No-Drill Rock Slider Options
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jckid, Jan 5, 2009.
  1. Jun 19, 2010 at 8:34 AM
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    No drilling or welding while using only OEM holes means you'll end up with a set of sliders that won't be able to withstand any kind of punishment. The only OEM holes are on the side of the frame, which means no footing when something is pushing up on the slider. They'll be mainly for looks and stepping on with your foot and could even damage the factory holes, mess up the brake line inside the frame rail, and possibly bend that portion of frame since those holes are square and the ones that are round are going to be bigger than the bolt going through it. I spent hours trying to figure out how to bolt them on w/o drilling. Drilling on the bottom won't hurt a thing, the frame is thick and also 2 layers. These frames have very little to bolt to as far as good mounting points go...that's why drilling is necessary. So basically, no drill sliders won't be sliders, they'll be steps, a sheep in wolf's clothing.
  2. Jul 13, 2010 at 8:28 AM
    gusher
    gusher SUPERCHARGED!!!
    Greg
    Hudson NH
    08 Tacoma Double Cab 4x4 long bed, TRD Sport
    '08 Indigo Double Cab TRD Sport 4x4 Long Bed, Grillcraft grill, Pioneer AVH-P3200BT head unit, XM receiver, Boyo backup camera, Custom devil horns Toyota logo, Black headlight mod, Fog lights on anytime mod, Maglight mount, Weathertech floor liners, Debadged, Trex color-matched eyelids, Access tonneau cover, Toyota bed divider, Sno-way 7'4" snow plow, Auxiliary backup lights, Rear spring TSB, Removed front mud flaps, 2.5" Hell Bent Steel front lift, 285/70-17 Goodyear Wrangler Duratracs, Satin black MB TKO wheels, Black Go Rhino Dominator II nerf steps, custom HomeLink install, CompuStar remote starter, Redline Tuning QuickLift Elite hood struts, Toyota bed mat, Custom short Taco antenna, TRD cold air intake, TRD exhaust, TRD supercharger
    Are there any warranty implications when you drill holes in the frame???
  3. Jul 13, 2010 at 8:55 AM
    jusmac
    jusmac Well-Known Member
    Avid offraod makes a few bolt on or weld on sliders, here is the link:
    http://avidoffroad.infusionsoft.com/go/avid/jusmac34
  4. Jul 31, 2010 at 9:05 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    I can speak from a Shrockworks owners perspective.
    I have only 2 regrets - One that I didn't get sliders with kickouts! - I have 2 rear doors that have trail rash that could have been saved if I had some substantial kick outs; far more damage, dollarwise than most any of these sliders cost!
    The other regret is that I failed to drill and bolt down the hole in front drivers side. The other week my front end dropped off a ledge that caused the slider to flex slightly and put a small dent in my rocker. :eek: So, if you get bolt ons, DO NOT LEAVE THE DRIVEWAY WITHOUT INSTALLING EVERY BOLT!!!
    Call me a geek but I don't like the idea of spot heat treating (welding) a thin, non-boxed frame that is designed to be a balance of strength, flexibility, and lightness. Frames today are heat treated to a spec that lives up to the design parameters for all of these characterics prior to welding and maybe after welding (more than likely you will never have any problem other than not being able to remove and replace with out the use of a welder)!
    Many manufactures only want you to weld on your sliders and there is some merit to them as well - for example All Pro wants to give you as much clearance in the height and somewhat less clearance in the width. A great design principle. They also prefer you to weld - I can understand that from their perspective. Their design will probably keep more of your sheet metal in tact.
    Regarding warranty, if you want minimum hassles from a stealer, do nothing other than wash your truck and take it to the stealer for every bit of maintenance work. I on the other hand may be silly but unless I blow a motor or a trans, they probably will not see me and my truck ever again. I realize I am an exception to the rule.
    The real deal is that, technically, they would need to prove that the drilled hole caused the intermittent windshield to fail. ;) On the other hand if you had a rusted out frame due to the welding of your sliders, or from the drilled holes from your sliders (which would be silly), your claim may be rejected.
    The biggest problem right now is that most service writers are trained to ask if the vehicle has been modified - to reduce the overall warranty costs back to Toyota. There are a few dealers that turn their head so that they improve their bottom line since warranty work brings them some nice reimbursements from Toyota.
    Good luck on your choice and I think if you follow the instructions of any of the major suppliers of rock sliders, you will be fine.
  5. Jul 31, 2010 at 10:38 AM
    snoope
    snoope Well-Known Member
    Ft.myers,FL
    2003 Lexus ES300/2004 Lexus 330 AWD
    Did everyone forget the CBI brand...they even sell the Bolt-on kit for those that make their own "rails" but need to attach by bolting on....
    Now that being said KMS will also be making bolt-ons for those living on the East Coast,New England area especially....My '02 Tacoma will be used as the "Mock-up" and will recieve the 1st set for 1st Gen....anyone with a 2nd Gen looking and available for a "Mock-up"???
  6. Aug 3, 2010 at 5:55 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Blackstone, MA
    '09 Sport DCLB Met Grey
    Toyota bed mat (1st mod), Toyota all season floor mats, Rear spring TSB, Map light mod, Fog light mod, Putco yellow fog bulbs, Weather Tech window vents, Extra d-rings, Mounted mag light, TRD CAI with AFE pro dry filter, '05 front mud flaps (winter only), 2 set's of wheels/tires, 285/75/16 Hankook MT's, Black Painted 1st Gen TRD wheels (wheeling set) Black powder coated FJ Cruiser with 265/70/17 BFGoodrich KO2's (everyday), painted center of grill & bumper black, Devil horns, OME with 885's + spacers front, OME shocks w/OMD designed rear springs, Front diff drop, Rear trailer plug relocate, ATO IFS skid, Relentless Trans & Transfer skids, BAMF bolt on rock sliders, Relentless tailgate reinforcement, Uniden 75 CB radio, BAMF antenna bracket, TRD exhaust, high lift jack w/ATO mounts. And of course ProEFX Towing Mirrors!
    What's involved in this? I might be interested.
  7. Apr 21, 2011 at 5:50 PM
    samsung
    samsung Well-Known Member
    George
    Sugar Land, Texas
    2011 PreRunner doublecab TRD Offroad
    undercover lid/Ipod integration kit/Pop n lock/bed rug, fumoto drain valve, full piping Wet Okole covers, Blacked out badges, Lamin-X fog light cover yellow, window tint, ARB deluxe bumper with fog light kit,DSM UCA'S,3 support shrockworks sliders,complete OME lift with 886X coil and dakar leaf spring with 3 degree axle shims and center pin lenghtener,warn VR10000 winch,amsteele blue synthetic rope, daystar winch isolator, daystar delrin rollers, IPF 900xs Extreme Driving H9 Kit 900XSD (900XSD),Horn on fire with shot Penning,
    all the bolt on will require you to drill some holes. or you can do what i'm going to do with mine when i get them. bolt on all pre existing holes and weld one of the support.
  8. Feb 20, 2016 at 1:46 PM
    2big4arunner
    2big4arunner Well-Known Member
    Tyler
    Vernon BC
    2015 tacoma dclb
    3/2 leveling kit, 275/60r20 duratracs on xd128 20x9 rims, AFE stage 2 intake, trd exhaust, duel electric fan w/dakota digital controller
    Regarding this thread that I know is older but maybe needs an update. I saw some sliders the other day that I am trying to find and probably will (will post if I find them) regarding no drill sliders for our tacoma's.
    The sliders I am trying to find use a bolt together box unit and engineered bolt on holders to grab the frame instead of drilling them. If you know which ones these are, link them or share the info.
    Do you have them?
    Photo's?
  9. Feb 20, 2016 at 1:57 PM
    PaulK
    PaulK Life is hard; it's harder if you're stupid.
    Paul
    Dublin, OH (but still a Pittsburgh guy)
    2013 Black Baja Access Cab
    Mobtown Bolt-on Sliders do not require any drilling and can support the weight of the truck using a high lift. They actually add structural rigidity to the frame. The only issue is that their front mound go in the same place as my BudBuilt sliders - and probable most others that use a cross member for the transfer case skid. I'm going to have a fab shop figure something out and will share when I do.
    https://www.tacomaworld.com/threads...ill-rock-sliders-for-2005-2015-tacoma.401408/
  10. Feb 20, 2016 at 2:04 PM
    2big4arunner
    Tyler
    Vernon BC
    2015 tacoma dclb
    That is one company, I am looking for this other one I saw that had clamps for the frame. I know the design will work way better and hope that others add these clamps to help with strength.
  11. Feb 22, 2016 at 10:41 PM
    2big4arunner
    Tyler
    Vernon BC
    2015 tacoma dclb
    Thank you. After searching for just about a week and passing over these guys at least 10 times I started to search pictures for sliders and found that the picture and type of slider I was looking for was indeed the mobtown version. I think I might see if they are willing to do a little modification to the design as I like a tighter fitting slider (angled up) and hopefully angled ends instead of square. but honestly this is the only design I can put onto my truck that will work for me.
    I must be tired, I better go back to work so I get some actual sleep.
    jowybyo likes this.
  12. Feb 23, 2016 at 2:42 AM
    Valsmere
    Valsmere Well-Known Member
    Brian
    New Jersey
    EXPENSIVE
    tail gate lock, rear view mirror bracket, hood hinge brackets, and the list grows.
    Yep Im going Mobtown also when I have some extra $$$, great guys btw, I just placed an order for their tailgate skin
    jowybyo likes this.
  13. Feb 23, 2016 at 2:58 AM
    ME OFF Rd
    ME OFF Rd Well-Known Member
    Jim
    Maine
    2013 TRD Off Road Edition
    - Digital Fit WeatherTechs - OME 885x Coils w/ Bilstein 5100's @ 0" - Rear Bilstein 5100's with ToyTec 2" AAL
    Check out SOS Concepts
    https://www.tacomaworld.com/threads/sos-concepts-sliders.305026/
    JimboAnz likes this.
  14. Feb 23, 2016 at 5:45 AM
    PaulK
    Paul
    They offer them in level or with a 15-degree up-angle, and with or without kick-outs. The angle version is very tight to the body. Not sure about the angles end thing, but they are pretty good guys to work with.
  15. Feb 23, 2016 at 5:54 AM
    #35
    Wile
    Wile It's a truck not a luxury sedan.
    Tim
    New Mexico
    08 4x4 DC TRD Offroad
    Pioneer AVH-5600BHS, ScanGauge, Wet Okole Seat Covers, Allpro Aluminum front bumper, Allpro Aluminum IFS skid plate, Allpro APEX rocksliders, Warn 9500s winch
    All-Pro APEX are great. They've taken a nasty beating and performed perfectly.
  16. Feb 23, 2016 at 5:54 AM
    #36
    JimboAnz
    JimboAnz Instagram @JimboAnz
    Jimbo
    Charlotte (Concord) NC
    '15 TRD OR AC MGM 4x4
    5100s with 886 springs, LR UCAs, AllPro Expo Leaf Pack, All-pro U-bolt Flip, ext rear brake lines, EGR in channel vent visors, low profile tool box, tailgate hose clamp mod, trim mud flaps, LED dome, maps, reverse lights and license plate lights, tech deck, clear view rear view bracket, plastidip badges (removed) and grill (sold) and rear bumper, G Tek Fab door sill protectors, tinted front windows to match rears, deleted silly rear seat access cab headrests, debadge, added black vinyl badges, weathertechs, MGMHLM, color matched grille, redline hood struts, ac line extension, rear diff breather extension, SOS bolt on no kick sliders, SOS full hoop front, SOS HC rear, SOS Skids, SOS Bed Bars, Iguana RTT, 4.56 gears, Iggy switch panel, SOS ditch light brax
    ME OFF Rd likes this.
  17. Feb 23, 2016 at 6:08 AM
    #37
    JimboAnz
    Jimbo
    100% no drill bolt on, is what i am running. he can also change angle if you need I think, just ask @EddyRRT
  18. Feb 23, 2016 at 6:24 AM
    #38
    PaulK
    Paul
    Could you take a picture of how they mount on the front inside of the frame? As noted above, the Mobtown sliders mount in the same spot as my transfer case skid cross member. I assume that the SOS no-drill-bolt-ons will have the same issue, but I need to see a pic to be sure.
  19. Feb 23, 2016 at 6:46 AM
    #39
    JimboAnz
    Jimbo
    Is this an aftermarket part crossmember? if stock, no interference with crossmember. Will take a pic later if I can remember :thumbsup:
  20. Feb 23, 2016 at 6:49 AM
    #40
    ME OFF Rd
    Jim
    Maine
    He will change the angle because I had him create mine at 0, his standard is 15
