No Illumination wire on factory harness
Discussion in 'Audio & Video' started by RedRumRick, Feb 26, 2019.
  1. Feb 26, 2019 at 8:03 AM
    RedRumRick
    RedRumRick [OP] New Member
    RICHARD
    Installing aftermarket head unit and the attached harness adapter has no orange or illumination wire. Testing all the wires I get one 12v on constant...one 12v with key on to acc... but no orange illum wire on adapter for 12v headlight on power.. If I check all the pins I see less than 3v on one without a wire going out...but that's not 12v or effected by headlight switch... should I remove adapter and cut factory harness to recheck wires Or...how can I tap into headlight power and create a proper connection to the illumnation wire on HU? TIA
  2. Feb 26, 2019 at 8:12 AM
    gearcruncher
    Canadain bumper technician
    When I wired my head unit in , I had 12 volts for illumination .
    What year is your truck ? WHAT YEAR IS YOUR TRUCK ?
    I did a write up a couple years ago when I installed my double din head unit . It may be relevant if your truck is 2nd gen
    https://www.tacomaworld.com/threads...ab-2010-with-pics-and-prices-write-up.364009/
    I should have the factory FSM for your truck with all the wiring diagrams .
    Send me a pm if you need the info
  3. Feb 26, 2019 at 8:33 AM
    RedRumRick
    RICHARD
    Part of my problem is I already purchased an adapter that apparently has no illum wire and I cant seem to locate a headlight switched 12v pin on factory plug so I'm thinking I may have to make a manual direct connection or perhaps to fuse box with a fuse if possible and I'll cut everything off and start fresh before I spend more $.
  4. Feb 26, 2019 at 8:36 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    What year truck? Is your dimmer switch turned down(idk if that wire is effected by the dimmer or not)
