NKGs on Right or Left side
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WV_Tacoma, Jan 12, 2012.
  1. Jan 12, 2012 at 6:50 AM
    WV_Tacoma
    WV_Tacoma [OP] Well-Known Member
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    Sorry to many damn spark plug posts been reading for hour.
    1. my owners man says .043". I am not sure why or how you guys think it should be differant other then just saying it...
    2. Owners manual says use NGKs and Denso, it does not tell me what side to put them? Can you help. I have 3 of each only.
    Keep your flames, i been working 13hrs last night....I can't search over an hour.
    Thanks
  2. Jan 12, 2012 at 6:55 AM
    WV_Tacoma
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    Understand, but I already bought 3 or each only. SO I would at least like to put them on the side that it came with. I guess I don't want to re-engineer what TOY did.
  3. Jan 12, 2012 at 6:55 AM
    98tacoma27
    Ben
    Not Beech Creek
    The gap is .039 - .043. And it doesn't matter which plug or what side you put the plugs on.
  4. Jan 12, 2012 at 6:56 AM
    98tacoma27
    Ben
    Not Beech Creek
    Have they been changed before? If not, then you'll know when you pull them.
  5. Jan 12, 2012 at 6:57 AM
    WV_Tacoma
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    I can show you where to put your Gorilla poop!
  6. Jan 12, 2012 at 7:00 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If the plugs haven't been swapped since new, couldn't you just put replace them with the brand you take out?
    Driver's side came with NGK, Passenger side with Denso according to this thread:
    http://www.tacomaworld.com/forum/technical-chat/30479-how-spark-plug-change-1-gr-fe.html
  7. Jan 12, 2012 at 7:00 AM
    WV_Tacoma
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    Yes they been changed.
    I am not re-engineering Toyota's billion dollar job. Same for the Gap. Book states .043"....
    I understand you guys know what works, but I am committed at this point to the manual. I got bad Gas mil problems and Have to cover all the bases... I want to go SPEC!
    thanks though for your inputs on what works, I just want Dead on SPEC...
  8. Jan 12, 2012 at 7:02 AM
    98tacoma27
    Ben
    Not Beech Creek
    THIS IS DEAD ON SPEC
  9. Jan 12, 2012 at 7:10 AM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Denso on the right, NKG on the left
  10. Jan 12, 2012 at 7:12 AM
    Pugga
    Massachusetts
    Right and left are irrelevant when working on a car, always use driver side and passenger side to avoid confusion to avoid confusion.
  11. Jan 12, 2012 at 7:13 AM
    WV_Tacoma
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    Thanks 98Taco27, That is exactly what I wanted to see. Spec says .039-.043" and looks like Toy don't care which plug to use...Plan as day on this sheet, Just not in my Owners Manual.
    Wolpac I understand not every engineer is correct. But for a group that spends millions on CAI's, I have to go with the Eng's....SO what kind of CAI do you have.....?
    Thanks guys, only 7 more hours and I have to be back at work for 13hrs shift...thanks
  12. Jan 12, 2012 at 7:13 AM
    linked2002
    linked2002 Well-Known Member
    san diego
    02 tacoma, 3 linked, 6 over custom arms, cage
    links, custom 6 over arms, full 1.75 d.o.m. cage, 35 gallon cell, etc
    denso plugs are made by NGK.... just a little FYI. it doesnt matter. your truck doesnt have a brain that tells it one plug doesnt match the other. just ensure they are all the same heat index plug, change them, and drive to the store for victory beers.
  13. Jan 12, 2012 at 7:17 AM
    Pugga
    Massachusetts
    How did you get from spark plugs to cold air intakes?? :confused:
    Keep in mind Toyota spends a lot of money to engineer a vehicle to meet a government mandated specification. They do NOT engineer a vehicle to be the best it can be. They did spend a lot of time and money engineering certain components, but not necessarily with the end user in mind...
  14. Jan 12, 2012 at 7:39 AM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    ...here i am, stuck in the middle with you!
    (i am the only one that had that pop in their head? :anonymous: :eek:)
  15. Jan 12, 2012 at 7:44 AM
    98tacoma27
    Ben
    Not Beech Creek
  16. Jan 12, 2012 at 8:26 AM
    WV_Tacoma
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    Sorry WOlfpack, about the engineer thing, it was intended for someone else. Thanks for the advise. I will do the 3!!! denso side first, then measure the horse powder, Yes Powder!
    Lol
    Thanks gain for you guys help. The spec sheet said it all in black white or white black...
