Nitto Terra Grappler G2's not working out
Discussion in '3rd Gen. Tacomas (2016-2023)' started by offset, Nov 25, 2020.
  1. Nov 25, 2020 at 6:47 AM
    medic2230
    Murph
    Bama! Roll Tide
    For some reason as of last year they had brought the original Terra Grapplers back. I ended up putting another set of them on mine in 285’s. New 4 runner we got last year came with original Terra Grapplers also. I thought I was going to have to get the G2’s also but they started producing them again. I’ve never had an issue with the originals and on my 3rd set of them. Toyo AT’s are good tires also in wet conditions. I’m running BFG KO2’s on my new truck and I haven’t had any issues with them either in wet conditions ( it’s a lot heavier truck though).
  2. Nov 25, 2020 at 6:47 AM
    offset
    offset [OP] Member
    Adam
    2021 MGM TRD Off Road
    All stock
    Right now I am leaning towards the Toyo AT3's but wonder if wet traction will be any better. They are both rated 600AB.
  3. Nov 25, 2020 at 6:48 AM
    Fullstrut850
    Fullstrut850 Well-Known Member
    Frank
    NW Florida
    2019 SR5 4x4 DCSB White
    I have the Nitto Ridge Grapplers 265/75/16 and I love them. No road noise and drive great in the ran.
  4. Nov 25, 2020 at 6:50 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    What pressure do you run the g2s? I run mine 36-39lbs on the streets depending on temps without any issues.
  5. Nov 25, 2020 at 6:52 AM
    offset
    offset [OP] Member
    Adam
    All stock
    I keep mine right around 30psi cold
    LV-TAC likes this.
  6. Nov 25, 2020 at 6:55 AM
    trajiiic
    trajiiic Well-Known Member
    I'm also planning on putting the RGs on my OEM OR wheels whenever the factory tires are toast. I looked at all the tires suggested and they seems to be a good light weight option that's good at almost everything; cheaper too.
    I'd go for the KO2 if they were lighter probably.
  7. Nov 25, 2020 at 6:58 AM
    offset
    offset [OP] Member
    Adam
    All stock
    That's where I'm at....I would go for the KO2 but they weigh almost 50lbs....bye bye gas mileage
    PuyallupJon likes this.
  8. Nov 25, 2020 at 7:04 AM
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    I've got them on my truck and you can definitely tell the difference.
  9. Nov 25, 2020 at 7:06 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    BFGs were my worst tire for the rain.
  10. Nov 25, 2020 at 7:09 AM
    PuyallupJon
    Jon
    Puyallup, WA
    2020 Tacoma
    If you are strapped for cash, choose wisely and get what you think will be best.
    If you are like me though, once I've tried it and don't like it, off they go and they get listed on Craigs List for $1. Off to the tire shop I go to try something different. It's just money and you can't take it with you.
  11. Nov 25, 2020 at 7:17 AM
    Crimson Flam3s
    Crimson Flam3s Well-Known Member
    Falken are the best all around tire but a bit heavier(47 pounds)
    I decided to try the Nitto Terra Grappler G2 and they have been fine so far, their rain traction is definitely worst than the Falken which are outstanding and probably a top tier tire in the rain.
  12. Nov 25, 2020 at 7:22 AM
    C-PORT TACO
    C-PORT TACO Member
    Evan
    2020 MGM Tacoma TRD OR 4X4
    TRD SEMA 17" Wheels; 265/70R17 Nitto Ridge Grappler; BAKFLIP MX4
    I am on my second set of Ridge Grapplers and have never had a single issue out of them.. Aggressive enough tread design with great on road manners. I have several friends who recently swapped to the Toyo AT3 and they seem to be very happy with them. Personally, I don't think you could go wrong with either tire.
  13. Nov 25, 2020 at 7:57 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Try having them siped, if your not happy with them in rain. Nothing to lose, since you already have them.
  14. Nov 25, 2020 at 8:49 AM
    lorsteez
    lorsteez P-Town Resident (415|707)
    Northern CA
    2019 DCLB OR- Cement
    Fox 2.0 Coilovers|Fox 2.0 Rear Reservoir Shocks | Icon 1.5 AAL w/Overload | Method 305 NV 16 X 8 | Falken Wildpeaks 267/76/16 | | Diode Dynamics SS3 LED Fogs | SR Grille Surround
    Weird, I’ve had the G2 Terra Grapplers on my Jeep Grand Cherokee for 50K miles and they’re some of the best tires I’ve ever had....granted they are in an R20 lol.
    Incredible in snow and have never had any spinning or slipping issues in rain whatsoever.
    The tread wear has been minimal too.
  15. Nov 25, 2020 at 8:55 AM
    #35
    JRMiller
    JRMiller Well-Known Member
    James
    2017 Tacoma TRD Off Road
    I have the same tires, they suck when wet out, might as well have racing slicks installed when it rains. Once these wear out I’m going with Michelin’s
    Hooper89 likes this.
  16. Nov 25, 2020 at 9:00 AM
    #36
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    I've run Toyo RT since last spring, no issues.
    Lot's of grip, aggressive tread, not super loud, heavy though.. Passed the standing water at highway speed and drive for 11 hours straight tests with flying colours..
  17. Nov 25, 2020 at 9:05 AM
    #37
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Best rain tire I've run is the Michelin LTX A/T2, we have them on the wife's SUV but they're not very aggressive looking.
    medic2230 and Hooper89 like this.
  18. Nov 25, 2020 at 9:07 AM
    #38
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    Any aggressive looking AT tire will be marginal to scary in the rain. I have yoko g015 and they stick to the road like glue.
  19. Nov 25, 2020 at 9:12 AM
    #39
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    For water, you want something with unobstructed lateral and longitudinal tread voids.
  20. Nov 25, 2020 at 9:28 AM
    #40
    Hooper89
    Michelin all-terrain’s are the best but they cost out the ass.
    medic2230 likes this.
