NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Sep 2, 2013 at 7:40 PM
    #3941
    aw10tacoma
    aw10tacoma backyard mechanic
    Andrew
    Northern New Jersey
    2011 AC Mgm
    -HomerTaco Grille -Aftermarket Headlights Halo Projectors -rear doors now have pioneer speakers -Kenwood DNX690HD -LED speedo gauge swap and faceplate along with painted needles - auto start and alarm from compustar -TRD painted on grille -Strobe lights in reverse lights -All bulbs are led -XD rims -arb bumper -S.O.S. Concept SLIDERS -OME 3inch suspension lift nitrocharger sport shocks dakar leafs -light racing ucas -toughtlight 22''dual led bar behind my homertaco grille -wet okale seat covers -trailer lights connection moved into bumper -tints -trd cold air intake -trd catback exhuast -total chaos lca skids -Budbuilt Skids -DT Long tubes -URD MAF SENSOR
    No tire pressure sensors traction control is off but the light comes on as if the traction control is working the maintence required has been on since I put the cai on
  2. Sep 2, 2013 at 8:03 PM
    #3942
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
  3. Sep 2, 2013 at 8:06 PM
    #3943
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    maintenance required is your oil change reminder.
    with your odometer showing, turn the ignition off. while holding down the trip reset turn your key to the on position, the odometer will show "000000" and then the light will go out.
    that takes care of one light at least :eek:
  4. Sep 2, 2013 at 8:12 PM
    #3944
    nj636
    Kev
    Jersey
    am i reading this correctly.. you have trac control off but trac control works?
  5. Sep 2, 2013 at 9:31 PM
    #3945
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    Unplug the speed sensor wires in the front. They're a delicate wire so be careful. There's a plug at the hub then the other end is on top of the inner fender. Use a continuity tester and check both strands in that wire. There are 4 strands of copper in each wire. Chances are something got caught on one of the wires and broke the strands. You're lookin at $70ish per side. Or if you think you're good enough, cut the coating off the wire and fix it. Took me over 3 hours to fix 1 wire. It's a royal pain in the ass, but saved me money.
  6. Sep 2, 2013 at 11:38 PM
    #3946
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    Mgm ftw
  7. Sep 3, 2013 at 12:02 AM
    #3947
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    I am dowm in Cape May County, even though I am in the EHT area every now and then.
    ^^^ This
  8. Sep 3, 2013 at 3:27 AM
    #3948
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    :pccoffee:
    Did I work on my truck all weekend or fight sone MMA guy? So sore, cut, burned and bruised :(
    Way to much work for one weekend.
    :bananadead:
  9. Sep 3, 2013 at 3:30 AM
    #3949
    nj636
    Kev
    Jersey
    Sounds way too much like work
    :pccoffee:
  10. Sep 3, 2013 at 4:03 AM
    #3950
    jrzyshore
    Scott
    SNJ
    You're right that does sound like way too much work.
    :pccoffee: :yawn:And the baby was up all night.
  11. Sep 3, 2013 at 4:13 AM
    #3951
    JLink
    JLink [OP] Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
  12. Sep 3, 2013 at 4:32 AM
    #3952
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    :pccoffee: and :rant: time!
    fell asleep at around 9pm last night, WAY TOO EARLY!….I usually go to bed at 10:30 - 11 ish… fucking woke up at 2:30AM feeling rested but way too early :mad: and could not go back to bed for a while… could not even go run with my dogs cuz it was pouring like mofo… woke up again at 6:30am and now I feel like I didnt sleep shit!!!!!
    ITS GONNA BE A GREAT FUCKING DAY!!!!
  13. Sep 3, 2013 at 4:34 AM
    #3953
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    curious…. how did you make out getting the broken bolts out of your armor? did the extractor/left hand bit work?
  14. Sep 3, 2013 at 4:43 AM
    #3954
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    so you gonna use a nut… or can you re-thread it to new size?
  15. Sep 3, 2013 at 4:57 AM
    #3955
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    WIN!!!
    how hard would it be to re-thread the new hole with a thread maker bit vs welding a nut?
  16. Sep 3, 2013 at 5:09 AM
    #3956
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    DID U GET LARGER TIRES?
    IF SO U MIGHT WANT TO RE CALIBRATE THE YAW RATE SENSOR....
    I SERIOUSLY DOUBT IT WAS A RESULT OF DAVES SHOP INSTALLING AND BALANCING YOUR TIRES.....
    AND YOU WONDER WHY NO ONE WANTS TO HANG :facepalm:
    YEA THATS A GREAT IDEA.....
    MAKE SURE U HAVE DADS # ON SPEED DIAL WHEN U GET ARRESTED BY THE PARK POLICE U WILL NEED IT.....
    SEE BELOWvvvvvvvvvvvv
    TRUTH
    WHY DID U LEAVER HIS SHOP IF THESE LIGHTS WERE ON?
    IF A WIRE WAS RIPPED " AND I DONT SEE HOW" BY CHANGING YOUR TIRES
    THIS ^^^^^
    TOTALLY UNTRUE
    YAW RATE AND ABS HAVE NOTHING AND I SAY NOTHING TO DO WITH TPMS
  17. Sep 3, 2013 at 5:27 AM
    #3957
    aw10tacoma
    Andrew
    Northern New Jersey
    2011 AC Mgm
    The light didnt come on until I left driving home and I was in a hurry for a graduation party and I went back the next day and they didnt know what is going on with it
  18. Sep 3, 2013 at 6:07 AM
    #3958
    nj636
    Kev
    Jersey
    stealing this for my sig :laugh:
  19. Sep 3, 2013 at 6:09 AM
    #3959
    jrzyshore
    Scott
    SNJ
    :rofl:
  20. Sep 3, 2013 at 6:13 AM
    #3960
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
