Nitto Terra Grappler 265/70 R17 correct psi for '09 double cab 17" wheels
Discussion in 'Wheels & Tires' started by acharney, Jul 26, 2011.
  1. Jul 26, 2011 at 2:09 PM
    acharney
    acharney [OP] Member
    Nashville, TN
    09 TRD Sport
    For those of you who want to know, I got off the phone with Nitto in California to ask them what the correct pressure is for 165/70 R17 Terra Grappler tires on a 2009 double cab TRD 17"rims (oem tires: 265/65 R17). They said if you have the P's it should be 29 psi if you have the LT's it should be 46 (45.6 to be exact) psi.
  2. Jul 26, 2011 at 2:12 PM
    TacomaGus
    TacomaGus Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    just make them between 34-40 up front and 32-38 in back, depending on how you want the ride and making sure all the tread is getting worn down (all tread is same color after driving for a while)
  3. Jul 26, 2011 at 2:16 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Do the chaulk test for the right psi. Run a line of chaulk across the tread (side to side), drive a short distance, if it's worn evenly off, you're good, if it's worn on the sides and not the middle, too low, if it's worn in the middle and not the sides, too much pressure.
    I'd say TacomaGus is pretty close though.
  4. Jul 26, 2011 at 2:35 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    x2
  5. Sep 27, 2011 at 2:06 PM
    tallywacker7
    tallywacker7 New Member
    '11 DC TRD sport (past '07 FJ Cruiser)
    Are you running the P rated? I was running them at 32 and dropped to 29- they feel a bit sluggish and look a bit low (however, i think p-rated balloon a bit more) but they sure ride nice and soft. If so, what kind of mpg and wear are you getting at 29 psi? Thanks
  6. Sep 27, 2011 at 2:12 PM
    Pugga
    Massachusetts
    Not the OP but I'm running P-Rated Cooper AT3's in 265/70R17, fronts at 34, rears at 32 (I keep the truck fairly well loaded and it's a double cab 4x4). At that pressure I get right around 20 MPG consistantly.
  7. Sep 27, 2011 at 2:14 PM
    tallywacker7
    Is the max pressure on that tire 35 psi like the p rated Nitto 265/70?
  8. Sep 27, 2011 at 2:15 PM
    Pugga
    Massachusetts
    Not sure, I think it's a bit higher but I'll have to check.
