No Acceleration after spark plug
Discussion in 'Technical Chat' started by deeazan, Nov 12, 2011.
  1. Nov 12, 2011 at 9:48 AM
    deeazan
    deeazan [OP] New Member
    Dee
    AZ
    06 Tacoma
    Just changed my spark plugs for my 06 tacoma (auto 4cyl). Changed them with the Xp autolite from the autostore and now the "malfuntion light" and the accelerator doesn't work.
    Was fine prior to the change, so I'm assuming it's the new spark plugs. Waiting for it to cool down before I exchange them...should I exchange them or go with the stock (denso) ones? Or other issues?
  2. Nov 12, 2011 at 9:58 AM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    Hmm... IIRC, the I4 models came with denso iridium plugs and shouldn't be changed until 90,000 miles on them. Well, that's what the tech at the dealer told me when I had my I4 in for service.
    Stands to reason that you should replace them with the same or comparable plugs, but I would recommend the denso iridiums. Just gap them correctly, add anti-seize, and make sure that the coil packs go back to the correct cylinder and you'll be g2g.
    You could just have a connection issue, as in a loose coil pack or incorrect coil pack to cylinder.
  3. Nov 12, 2011 at 1:29 PM
    deeazan
    Dee
    AZ
    06 Tacoma
    thanks! I think it was as you said coil connection...just redid connections and seems fine now. Just got to reset the "MIL" that came on from this and should be good.
  4. Dec 6, 2011 at 11:53 AM
    nobackhair
    nobackhair Well-Known Member
    There is a Hell, Az
    07 PreRunner LB Tacoma (White)
    DR coil-overs Camburg uniball UCA AFE stage 2 SI CAI AFE Catback
    Just bought an 07 Taco 4.0 at 70k. Changing evrything out. Checked out instructions on s. plugs. Didn't do anything like disconnect battery. Just swapped them out. Running really rough and making a vacuum sound. Almost stalls when braking. Is there a thread I haven't found that might explain where I screwed up? I'm going to check vacuum lines before I restart. The plugs were shot and I thought maybe the computer was trying to recalibrate. I only drove it a mile at 35mph max.
  5. Dec 6, 2011 at 11:55 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    What else did you change out at the same time as the spark plugs? Did you put OEM plugs back in and torque them properly? As stated above, check all connections, make sure they're all snug and that you didn't mix up wires.
  6. Dec 6, 2011 at 11:57 AM
    Pugga
    Massachusetts
    Ooooh, good point, that's probably it. See, that's why you make the big bucks!
  7. Dec 6, 2011 at 11:59 AM
    nobackhair
    There is a Hell, Az
    Used NKG's long thread. Didn't R and R anything else. Did disconnect some vacuum lines on drivers side. Did one at a time to avoid switching connectors.
  8. Dec 6, 2011 at 1:01 PM
    nobackhair
    There is a Hell, Az
    Vent hose reconnected.
  9. Dec 6, 2011 at 1:24 PM
    Pugga
    Massachusetts
    I don't know what you're talking about :spy:
