Nitrogen pressure change valving?
Discussion in 'Suspension' started by goomba, Feb 1, 2012.
  1. Feb 1, 2012 at 7:15 AM
    goomba
    goomba [OP] It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
  2. Feb 8, 2012 at 11:53 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    The recommended pressure for each brand of shock is usually best, however altering the pressure up and down will increase or decrease the amount of cavitation (vacuum bubble that forms behind the piston) leading to a slightly softer or firmer feel. The problem however is, too little pressure (i.e. less than 150psi usually) and the shock will fade and begin to malfunction. Too much pressure (i.e. greater than 300psi depending on manuf) and the seals may fail prematurely in addition to a potentially harsh ride. That's the simple explanation. Optimal pressure is the least amount that gets the Job done without fading or boiling the oil.
  3. Feb 9, 2012 at 5:37 AM
    goomba
    Josh
    San Antonio Fl
    Thanks.
