LT w/Kings/62" Deavers/12" TC Shackles, Glassworks hood/fenders/bedsides, TRD SC, URD fuel mods/lightweight flywheel/10psi Pulley, JBA Headers, TT Supra MAF
    I've run Nexus +P and now on Blackhawk, both huge improvements over KDMax Pro. More power, better shifting, and better MPG's than I got with KDMax. Still on stock downtubes but I'm running the URD Spec-U exhaust that deletes the rear cats.
  4. Oct 4, 2022 at 11:38 AM
    #844
    Maxx
    Maxx Well-Known Member
    My MPGs dropped by 2-3 with this tune. Throttle just always wanted to go. There was more power for sure but notice some low load and RPM detention. I ended up switching back to KDMax Pro and MPGs went back up to where they were before. Probably just going to leave it since I’m sick of spending money on tunes.
    Chadr7858 likes this.
  5. Oct 4, 2022 at 3:30 PM
    #845
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    MPG's are tough to guarantee. Some see an increase, some see a decrease. Most of the tunes I have tested, this included, I don't see much of a change at all.
    Regardless, if/when updates release, just remember that you are always welcome to get the newest updates from us, free of charge. No need to spend any more money.
  6. Oct 4, 2022 at 4:19 PM
    #846
    Maxx
    I had no expectations of MPG increases or decreases coming into this. I just drive really conservatively and tend to get better MPGs than most. I don’t need all the throttle at once all the time. If you want to scale the throttle back a shit ton and send me a file, I’ll give it another try. Seemed like truck was constantly hitting acceleration enrichment even just trying to cruise with a steady throttle at any speed. Then when rolling at low speeds off throttle, I’d get back on the throttle, it would ping a bit like there wasn’t enough enrichment or too much timing. Just my observations. I reset all settings at initial flash and let everything relearn.
    22tacoBred likes this.
  7. Oct 4, 2022 at 5:39 PM
    #847
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Out of curiosity, were you on WW or AD? But yes, we can gladly get a new adjusted set of files sent your way.
  8. Oct 4, 2022 at 9:14 PM
    #848
    Maxx
    It was the WW file. My understanding was that was the mildest map. I got the new file so I’ll check it out and let you. I appreciate the support. Thanks again!
    ktbell444[QUOTED] likes this.
  9. Oct 5, 2022 at 7:47 AM
    #849
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I did report pinging a while back. So you are not alone.
    ""I've been getting heavy knocking while driving slow in town. Happened 3 days in a row in 4th (25-35 mph), some while taking off from the stop. KCLV usually at 28-30 when it happens. KFB swings down to -6.8 -7.5..."
  10. Oct 5, 2022 at 8:21 AM
    #850
    Kevinpd325
    Kevinpd325 Well-Known Member
    Kevin
    San Diego
    2017 Tacoma TRD Sport 4x4
    Racks/Storage • Prinsu Cabrack w/ load panels • Leitner Designs ACS • Leitner Designs cargo pods (x2) • Leitner Designs accessory mounts (x4) • Leitner Designs Hi-lift mount • Rotopax mounts (x6) • Harbor freight roof mounted rifle case • FWP Fab bed rail shovel and axe mounts (modified for Leitner ACS) • FWP Fab bed corner mounts (modified for Leitner ACS & air fittings) Wheels/Tires • BFG 285/70 R17 KM3 • Pro Comp 61 series Cognos 17x9 wheels Electrical/Power • Genesis Offroad dual battery system • Odyssey group 34 AGM batteries • Renogy 100w solar panel w/ Voyager charge controller • Renogy 3000w pure sine power inverter • sPod4x4 BantamX • Warn winch isolator solenoid • Powertray x2 (right side modified for solar charger) • DC Power Engineering 270A alternator Engine/Performance • IS350 Custom tune • Revolution gears (5.29 ratio) • Eaton E-lockers (front & rear) • OME carrier bearing drop • Custom rear differential breather • K&N drop-in air filter • Dobinson snorkle • AC drain line mod • Start-X remote start • Redline tuning hood struts Exterior • Meso Customs Gashole • TRD Pro grille w/ LED lights • Pop & lock tailgate lock actuator • Anytime Backup Camera (modified for 2nd rear camera) • AVS in-channel weather guards • Expedition Essentials bedside compressor mount • Custom CMC & pinch weld mod • OEM spare tire well modified to fit 285/70 R17 • Goat armor (arachnid black) • Leitner Designs bed stiffeners • Black raised tailgate letters • Bed stickers removed • Debadged 100% • Herculiner bed liner • Mountain Hatch tailgate insert • Modified right side bed storage compartment for water and power connections • Vinyl wrapped hood & roof • Tacoma Twins Prinsu grab handles & Prinsu accents Interior • Meso Customs lower switch panel • Meso Customs interior chrome delete • Meso Customs extended fuse panel cover • Meso Customs overhead 3 switch panel • Relocated center 12vdc outlet • Dual USB outlet mounted in overhead console • Blue Sea dual USB outlet mounted on rear of lower console • Expedition Essentials 3TPAM w/ Blue Sea rapid charger • Doc Loco Molle rear wall panel • 67 Designs ball mounts • 67 Designs carbon fiber arms • 67 Designs universal device holder • 67 Designs sPod touchscreen mount • Ram Mounts Tab-tite iPad holder • ch4x4 cubby switch mount (water pump, winch power & air compressor switches) • Interior panels painted American flag pattern • Tuff skins glovebox letters • GPCA headrest grab handles • desert.does.it seat jackers Lighting • Caliraised LED dual function 40” light bar • Caliraised LED ditch light brackets & side shooters • Caliraised LED amber chase lights • SpartanX Customs stealth scoop light w/ Nitevision function • SDHQ Dual hidden light bar mount • Extreme LED 30" dual function light bar (x2) • Auxbeam 6x2 amber LED light pods (scene lights) • Opt7 Quantum rock lights • LED interior lighting upgrade • SpartanX Customs tricolor LED headlights & fog lights • yodaTEQ underhood LED lights • Meso Customs V2 Dome light • Meso Customs total tail lights Comms • Uniden Bearcat CB radio (mounted in center console) • Anytone AT878UV UHF/VHF radio • Rago antenna mount Armor • SSO slimline bumper w/ stage 2 • RCI sliders Suspension • Icon Vehicle Dynamics Stage 4 • Icon Vehicle Dynamics tubular UCA w/ delta joint • Icon Vehicle Dynamics RXT leaf springs • Overland Custom Designs swaybar disconnects Recovery • Smittybuilt XRC 9500 w/ synthetic cable (rewired for wireless remote) • Factor55 flatlink • 40” Hi-lift jack w/ Jack Mate • Rototrax • Vault hitch shackle block • Gear America recovery kit Audio • Kicker KS series speakers • Kicker CS dome tweeters. • Kicker 10” powered subwoofer • Subaru Kicker tweeters • Kicker Key 180.4 plug and play amplifier • Mat66 sound deadening (whole interior) Accessories • ARB twin compressor • ARB 35L fridge/freezer • Expedition Essentials propane mount w/ 11 lb tank • Outer Limit Supply first aid kit w/ magnetic mount • Rotopax Gen2 2gal fuel & water cans • Fuelpax 3.5gal cans • Quick release fire extinguisher mounts x2 • Fire extinguisher x2 (5lb & 1lb) • Seaflo series 33 water washdown pump • Custom ABS 5 gallon water tank • Roam Vagabond XL Rooftop Tent • OVS Nomad 270⁰ awning
    Sent you a DM.
  11. Oct 6, 2022 at 8:12 AM
    #851
    Mooseditty17
    Mooseditty17 [OP] Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Any logs you could send us? If using OBD, please log only: rpm, kclv, k-f/b, and load.
  12. Oct 6, 2022 at 9:08 AM
    #852
    Vlady
    Issy, WA
    I don not have logs specific for this issue. All observed on the obd. WW file w/87 gas.
    Based on the road conditons, rpms were around 1500. Not sure about load. A/C was running for sure.
    The weather was hot that week and I remember the intake temperature was around 120
  13. Oct 7, 2022 at 2:09 PM
    #853
    22tacoBred
    22tacoBred Member
    Josh
    22 Tacoma 4x2
    I had the same issues I believe as vlady and maxx. Trying to accelerate slowing just resulted in a lot of stuttering. I finally went back to nexus as I stopped receiving any replies on the issue from who sent me the tune. Shame because I did like the way the transmission behaved more with the Blackhawk tune. Either way the nexus tune is way better than stock so I’m happy.
  14. Oct 7, 2022 at 2:19 PM
    #854
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Sorry to hear that! I receive an email any time I'm sent a PM so feel free to send me one if you don't hear back from anyone else in the group.
    I'll send you an updated tune pack. Has any info changed since March? New tires, different email, etc.?
    22tacoBred[QUOTED] likes this.
  15. Oct 7, 2022 at 2:26 PM
    #855
    22tacoBred
    22tacoBred Member
    Josh
    22 Tacoma 4x2
    Wow thanks for the quick response. I have installed an AGM battery since then if there’s a firmware change for that? Other than that no sir.
    Mooseditty17[OP] likes this.
  16. Oct 7, 2022 at 2:29 PM
    #856
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    We do have a tune with adjustments for AGM. I'll make sure you get those!
    Again, apologies for the no response. I will make sure each of us has settings like mine, where emails are sent when a new message is received.
    SpeySquatch likes this.
  17. Oct 7, 2022 at 2:38 PM
    #857
    22tacoBred
    22tacoBred Member
    Josh
    22 Tacoma 4x2
    Ok thank you. As soon as I get the updated file I will give it a try and report back here. Again I’m happy with what I have and was not trying to rip on anyone. Honestly I wrote off my problem to my truck being lighter than most (4x2 access cab stock everything). Most guys on here are far from this basic setup I believe.
    Mooseditty17[OP] and ktbell444 like this.
  18. Oct 7, 2022 at 2:48 PM
    #858
    disk_55FL
    disk_55FL Well-Known Member
    disk
    Buckeye
    '17 TRD Sport MT
    I’ve also had the “pinging” ….. but, I think it’s better described as the “marbles bouncing in the skillet” sound.
    Definitely knock. I’ve had the "BlackHawk" WW 87 octane tune in since July 10 ’22 ( via A.J. / thanks ! )
    Is this the latest rev. ?
    It’s done it 3 times. Twice with an empty bed / stock weight / tires. Once while pulling the
    Boat ( 14.5 ‘ so not overloaded ). I didn’t have it “floored” …. Probably 75% throttle. Since then I use less throttle
    and it does OK. Always first or second gear. ( 6MT )
    I didn’t mention this before now …… ‘till I read that the other 3 guys were having the issue also.
    So ….. if you guys make changes to the tune ….. shoot me the file. Thanks !
  19. Oct 7, 2022 at 2:52 PM
    #859
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Yeah there was an update published right around then to address the issues that were brought up.
  20. Oct 7, 2022 at 3:02 PM
    #860
    22tacoBred
    22tacoBred Member
    Josh
    22 Tacoma 4x2
    your issue sounds different than mine. More than quarter throttle my truck ran great. It’s trying to accelerate slowly/normally is where I had issues. I also tried 87, 89 and 93 octane with no change. I really don’t think it was a ping issue. More of a too sensitive of a tip-in issue? I think that’s what it’s called but I am far from an expert on this. This is why I came to the conclusion that if my truck was heavier I would not have this issue and just went back to the nexus tune. I wasn’t expecting future upgrades for free anyway.
