NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Oct 5, 2017 at 8:06 PM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Seems to be coming from the back wheel.
  2. Oct 5, 2017 at 8:06 PM
    Arcticelf
    Gladiator
    I can't find anything. I'm wondering if it's a bearing?
    Blackout14 likes this.
  3. Oct 5, 2017 at 8:13 PM
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    HA! Sounds like your adjuster nut or something inside the brake drum is rubbing on something it shouldn't be. Its literally exactly what Ants truck sounds like but only when he hits the brakes
  4. Oct 5, 2017 at 9:01 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    What were the symptoms? Shaking steering wheel?
  5. Oct 5, 2017 at 9:05 PM
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    So it's the bushing in the fire wall, or is it those flexible couplings?
  6. Oct 5, 2017 at 9:09 PM
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
    It cycles with the tire, swap in a spare?
  7. Oct 5, 2017 at 9:47 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Yup. Found that....maybe I'll call tomorrow and see what they say
    stairgod[QUOTED] likes this.
  8. Oct 5, 2017 at 9:48 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Like a steering clunk when turning and hit a bump
  9. Oct 5, 2017 at 9:49 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    It's the bushing just below that u joint. Found the tsb and the zip tie fix....which I am not convinced is the best option
  10. Oct 6, 2017 at 3:03 AM
    Chux
    Chux Pura Vida
    NJ beaches
    2013 TRD O/R Beach Buggy
    Click on my Build
    I did the zip tie mod, it didn't take away all the play put took away the clunking..
    Nimble9 likes this.
  11. Oct 6, 2017 at 3:34 AM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Weld it. There's a write up on here somewhere. If I remeber I'll try to find it this afternoon
    Sub-Zero[QUOTED] likes this.
  12. Oct 6, 2017 at 6:04 AM
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
    Thanks man! I looked this up and saw the tsb too. Learned something new this morning, and I didn't even realize that this was an issue. That tsb looks pricey though, I'd try the zip tie first, pass on the welding, tsb when time and dollars allow. I wish they had sites this cool for all cars.
    uurx likes this.
  13. Oct 6, 2017 at 6:14 AM
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
    I listened to it again, and to go to the extreme, bent wheel or axle with rubbing on the shock?
  14. Oct 6, 2017 at 6:33 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Tsb should be free no? I didn't pay anything for the leaf spring tsb
  15. Oct 6, 2017 at 6:37 AM
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
    I read it as under 3/36 only?
  16. Oct 6, 2017 at 6:40 AM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    This
    The zip tie fix is a permant solution. The bushing that causes the rattle is literally just there to prevent the rattle. There are no moving parts and nothing is supported by it. Some people go the extra step of instead of just sticking a piece of a zip tie in there they wrap the tie right around into itself so it can't fall out
    Sub-Zero likes this.
  17. Oct 6, 2017 at 6:48 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Shit you're right. Well fuck me, thanks again Toyota. I tried to wrap the zip tie all the way around but I couldn't quite get it...we'll see if I'm satisfied after a test drive this weekend. Maybe I can remove that piece and press a new bushing in with tighter tolerance someday
  18. Oct 6, 2017 at 6:49 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Also I forgot, the leaf springs were a recall by the time I got it done, that's why it was free
  19. Oct 6, 2017 at 7:03 AM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
  20. Oct 6, 2017 at 7:04 AM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    The steering column bushing tbs is up 2012s from what I understand... yet they did not use the revised part on 2013s
