no cruise control
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Driftwood, Oct 16, 2024.
  1. Oct 16, 2024 at 1:54 PM
    Driftwood
    Driftwood [OP] New Member
    Rick
    '05 Tacoma TRD Sport white automatic
    air filter
    I just bought an 05 TRD Sport with 132k miles, VG condition
    the only issue is no action when pushing the cruise control button, no light in speedometer, nothing. The switch doesn't even look like it was used much, no wear signs
    What would be the most likely causes of this issue?
  2. Oct 16, 2024 at 2:11 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The clock spring, AKA: Spiral cable is normally the issue.
    Try turning the steering wheel to different spots and turning Cruise on.
    Sometimes it will make contact and work. If so, it's the spiral cable.
    reallifedog and wilcam47 like this.
  3. Oct 16, 2024 at 2:20 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Add to that...Check fuses
    TnShooter likes this.
  4. Oct 17, 2024 at 6:46 AM
    Driftwood
    Rick
    air filter
    Nope, I just spun the wheel all over left to right and nothing happened, no light came on. I've scanned it as well with no faults coming up. The place I bought it from thinks its the switch which they're replacing when it comes in.
  5. Oct 17, 2024 at 6:51 AM
    Driftwood
    Rick
    air filter
    what fuses? I see no fuse dedicated to the cruise control?
  6. Oct 17, 2024 at 7:24 AM
    2013TuRD
    2013TuRD Well-Known Member
    Bruce
    SW BC
    TRD OFF ROAD
  7. Oct 17, 2024 at 8:24 AM
    TnShooter
    Deogee
    STOCK
    The ECM controls the cruise. If a fuse were blown, you’d have other issues.
    There are ways to test switch. But most guys don’t know how or want to take the time to do it. It “can be” time consuming.
    Going to the ECM and probing the correct wires while looking at a meter can be intimidating to some. So parts start getting thrown at it.
    I’ll post a brief “how it works” later.
    But I’m not going to post the process.
    It sounds like the parts cannon is being loaded. And if it’s not costing you anything. Fire away.
  8. Oct 17, 2024 at 8:28 AM
    HappyGilmore
    HappyGilmore LambTek Innovations
    Huntsville, AL
    2013 SC’d DCSB TRD OR 4x4 | 2012 Lexus IS-F
    Yes
    IIRC, on my 2013, if the Check Engine Light is illuminated, cruise control won't work. Is your CEL on?
