No Dome, No Chime
Discussion in '1st Gen. Tacomas (1995-2004)' started by beeskib, Jan 24, 2022.
  1. Jan 24, 2022 at 7:32 AM
    beeskib
    beeskib [OP] Member
    Hey All, I've read a couple of different threads here about disabling these things. My hunch is that someone unplugged this:
    https://www.tacomaworld.com/threads/disable-that-damn-door-buzzer.54732/
    My dome light and map lights works in any position when the key is in the on position. So it turns out the Ding Ding Ding IS working when the door is open... but the light will only turn on when the key is in. Is that how it's supposed to work?
    '03 TRD
    What are your thoughts?
    B
  2. Jan 24, 2022 at 8:36 AM
    02hilux
    Planet: EARTH
    FYI, 01-04 don't have igniting ring light
  3. Jan 24, 2022 at 12:56 PM
    beeskib
    beeskib [OP] Member
    Thanks, I changed my question as I was incorrect about the Chime... but i can't change the subject...
  4. Sep 25, 2022 at 4:49 AM
    beeskib
    beeskib [OP] Member
  5. Sep 25, 2022 at 9:43 AM
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    That’s odd…the dome has three positions: on, off and door. I keep mine Off, but if I switch it to door, it comes on when I open the door and goes off after the door has been closed for 15 seconds or so.
    Chime on comes on if key is in ignition and door is open.
  6. Sep 25, 2022 at 10:16 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Do you have LEDs in your dome lights? I seem to recall some people having issues where LED bulbs would screw with the logic in the body ECU and cause them to not work properly.
  7. Sep 25, 2022 at 1:55 PM
    beeskib
    beeskib [OP] Member
    I do have LEDs, I'll try a standard light and see if I have better luck. I also but LED headlights in and the highbeam indicator stopped working, Although the high beams work fine. I wonder if that is the same issue.
  8. Sep 25, 2022 at 2:58 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That would make sense due to how the high beam indicator works on 1st gen trucks without DRL.
  9. Sep 25, 2022 at 3:14 PM
    beeskib
    beeskib [OP] Member
    Sorry, Noob here... What is DRL? Day Running Lights?
    Sicyota04 likes this.
  10. Sep 25, 2022 at 3:56 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yes, DRL = Daytime Running Lights.
  11. Sep 26, 2022 at 11:14 AM
    golferdawg17
    golferdawg17 Taco seconds-Spruce Dawg
    Columbus, GA/Dadeville, AL
    '14 Spruce Mica 4x4 Double Cab V6 TRD
    WeatherTech DigiFit Mats, Dee Zee Bed Mat, Clazzio Custom Leather seat covers (gray outer/black insert) ordered from Tyler at Clazzio (DO NOT ORDER FROM clazzioseatcovers.com)
    I have a 2nd Gen and noticed my dome light works sporadically
    since I upgraded with an LED light? could this be related to the same issue that some are having with the 1st gens (screwing up the logic in the body ECU)?
  12. Sep 26, 2022 at 9:40 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I haven't heard of anyone having this issue on a 2nd gen, I have LEDs in mine and have no issues.
    Are you sure your door switches are working? See if the door ajar light is on when the dome light doesn't work.
    golferdawg17[QUOTED] likes this.
  13. Sep 28, 2022 at 11:43 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    I've got LEDs in my map & dome lights. The ones I have now are supposedly "canbus" so I don't have the turning on issue as much but sometimes do. My old LED dome light (not canbus) did have issues turning on.
    An easy work around without having to install resistors is when my map lights ever have trouble turning on I just turn on both of them. If I have my dome light on, just one map light will turn on fine when I want. As long as one other light is on it should work fine. This is what I did before I got the "canbus" LEDs.
