No lift 255/75/17. Will it rub.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FLYH2O, Oct 15, 2016.
  1. Oct 15, 2016 at 7:09 AM
    FLYH2O
    FLYH2O [OP] Well-Known Member
    2016 Tacoma TRD Sport Blue
    I know guys run them but I did a few different searches and never see the results.
    Do they rub at all. I think they'll look ok on a stock no lift 2016 4x4 ?
    Any negative down side to running 255/75/17 BFG KO2 vs 265/70/17 BFG KO2?
    Stock sport wheels on now and TRD SEMA Wheels soon.
  2. Oct 16, 2016 at 3:26 PM
    FLYH2O
    Nobody owns a set of these?
  3. Oct 16, 2016 at 4:53 PM
    pra4sno
    pra4sno Well-Known Member
    Fort Collins, Colorado
    2017 DCSB OR MT. Previously 2013 DCSB SR5
    A lot of threads exist on this - likely why no response.
    I don't know the answer, I'm just being the messenger.
  4. Oct 16, 2016 at 5:52 PM
    FLYH2O
    True there are a few threads with a small hand full of guys running 255/75/17 tires.
    The problem is nobody is saying they rub or don't rub.
    They look great and the little thinner profile shouldn't hurt the fuel economy as bad as a 275?
  5. Oct 16, 2016 at 6:13 PM
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    Yes. They will rub.
  6. Oct 16, 2016 at 6:19 PM
    pra4sno
    Fuel economy on 255's is better than wider tires as tested by guys with FJ's, 4Runners, and Tacoma's, and are not at much of a contact patch disadvantage to larger tires when aired down.
  7. Oct 16, 2016 at 8:29 PM
    FLYH2O
    Thanks. I was hoping the thin profile would let me get away with no rub.
  8. Oct 16, 2016 at 8:33 PM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    Ditch the mud flaps if you have them and maybe. Depending on which tire your looking at you might be able to run them. Some of the 255/75s are shorter than the 275/70/17 that some have run stock. If you want to be certain and have more options go 265/70/17.
  9. Nov 4, 2016 at 6:45 AM
    FLYH2O
    255/75/17 BFG KO2 do fit the 3rd gen with no rubbing even with factory mud flaps. For those that want to know another option.
    I put 265/70/17 BFGs on mine because I was told it was the best (safe choice) with no lift. Buddy in my office rolled the dice and did 255/75/17 and he has had not one problem with rubbing. They look great as well!
  10. Oct 5, 2017 at 11:21 AM
    Xena1
    Xena1 Well-Known Member
    Ron
    2017 Tacoma Access Cab
    Can anyone else confirm this statement? Would like to try 255/75/17's but do not want to do lift or spacers.
  11. Jan 3, 2018 at 7:04 PM
    xxtavixx
    xxtavixx Well-Known Member
    Jacksonville fl
    2018 6MT
    ARB rear locker OVtune Mobtown sliders Core-shifter short throw Trd bro-phony grill Caliraised bumper light bar Caliraised ditch lights Rigid ignite back up lights FN Five Star 16x8 Et0 255/85/16 cooper st maxx MesoJDM fuse box cover MesoJDM led interior lights Bilstein 6112 fronts Bilstein 5100 rears Headstrong 3 aal Toytec 3* shims Mesjodm dome and map lights Diode dynamix ss3 pro yellow Mobtown aluminum front skid 2lo mod SOS front recovery point
    Ever roll the dice on this by chance? Seems some say they fit and some say they dont
  12. Jan 3, 2018 at 8:10 PM
    Big Dustin
    Big Dustin Well-Known Member
    Dustin
    Denver, Colorado
    '17 Tacoma DCSB SR 4x4
    5100's all around, OME 887 with 1/4" spacer, icon 3 leaf aal. 255/75/17 BFG KM's on 4runner pro's. Rigid led pods. Debadged and tinted.
    I'm running 255/75/17 BFG KM's on my 17 SR 4x4 with SEMA wheels. No rub at stock height, no modifications needed at all. Full disclosure, my truck never had mud flaps, so no comment on that scenario.
  13. Jan 3, 2018 at 8:33 PM
    CZ5ANM Taco
    CZ5ANM Taco Well-Known Member
    BC, Canada
    2016 DCSB Manual 35x11.5s
    Front Suspension King Ext Fronts 700# Icon UCA delta joints JD fab spindle gussets All Pro cam tabs DuroBumps Warfab steering sleeves Rear Suspension Old Man Emu leafs -Radflo Ext travel rears Timbrens ubolt flip kit SCS stealth 6 Wheels 35x11.5 Maxxis Razr [ 34.5 x 9.75 on 8.5 rim not on truck] Heavy Stuff Relentless front bumper Smitty 3rd Gen winch Big County Customs skid plates Arc One industries rear HC bumper RCI sliders Misc Arb dual compressor Arb rear locker Pelfreybilt fuse panel tray Cali raised ditch light mounts Cali raised bed stiffeners 5th Gen 4runner LED fog lights Racks Retraxone XR tonneau Yakima load bars Sherpa Roof Rack Camping Smittybilt Tent Dometic CFX50 fridge
  14. Jan 3, 2018 at 8:35 PM
    Big Dustin
    Dustin
    Denver, Colorado
  15. Jan 3, 2018 at 8:45 PM
    CZ5ANM Taco
    BC, Canada
    So when you read the Full thread I posted and see that a 33 @ 255 can fit no rub.... you decide to quote me and point out it’s a 32?
    Sorry bud finished a 16 hour shift and figured I didn’t need to explain that a bigger tire fits at same width without issue....
    Have a good one.
  16. Jan 4, 2018 at 3:47 AM
    Big Dustin
    Dustin
    Denver, Colorado
    Actually, the 33s only fit with stock wheels without rub. Pretty much any post I've seen where someone is running them on wheels other than OEM, most are SEMA or scs, they have some level of rubbing. Many have done a CMC to remedy the issue, even with a 2-3" lift. One of the major benefits to running a tall skinny tire is not dealing with the same level of modifications that comes from trying to run a 285/70.
    Thanks for letting me know that you worked a 16 hour shift, bud. I work in the oilfield, I'm no stranger to 100+ hour weeks.
  17. Feb 25, 2023 at 10:33 AM
    DrFish
    DrFish Member
    William
    Arizona
    2022 Tacoma SR 4x4
    265/70/17 BFG KO2’s C load -18 offset DX4 Beast Rims 3” front 2” rear Leveling Kit TRD Pro Grill w/ Raptor Lights
    A little late to the party but my 2022 SR 4x4 rubs with 255/75/17’s. Granted I have a -18 offset but I used a heat gun too and I can’t seem to escape it with stock lift/suspension :(
    Discount wants me to change to 265/70/17. Sad day I really wanted the 255 to work but I can’t afford a good lift to make it work :(
    hopefully this helps anyone in my shoes
