Nitori's OEM SR Foglight mod!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nitori, Sep 17, 2016.
  1. Apr 17, 2021 at 10:34 AM
    #541
    caribe makaira
    Caribbean, Puerto Rico
  2. Apr 17, 2021 at 10:36 AM
    #542
    pinktaco808
    pinktaco808 Hot Steppa
    This is to turn the fog light icon to come on , in the bash? Locate ld under the dash?
  3. Apr 17, 2021 at 10:37 AM
    #543
    pinktaco808
  4. Apr 18, 2021 at 7:30 AM
    #544
    pinktaco808
    What pin 26 for again and the point of wiring to that?
  5. Apr 18, 2021 at 7:54 AM
    #545
    caribe makaira
    Go ahead and re--read slowly the first 2 pages of the thread....
    bagleboy likes this.
  6. Apr 18, 2021 at 12:56 PM
    #546
    pinktaco808
    I'm still lost lol.... it mean prewired for factory and where
  7. Apr 18, 2021 at 5:26 PM
    #547
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Lost without complete sentences.
  8. Apr 19, 2021 at 9:04 AM
    #548
    pinktaco808
    Lol
    If it pre-wired where can we wire the fog light from then?
  9. Apr 19, 2021 at 3:30 PM
    #549
    bagleboy
    Scott
    Norcal, Santa Rosa
    It’s in those opening posts of the thread. Read the part that says what to do if you’re prewired. Clue: it involves a harness by the radiator.
  10. Apr 19, 2021 at 3:35 PM
    #550
    bagleboy
    Scott
    Norcal, Santa Rosa
    The instructions for prewired are in post#68 but there’s a link to them in the OP.
    pinktaco808 and davidstacoma like this.
  11. Apr 24, 2021 at 8:46 PM
    #551
    TNslawdog
    TNslawdog Member
    Shaun
    Knoxville, TN
    2016 Tacoma SR 4X4
    BFG KO2 265/75/16, Baja Designs Fogs
    Thanks for this write up, super happy with this install! I used the stock 2015 dash switch with Baja Designs Squadron Sport amber. So glad to have the blanks gone and lights put in place.
  12. Apr 25, 2021 at 5:33 AM
    #552
    Wistrick
    Wistrick New Member
    Daniel
    2021 Charcoal Grey Access Cab SX
    NONE
    What I meant to say was the foglight relay under the HOOD was already in place, from the factory...
  13. Apr 25, 2021 at 5:35 AM
    #553
    Wistrick
    Wistrick New Member
    Daniel
    NONE
    I meant to say under the HOOD and the relay was there from the factory...
    davidstacoma[QUOTED] likes this.
  14. May 17, 2021 at 7:39 PM
    #554
    TacosRacingKTM
    TacosRacingKTM Active Member
    Josh
    '20 White 4x4 Taco CrewCab
    Thanks for the write up! Worked out great on my SR
    Anslet, Scotfree and pinktaco808 like this.
  15. May 31, 2021 at 3:15 PM
    #555
    caribe makaira
    pinktaco808 and Nitori[OP] like this.
  16. Sep 10, 2021 at 11:30 PM
    #556
    907rx7
    907rx7 Well-Known Member
    James
    '20 Tacoma DCSB SR 4x4
    So, finally coming back to this. Has anyone else done the stalk swap and not have their DRL option work anymore? I'm guessing it's a bad stalk but figured I'd ask.
  17. Sep 14, 2021 at 10:00 PM
    #557
    Scotfree
    Scotfree I drive slow
    2021 sr 4x4 2.7
    Has the aftermarket switch held up? I’m going to copy this.
  18. Sep 15, 2021 at 4:33 AM
    #558
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Good question, I actually didn’t like the location of the switch (kept hitting the Auto headlight switch instead of my fog light switch) so I replaced it with a larger form factor switch to the right of the Auto headlights switch. I used a CH4X4 switch and like the larger switch in that location much better:
    https://www.tacomaworld.com/threads/nitoris-oem-sr-foglight-mod.451495/page-21#post-23754835
    Scotfree[QUOTED] likes this.
  19. Sep 15, 2021 at 6:11 AM
    #559
    Scotfree
    2021 sr 4x4 2.7
  20. Sep 15, 2021 at 4:13 PM
    #560
    caribe makaira
    Adding a C11 T "harness" and swapping the light stalk with one with the Fog Light select, but still need to locate, remove, disassemble M6 to add the missing terminal.
    Repair wire $$$ or TE terminal to Blue wire to C11 switch side.
    Required (missing) ground on SR is joined at C11 T harness.
    Switch completes the circuit.
    Contact @kmorgan3 for custom C11 T.
