Nexus Collaboration: YWNexus Blackhawk
Discussion in 'Performance and Tuning' started by Mooseditty17, Jan 21, 2022.
  1. Nov 19, 2022 at 6:47 AM
    #901
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Thanks for the clarification. I'll wait for the update addressing my issue.
  2. Nov 19, 2022 at 7:05 AM
    #902
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    I do not believe so. I don't believe you had that issue either, reading through the messages in the Facebook chat.
    RPM's will fluctuate as load increases. The AC compressor kicking on and turning off is a good example of when that will occur and shouldn't be any reason for concern.
    shotgunbilly420 likes this.
  3. Nov 19, 2022 at 7:39 AM
    #903
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Turning the wheel can make it rise too. Power steering.
  4. Nov 22, 2022 at 7:16 AM
    #904
    SpeySquatch
    2016 TRD OR DCSB
    It happens at idle at a stoplight, and I’m never running the AC. It’s also a smaller than normal fluctuation. Like I said it’s only 50 RPMs or so.
  5. Nov 22, 2022 at 9:07 AM
    #905
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    Mine does the same thing. I also have stumble starts after warmed up.
  6. Nov 22, 2022 at 9:31 AM
    #906
    Mooseditty17
    Mooseditty17 [OP] Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Factory tunes fluctuate idle. This is normal with loads varying on the engine. Please elaborate on the stumble starting. When did this begin? What octane are you running? Can you log the issue for assessment?
    SpeySquatch likes this.
  7. Nov 22, 2022 at 3:09 PM
    #907
    SpeySquatch
    2016 TRD OR DCSB
    The tune is amazing, so in no way does the idle fluctuation affect anything. I honestly think it just needs more miles. The driveability is beyond the last tune
    Kevinpd325 and ktbell444 like this.
  8. Dec 21, 2022 at 10:20 AM
    #908
    DEEPfrom1
    DEEPfrom1 Well-Known Member
    21 TRD OR Army Green
    Which throttle setting are using on the Kdmax tune? I also drive conservative for MPG and looking for a tune to help with the wonky shifting of our trucks
  9. Dec 21, 2022 at 10:35 AM
    #909
    Kevinpd325
    Kevinpd325 Well-Known Member
    Kevin
    San Diego
    2017 Tacoma TRD Sport 4x4
    Racks/Storage • Prinsu Cabrack w/ load panels • Leitner Designs ACS • Leitner Designs cargo pods (x2) • Leitner Designs accessory mounts (x4) • Leitner Designs Hi-lift mount • Rotopax mounts (x6) • Harbor freight roof mounted rifle case • FWP Fab bed rail shovel and axe mounts (modified for Leitner ACS) • FWP Fab bed corner mounts (modified for Leitner ACS & air fittings) Wheels/Tires • BFG 285/70 R17 KM3 • Pro Comp 61 series Cognos 17x9 wheels Electrical/Power • Genesis Offroad dual battery system • Odyssey group 34 AGM batteries • Renogy 100w solar panel w/ Voyager charge controller • Renogy 3000w pure sine power inverter • sPod4x4 BantamX • Warn winch isolator solenoid • Powertray x2 (right side modified for solar charger) • DC Power Engineering 270A alternator Engine/Performance • IS350 Custom tune • Revolution gears (5.29 ratio) • Eaton E-lockers (front & rear) • OME carrier bearing drop • Custom rear differential breather • K&N drop-in air filter • Dobinson snorkle • AC drain line mod • Start-X remote start • Redline tuning hood struts Exterior • Meso Customs Gashole • TRD Pro grille w/ LED lights • Pop & lock tailgate lock actuator • Anytime Backup Camera (modified for 2nd rear camera) • AVS in-channel weather guards • Expedition Essentials bedside compressor mount • Custom CMC & pinch weld mod • OEM spare tire well modified to fit 285/70 R17 • Goat armor (arachnid black) • Leitner Designs bed stiffeners • Black raised tailgate letters • Bed stickers removed • Debadged 100% • Herculiner bed liner • Mountain Hatch tailgate insert • Modified right side bed storage compartment for water and power connections • Vinyl wrapped hood & roof • Tacoma Twins Prinsu grab handles & Prinsu accents Interior • Meso Customs lower switch panel • Meso Customs interior chrome delete • Meso Customs extended fuse panel cover • Meso Customs overhead 3 switch panel • Relocated center 12vdc outlet • Dual USB outlet mounted in overhead console • Blue Sea dual USB outlet mounted on rear of lower console • Expedition Essentials 3TPAM w/ Blue Sea rapid charger • Doc Loco Molle rear wall panel • 67 Designs ball mounts • 67 Designs carbon fiber arms • 67 Designs universal device holder • 67 Designs sPod touchscreen mount • Ram Mounts Tab-tite iPad holder • ch4x4 cubby switch mount (water pump, winch power & air compressor switches) • Interior panels painted American flag pattern • Tuff skins glovebox letters • GPCA headrest grab handles • desert.does.it seat jackers Lighting • Caliraised LED dual function 40” light bar • Caliraised LED ditch light brackets & side shooters • Caliraised LED amber chase lights • SpartanX Customs stealth scoop light w/ Nitevision function • SDHQ Dual hidden light bar mount • Extreme LED 30" dual function light bar (x2) • Auxbeam 6x2 amber LED light pods (scene lights) • Opt7 Quantum rock lights • LED interior lighting upgrade • SpartanX Customs tricolor LED headlights & fog lights • yodaTEQ underhood LED lights • Meso Customs V2 Dome light • Meso Customs total tail lights Comms • Uniden Bearcat CB radio (mounted in center console) • Anytone AT878UV UHF/VHF radio • Rago antenna mount Armor • SSO slimline bumper w/ stage 2 • RCI sliders Suspension • Icon Vehicle Dynamics Stage 4 • Icon Vehicle Dynamics tubular UCA w/ delta joint • Icon Vehicle Dynamics RXT leaf springs • Overland Custom Designs swaybar disconnects Recovery • Smittybuilt XRC 9500 w/ synthetic cable (rewired for wireless remote) • Factor55 flatlink • 40” Hi-lift jack w/ Jack Mate • Rototrax • Vault hitch shackle block • Gear America recovery kit Audio • Kicker KS series speakers • Kicker CS dome tweeters. • Kicker 10” powered subwoofer • Subaru Kicker tweeters • Kicker Key 180.4 plug and play amplifier • Mat66 sound deadening (whole interior) Accessories • ARB twin compressor • ARB 35L fridge/freezer • Expedition Essentials propane mount w/ 11 lb tank • Outer Limit Supply first aid kit w/ magnetic mount • Rotopax Gen2 2gal fuel & water cans • Fuelpax 3.5gal cans • Quick release fire extinguisher mounts x2 • Fire extinguisher x2 (5lb & 1lb) • Seaflo series 33 water washdown pump • Custom ABS 5 gallon water tank • Roam Vagabond XL Rooftop Tent • OVS Nomad 270⁰ awning
    Wanted to give everyone a bit of an update on things since raising thread has been quiet. Initial release had some fairly isolated limp mode reports on some trucks, and was solved. Low end ping has also been resolved. Part throttle enrichment will be revisited in a future update. We do have several different throttle settings we've done for different owners and their driving preferences. If the tune you receive is too spicy, just let us know and we'll send you a milder setting.
    ChilliTaco likes this.
  10. Dec 21, 2022 at 10:57 AM
    #910
    DEEPfrom1
    Any Nexus tuners in the St. Louis area?
  11. Dec 21, 2022 at 11:01 AM
    #911
    Maxx
    Maxx Well-Known Member
    I use the lightest throttle map. ECT for when I tow or need more throttle on the highway.
  12. Jan 24, 2023 at 8:24 PM
    #912
    CO_Taco125
    CO_Taco125 Well-Known Member
    '17 TRD OR DCSB
    Blackhawk Tune, Falken Wildpeaks, Falcon Suspension, KMC XD, KC flexpods, KC Pro6 bar, Kicker speakers, Sound Ordnance sub, MTX amp, interior vinyl wrap
    Since it's been a year and no one has posted (;)), just wanted to see if there are any tuning updates now that we're through the holidays. I have noticed that my truck likes to shift up and down (maybe lock and unlock TC?) when accelerating from say 5mph up to 20, like it up shifts, realizes it still needed power, and down shifts again, all within a few seconds. Not sure if the issues brought up recently are related to this but thought it was worth mentioning.
  13. Jan 24, 2023 at 8:52 PM
    #913
    Vlady
    Issy, WA
    It is related to SLU solenoid management for 2nd and 3rd gears. Also, there is a large gap in throttle limits between 3 and 4th.
    Talk to @ktbell444 or @Kevinpd325. We went through this last summer with Karl, and Kevin last December.
    Kevinpd325 likes this.
  14. Jan 24, 2023 at 10:18 PM
    #914
    Kevinpd325
    Kevin
    San Diego
    Such a long year. Lol
    Definitely exactly what Vlady said. 100% TC locking and unlocking. We are in a development phase, but in the meantime if this is something that's bothering you I can set you up with what I did for Valdy last year. Lol
    CO_Taco125[QUOTED] likes this.
  15. Jan 25, 2023 at 2:13 AM
    #915
    CO_Taco125
    '17 TRD OR DCSB
    Sounds good. I'll wait for the update, hopefully soon :fingerscrossed:
    Mooseditty17[OP] likes this.
  16. Jan 25, 2023 at 12:14 PM
    #916
    Way Way Afar
    Way Way Afar Well-Known Member
    2022 TRD OR 4x4 DCSB AT
    How are updates communicated to users?
    Thanks!
  17. Jan 25, 2023 at 12:16 PM
    #917
    Mooseditty17
    AJ
    WI
    We will announce it here, on FB and our website. It's up to the customer from there if there want it. We have record of every truck tuned and can verify if you are in fact an existing customer or new one. Those tune by us prior will receive the updates free of charge.
    TongaTonyTaco likes this.
  18. Jan 25, 2023 at 1:35 PM
    #918
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Was about to post one of those " I'm asking again for your support..." memes, but I'd end up getting banned, so maybe not
    Hey @Mooseditty17 , is there a chance to get updated copy of YW Blackhawk for my truck? I asked for it in a PM some six months ago or so, maybe it got lost in the mail.
  19. Jan 25, 2023 at 3:08 PM
    #919
    Mooseditty17
    AJ
    WI
    Absofuckinlutely! Sorry for the delay bud.
    Bastek[QUOTED] likes this.
  20. Jan 25, 2023 at 3:17 PM
    #920
    Mooseditty17
    AJ
    WI
    Still have the same 2017 with 33s, 390 gears and AGM battery?
