Nexus Collaboration: YWNexus Blackhawk
Discussion in 'Performance and Tuning' started by Mooseditty17, Jan 21, 2022.
  1. Feb 1, 2022 at 8:29 AM
    #161
    S2KON2
    S2KON2 Well-Known Member
    So Cal (SFV)
    Still super early for any review on my experience with +P (1/2 tank), but so far so good. I missed that "turbo lag". Had some questions though:
    Any pro's/con's of using higher octane on +P, or is this also OL?
    How about 4H/4L changes/improvements?
  2. Feb 1, 2022 at 9:13 AM
    #162
    Mooseditty17
    Mooseditty17 [OP] Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Yes premium fuel runs better yet, and yields a slight improvement in fuel economy.
    4HI yields the same improvements as 2HI and 4 low has been significantly smoothed.
    S2KON2[QUOTED] likes this.
  3. Feb 1, 2022 at 9:18 AM
    #163
    Kevinpd325
    Kevinpd325 Well-Known Member
    Kevin
    San Diego
    2017 Tacoma TRD Sport 4x4
    Racks/Storage • Prinsu Cabrack w/ load panels • Leitner Designs ACS • Leitner Designs cargo pods (x2) • Leitner Designs accessory mounts (x4) • Leitner Designs Hi-lift mount • Rotopax mounts (x6) • Harbor freight roof mounted rifle case • FWP Fab bed rail shovel and axe mounts (modified for Leitner ACS) • FWP Fab bed corner mounts (modified for Leitner ACS & air fittings) Wheels/Tires • BFG 285/70 R17 KM3 • Pro Comp 61 series Cognos 17x9 wheels Electrical/Power • Genesis Offroad dual battery system • Odyssey group 34 AGM batteries • Renogy 100w solar panel w/ Voyager charge controller • Renogy 3000w pure sine power inverter • sPod4x4 BantamX • Warn winch isolator solenoid • Powertray x2 (right side modified for solar charger) • DC Power Engineering 270A alternator Engine/Performance • IS350 Custom tune • Revolution gears (5.29 ratio) • Eaton E-lockers (front & rear) • OME carrier bearing drop • Custom rear differential breather • K&N drop-in air filter • Dobinson snorkle • AC drain line mod • Start-X remote start • Redline tuning hood struts Exterior • Meso Customs Gashole • TRD Pro grille w/ LED lights • Pop & lock tailgate lock actuator • Anytime Backup Camera (modified for 2nd rear camera) • AVS in-channel weather guards • Expedition Essentials bedside compressor mount • Custom CMC & pinch weld mod • OEM spare tire well modified to fit 285/70 R17 • Goat armor (arachnid black) • Leitner Designs bed stiffeners • Black raised tailgate letters • Bed stickers removed • Debadged 100% • Herculiner bed liner • Mountain Hatch tailgate insert • Modified right side bed storage compartment for water and power connections • Vinyl wrapped hood & roof • Tacoma Twins Prinsu grab handles & Prinsu accents Interior • Meso Customs lower switch panel • Meso Customs interior chrome delete • Meso Customs extended fuse panel cover • Meso Customs overhead 3 switch panel • Relocated center 12vdc outlet • Dual USB outlet mounted in overhead console • Blue Sea dual USB outlet mounted on rear of lower console • Expedition Essentials 3TPAM w/ Blue Sea rapid charger • Doc Loco Molle rear wall panel • 67 Designs ball mounts • 67 Designs carbon fiber arms • 67 Designs universal device holder • 67 Designs sPod touchscreen mount • Ram Mounts Tab-tite iPad holder • ch4x4 cubby switch mount (water pump, winch power & air compressor switches) • Interior panels painted American flag pattern • Tuff skins glovebox letters • GPCA headrest grab handles • desert.does.it seat jackers Lighting • Caliraised LED dual function 40” light bar • Caliraised LED ditch light brackets & side shooters • Caliraised LED amber chase lights • SpartanX Customs stealth scoop light w/ Nitevision function • SDHQ Dual hidden light bar mount • Extreme LED 30" dual function light bar (x2) • Auxbeam 6x2 amber LED light pods (scene lights) • Opt7 Quantum rock lights • LED interior lighting upgrade • SpartanX Customs tricolor LED headlights & fog lights • yodaTEQ underhood LED lights • Meso Customs V2 Dome light • Meso Customs total tail lights Comms • Uniden Bearcat CB radio (mounted in center console) • Anytone AT878UV UHF/VHF radio • Rago antenna mount Armor • SSO slimline bumper w/ stage 2 • RCI sliders Suspension • Icon Vehicle Dynamics Stage 4 • Icon Vehicle Dynamics tubular UCA w/ delta joint • Icon Vehicle Dynamics RXT leaf springs • Overland Custom Designs swaybar disconnects Recovery • Smittybuilt XRC 9500 w/ synthetic cable (rewired for wireless remote) • Factor55 flatlink • 40” Hi-lift jack w/ Jack Mate • Rototrax • Vault hitch shackle block • Gear America recovery kit Audio • Kicker KS series speakers • Kicker CS dome tweeters. • Kicker 10” powered subwoofer • Subaru Kicker tweeters • Kicker Key 180.4 plug and play amplifier • Mat66 sound deadening (whole interior) Accessories • ARB twin compressor • ARB 35L fridge/freezer • Expedition Essentials propane mount w/ 11 lb tank • Outer Limit Supply first aid kit w/ magnetic mount • Rotopax Gen2 2gal fuel & water cans • Fuelpax 3.5gal cans • Quick release fire extinguisher mounts x2 • Fire extinguisher x2 (5lb & 1lb) • Seaflo series 33 water washdown pump • Custom ABS 5 gallon water tank • Roam Vagabond XL Rooftop Tent • OVS Nomad 270⁰ awning
    Contrary to popular belief, and claims by others... ALL tunes using vftuner are in fact OL. This has been beaten to death by Mat himself. We done extensive research and logging that back this fact. Anyone claiming they've made an OL specific tune other than Mat himself is pulling your leg.
  4. Feb 1, 2022 at 9:19 AM
    #164
    S2KON2
    So Cal (SFV)
    Thank you for clarifying that, sirs!
    Kevinpd325[QUOTED] likes this.
  5. Feb 1, 2022 at 9:26 AM
    #165
    Mooseditty17
    AJ
    WI
    :cheers:
  6. Feb 1, 2022 at 11:26 AM
    #166
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    To clarify more, only 3rd gen Tacoma tunes built from a tune pack file (there may be others but I'm not aware. I know Tundra and 4R tune pack files are NOT). Building from stock files will act like normal. Also, tweaking certain maps can negate the OL. Mat's code basically causes it to learn faster.
  7. Feb 1, 2022 at 1:07 PM
    #167
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Forgive my ignorance, OL?
  8. Feb 1, 2022 at 1:08 PM
    #168
    758_Moto
    758_Moto Well-Known Member
    2004 LT Taco, 2019 Taco
    2019: Icon Coilovers/UCA/AAL, 16x8 Methods/285 Duratracs, URD Spec-U Exhaust, Nexus +P Tune 2004: Chaos LT w/Kings/62" Deavers/12" TC Shackles, Glassworks hood/fenders/bedsides, TRD SC, URD fuel mods/lightweight flywheel/10psi Pulley, JBA Headers, TT Supra MAF
    Octane Learning, will adjust timing based on fuel used
  9. Feb 1, 2022 at 1:11 PM
    #169
    Mooseditty17
    AJ
    WI
    What he said :thumbsup:
    FCL30 and Speedfreak like this.
  10. Feb 1, 2022 at 3:53 PM
    #170
    MLee
    MLee Well-Known Member
    Mark
    Knoxville TN
    2018 Limited Cement
    OTT 7.0
    Made the 120 mile round trip again and this time took the interstate. I cruised along averaging 78-80 and got 21.4 mpg. Very smooth and nothing to report except the tune proved again to be the most refined offering I've experienced. It was tempting to play fighter pilot but not my style of driving.... I'm sure the truck would have been up to the task as it never felt strained and plenty of get up and go in reserve. I like the torque converter providing some oomph when needed in the rolling hills rather than shifting. Well thought out whomever brought that idea to the table and implemented it!
  11. Feb 1, 2022 at 3:59 PM
    #171
    Mooseditty17
    AJ
    WI
    I'm glad you're enjoying the tunes.
    :hattip:
    FCL30 and MLee[QUOTED] like this.
  12. Feb 3, 2022 at 3:22 PM
    #172
    S2KON2
    So Cal (SFV)
    Here's my quick review after my 1st tank. Might be too early to fully review, but it's been so good that it needs some praise. I'll try to keep it short.
    I've gone through several tunes (Kruiser 4.0, MD Ultimate Daily, KDMax6/7, Valley Runner 2.0, and KDMax Pro) and a lot of money. I'm about $1k deep in tunes and software/hardware, so hopefully this is my last tune. So please, no more improvements!
    Anyways, coming from KDMax Pro, it was a nice change of pace. Mind you, absolutely nothing wrong with KDMP. It's all about my driving habits. The tip-in is so far the best out of the tunes I've tried. No problems driving in tight parking lots and the truck lurching. But there's also no lag in throttle response.
    ECT button is mighty fun. Without it, is already fun. But for the times you need/want an extra power on the buttdyno, use it and you'll be happy. Having the option of the ECT modifications is one of my favorite parts of this tune.
    The "half gears" (through TC settings?) that were mentioned can definitely be felt on the highway making shifting buttery smooth. I had to check RPMs to see what gear I was in because I couldn't feel the shift.
    When I saw Nexus advertised as "smooth" I was thinking, "not another one". But it IS that smooth.
    5th and 6th gear are much more usable now. I have these freeway stretches that always shift me to 4th, but now, if I keep speed limit, it'll drop to 5th instead.
    The engine alone sounds better. Less clickity-clackity of the valves or something.
    The only thing I'm waiting for is more miles on the tune to see what MPGs I get. Other than that, I hope no more improvements come out because I'm tired of spending so much on tunes. So whichever tune gets me closest to 17mpg, wins.
    Disclaimer: I'm in no way sponsored, affiliated, or related to any of the tuners.
    acorn27, RScottie, FCL30 and 7 others like this.
  13. Feb 3, 2022 at 3:35 PM
    #173
    MLee
    Mark
    Knoxville TN
    2018 Limited Cement
    OTT 7.0
    S2KON2, your review is spot on and matches my experience as well.
  14. Feb 3, 2022 at 3:54 PM
    #174
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    Interested in the +P tune but was hoping you could answer a couple of questions.
    1). Located in CA. I’m sure you’re aware of the new law that was passed regarding tunes. Is the tune detectable when you go for a smog check, or by the dealer?
    2). What exactly would I need to flash it myself? I would prefer to be able to flash back to stock if necessary
    PM me if need be. Thanks
    MountainManGuy likes this.
  15. Feb 3, 2022 at 4:32 PM
    #175
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Awesome! I definitely understand the money part. That’s the only thing holding me back from trying out this tune. I wanna hear enough reviews from people coming from KDMP first before I bust the wallet out.
  16. Feb 3, 2022 at 5:17 PM
    #176
    Kevinpd325
    Kevin
    San Diego
    I also live and work in the infamous land of restrictions and guidance on what me may not do with our own private property. If I may attempt to answer your questions to the best of my abilities...
    First, no vehicle here is due for smog until after it's reached 8 years old. So, a 2016 isn't due until 2024. As far as making sure the truck will pass, yes you can always flash back to stock then reflash afterwards. There have been some to test this new system and pass with a tune, but in common fashion, the laws were passed before making sure detection devices are up to the task.
    Second, our files CAN be detected by a dealer if they should have reason to check. Ensuring every file is updated to current TSB should give them no reason to check (which they generally won't unless you complain about how it shifts). We CAN build files that are undetectable, but this limits a bit of the ability to properly tune AFR, because... Toyota. For those worried about warranty and such we generally build files this way so there is no question of detection by the dealer.
    Third, to flash yourself you need VFtuner software and the cable kit. Then we can sell you a single file or tune pack. Here's the link for the software:
    https://vftuner.com/collections/vf/products/vforest-tuner-software-flash-cable
    Lastly, my truck isn't registered here. So, I may test the validity of this new tune detection check, or whatever the hell it is. Lol
    Mooseditty17[OP] likes this.
  17. Feb 3, 2022 at 5:23 PM
    #177
    Mooseditty17
    AJ
    WI
    :cheers:
  18. Feb 3, 2022 at 6:48 PM
    #178
    Mike402
    Palm Springs, CA
    Appreciate the detailed response! Ok will secure that vf tuner and I'll pm you with the details of my truck. Thanks again
  19. Feb 3, 2022 at 7:28 PM
    #179
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I too am waiting for more kdmp user to give their reviews . I fell back on valley runner to get mpgs back . I'm back at 20 mpgs stock gears , 285/75/16 truck weight 5,350 lbs
  20. Feb 6, 2022 at 2:51 PM
    #180
    Kevinpd325
    Kevin
    San Diego
    Good news for you MT guys... Tests are in progress.
