Nitto Grappler
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ttran076, Aug 18, 2008.
  1. Aug 18, 2008 at 3:31 PM
    ttran076
    ttran076 [OP] Well-Known Member
    Orange County, CA
    2014 Tacoma Sport 4x4
    Kings, TC UCA, Dakars, Prinsu rack, ARB Snorkel, Method NV, Wildpeak AT3
    Does anyone know the difference between the (P)-Passenger and (LT)-Light Truck tires from Nitto? Can I use the P version on a DC Tacoma? Thanks!
  2. Aug 18, 2008 at 3:37 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep, you can use the p- metrics.......they are less heavy than a lt tire. not as rugged for offroading, but they will be good for light offroading and great for the road.
  3. Aug 18, 2008 at 3:38 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    LT tires are usually made thicker (ie sidewalls 4 ply instead of 3 ply) and P's are softer for better highway comfort
  4. Aug 18, 2008 at 4:51 PM
    Wood
    Wood Well-Known Member
    Also, P-metrics often have less tread depth than LT tires which equates to shorter tire life.
  5. Aug 18, 2008 at 6:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    All the Nittos TG's are a 2 ply side wall. :)
  6. Aug 18, 2008 at 6:44 PM
    The_Hodge
    SC
    well screw u too then!!! :rolleyes:
    this is the site of "misinformation"!!
  7. Aug 18, 2008 at 6:48 PM
    dustin19d
    dustin19d Well-Known Member
    Dustin
    Oahu
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
    P= Passenger
    lt= light truck
    at least thats what I was tought way back when.
    It'll work fine as long as you don't abuse it.
  8. Aug 18, 2008 at 6:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :eek:
  9. Aug 18, 2008 at 6:57 PM
    The_Hodge
    SC
    lol...no hard feelings
  10. Aug 18, 2008 at 6:59 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I have P's. I wanted an AT but I only go offroad occasionally and I don't tow.
  11. Aug 18, 2008 at 7:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    C'mon......Im not that sensative...
    :proposetoast::proposetoast:
  12. Aug 18, 2008 at 7:16 PM
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    295/70/17 Cooper STT Pro, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    Also means they do not have the strength capabilities to haul heavy loads, like LT tires can. P metrics a 4 ply max. tire. Where the LT tires range from 6ply load range C, all the way up to 8-ply Load range E. higher the load range the more weight each tire can hold.
    Higher load ranges offer a stiffer tire, bad for off-road, because of the stiff side walls, and tire felxibility.
    IMHO I prefer to run LT Load C 6-ply, even A/T's, that way you get the best of both worlds. A tire good for hauling, regular driving, off-road. Not to mention won't have to worry about a toothpick puncturing your tire, like a P 4-ply....Always stay with LT's.
  13. Aug 18, 2008 at 7:20 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i agree mostly....but i had a set of p-metric bridgestone dueler a/t revos on the 06 prerunner i had....awesome,strong tire, and the did fine when i offroaded in the mountains.....and there were some pretty damn sharp rocks up there.
  14. Aug 18, 2008 at 8:28 PM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    id run LTs on any suv/truck, leave the P rated for cars.
