Nitrogen Tire Thread?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Corndawg, Nov 1, 2012.
  1. Nov 1, 2012 at 1:53 PM
    Creemore
    Creemore Well-Known Member
    Toronto
    Magnetic grey TRD Sport/leather pkg.
    If you were filling the tires on a 747, you'd want as little moisture in there over time as you could manage, to reduce its corrosive effects. For an automotive tire and wheel, I don't think moisture in these amounts is a problem at all.
  2. Nov 1, 2012 at 2:02 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Seems chris4x4 did some testing on this awhile back and came to the conclusion that it was a total crock.
  3. Nov 1, 2012 at 2:04 PM
    badger
    badger Well-Known Member
    07 SR5
    Nitrogen is not inert. Whether it is or not has nothing to with it's expansion/contraction with temperature. There are a totally different set of laws governing that. If your pressure did not change over a temp swing of 40C, then you have defied the laws of physics.
  4. Nov 1, 2012 at 2:09 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You don't want air in an airplane tire because they rapidly heat when the tires hit the runway. Water expands a LOT more than nitrogen over a similar temperature swing and could cause issues with the tires such as them freezing while in flight (meaning still frozen at touch down) and rapid expansion causing the tire to burst.
    With nitrogen, you don't pay to get nitrogen, you pay to not get moisture. The moisture expanding and contracting with the temperature swings is what causes the most noticable pressure swings. If you're buying nitrogen for your tires, what you're really paying for is dry nitrogen.
  5. Nov 1, 2012 at 2:12 PM
    t4daddy
    North Alabama
  6. Nov 1, 2012 at 4:27 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Air craft tires have nitrogen in them only because it does not promote combustion. They don't give a damn if there is moisture in them.
  7. Nov 1, 2012 at 5:03 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Untrue, they use Nitrogen in aircraft tires so that there is absolutely no moisture, no oil, and no other gases, because N2 is a dry, inert gas. If there is frozen moisture inside the aircrafts tire when it tries to land, that tire is going to explode.
    But, on a lighter note.
    Use Hydrogen in your tires, you'll get better gas mileage, cuz you'll float.
  8. Nov 1, 2012 at 5:17 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Nitrogen is used in aircraft tires because it will help to quench, rather than feed, a fire in a wheelwell caused by a hydraulic line being broken by a tire explosion.
    It is not hard to "dry" compressed air.
  9. Nov 1, 2012 at 5:36 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I lived on the USS Nimitz for 4 years and learned there are so many uses for N2 on an aircraft, main reason is that there is no moisture or oil in it, secondary reason is that the molecule is more consistent than any other combination of molecules including dry air. N2 was used in all Navy aircraft for tire inflation due to the extreme temp change when at high altitude then suddenly landing, also used for the tail hook actuator when hydraulics fail, used in side winder missile actuators and other ordinance operations, the list goes on, but you get the point. I wouldn't pay someone to put N2 in my automobile tires, but if I had an aircraft, you better believe I'd pay. Especially if it's the difference in my tire exploding upon landing.
  10. Nov 1, 2012 at 5:45 PM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    Thats exactly what they did to my tires.
