Nitrogen in the tires?
Discussion in 'Wheels & Tires' started by Okkine, Sep 25, 2008.
  1. Sep 25, 2008 at 6:01 PM
    Okkine
    Okkine [OP] Well-Known Member
    Alberta
    1998 Tacoma, V6, Manual Transmission, 4x4
    Hello All,
    When I bought my Taco a couple weeks ago, they offered to fill the tires with Nitrogen for $75. Their claim was that it helps the tires stay cooler, and maintain a constant pressure.... Since air is %79 Nitrogen, does it make a big difference? Seems kinda like a gimmick to me.
  2. Sep 25, 2008 at 6:03 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    Well I have it in mine simply because it does not flux like air however I only paid a tire shop $15 to do mine and anytime I want them checked and more added its free.
  3. Sep 25, 2008 at 6:04 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    we run nitrogen in some of our heavier use patrol vehicles
    the idea is that nitrogen tires lose pressure a LOT slower and dont have to be checked as often (i think)
  4. Sep 25, 2008 at 6:10 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    I dont like it and never needed it. Has anyone?
    And you have to go to the place who has it every time you need to fill the tires?
    that SUX!!
  5. Sep 25, 2008 at 6:12 PM
    JJ Customs
    Jay
    NV
    No you can still add air if you want but I live in the desert and with the flux in temp air will set off the TPS sensor ever couple of weeks so it makes sense for me...
  6. Sep 25, 2008 at 6:56 PM
    zuter
    zuter Well-Known Member
    Calgary, AB
    09 SR5 4x4 4 cyl
    2nd filter, undercover, debaged, bug deflector, more to follow!
    I read that using nitrogen developed from racing - formula 1, etc. Where every little advantage is investigated and used. And that it only made a difference when used in that application. However, there my be some advantage to slower pressure loss but again it may only apply to racing! Google it to get more info.
  7. Sep 25, 2008 at 7:52 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Yeah...in those racing situations, EVERY little detail counts.
    But for daily driving usage? I think its just another gimmick to make money off of.
    Compressed air can be had for free. Air actually contains what...78% nitrogen already?
    http://blogs.consumerreports.org/cars/2007/10/tires-nitrogen-.html
  8. Sep 25, 2008 at 7:54 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    I beg to differ-as I have heard you should keep it either all nitrogen or all air due to false readings.
  9. Sep 25, 2008 at 8:24 PM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    not worth paying for.... if you can get it for free (Costco) then sure why not
  10. Sep 25, 2008 at 8:33 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    Ok to help clear up some info here
    Nitrogen is larger and does not pass through the rubber in tire as fast as normal Air does.. Normal air filled tires loose 1 PSI every 30 days just sitting. and more if used at times.
    Also Nitrogen filled tires do not expand as much and when it does it does it the same every time you hit a temp range. Normal Air has a ton of water in it. THis is what makes for manny issue we have.
    Would I pay $75 hell no..
    Will Costco refill your tie NOPE. only if you buy tires from them will they..
    or if you have a friend who works their. But you can drive up and get it switched.
    So to rap this up. If you can get it free do it.
    If you have to Pay fet it under $45 for all 5 tires.
  11. Sep 25, 2008 at 8:39 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    The air we breath is about 80% Nitrogen...
    Therefore... pointless in my opinion.
  12. Sep 25, 2008 at 9:22 PM
    Killer Red Taco
    Killer Red Taco NorCal Rock Whore
    Whatsurname
    BFE–Norcal
    007 Tacoma A/C TRD O/R Impulse Red 4x4
    Bilstein 5100 on front at 1.75 setting • 5100 on back• K&N Air Filter• TRD Seat Covers• Day Time Running Lights• Foglights Anytime• Hella 500 lights in grille• Rear TSB Springs• Alternative Locker Mod• CB and 4 ft firestick II• Billet Grille• Kid puke in the back!• 265/75R16 Goodyear MT/R• 16" Devino wheels• Hose Clamp Mod• Revenge Fab Sliders• No Sway Bar• A Hottie as Copilot
    So far we have air has 78% 79% 80% Nitrogen, quit being lazy and get out and check the tires, air is free.
  13. Sep 25, 2008 at 9:29 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Hell no not worth $75. I have it in my tires, but Costco does it for FREE!
  14. Sep 26, 2008 at 12:57 AM
    Okkine
    Alberta
    Haha, that's kinda what I was thinking. Air's been working good for the past 100 years. It will keep working for what I need. Thanks for the input guys.
  15. Sep 26, 2008 at 1:57 AM
    VeeRFour05
    VeeRFour05 Active Member
    The whole idea is that nitrogen is more stable than air. With air your pressure will change about 1psi for every 10 degrees in temp change. With nitrogen it is less than that. I have it in the tires on my car because the shop put it in for free when I had them mount my tires. I wouldn't pay for it though, especially living in MN where we don't have very rapid temp changes. For people like harris that live in desert states it may be something worth getting, but not for $75.
  16. Sep 26, 2008 at 4:02 AM
    Janster
    Jandy
    Lancaster, PA
    It's not worth the gas to drive to costco to get it!
  17. Sep 30, 2008 at 7:23 AM
    sAm I aM
    sAm I aM Well-Known Member
    Jacksonville, AR
    08 TRD 4x2
    Flowmaster .50 ries xhaust, K&N Filter
    For those in the AF just get with your local AGE mechanic. Self Generating Nitrogen Servicing Carts are essential in a flightline environment.
  18. Sep 30, 2008 at 7:31 AM
    uuc328
    uuc328 Well-Known Member
    So. Arlington, Texas
    '07 FJC fender crack edition
    in for updates
    FYI - mine tires came filled with nitrogen, AFAIK i did not pay any extra for this either. i def would not pay $75 for it.
    i would like to have them topped off as when i checked them they seemed a little low (34 psi) need to do the crayon pressure trick first
  19. Sep 30, 2008 at 8:41 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    yeppers!! :D
  20. Sep 30, 2008 at 9:03 AM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    Sounds like the $tealership was really trying to take you for a ride on that one.
    I swapped out my stock tires immediately, and picked up some Michelin AT2's at Costco for a great price ($250 cheaper than the local tire shop!). They filled 'em with Nitrogen free of charge, and will do so for the life of the tires. Fortunately for me, the local Costco is about 5 miles from my house. I live in an area where temperature fluctuates +/- 40 degrees everyday, so if the Nitrogen will keep my tires' volume relatively stable, then it can't hurt.
