No longer available. Alpine KTP-445U Amp
Discussion in '3rd Gen Tacoma Parts Marketplace (2016+)' started by gulzeb, Jul 18, 2017.
  1. Jul 18, 2017 at 5:05 AM
    gulzeb
    gulzeb [OP] G
    Gulzeb
    Fort Worth, TX
    08 Highlander, 12 Outback, 15 Legacy
    In order of install: Tint all around Weathertech floormats Center console insert and tray 17x7.5 +15mm alloy FJ rims, painted black Morimoto 2stroke led low beams Toyota bed mat AVS in-channel vent visors Removed black stickers from doors Removed air dam Debadged JDM ASTAR reverse leds Door sill protectors Reflective black tailgate inserts Rear cam anytime Fabric console cover Extra coverage engine guards Rigid SAE fogs Kicker/Subaru in-dash speakers JBL GT7-96 front door speakers JBL GT7-6 rear door speakers Hushmat deadener and wave breakers in doors Noico deadener behind rear seats Timbren Tortun4L rear bumpstops Added Line-X'd OEM flares OEM mudflaps Skid from TRD OR Avid Off Road front bumper guard Fatmat hoodliner 2nd gen 5100's with 2885s Sway bar relocate Cut off exhaust behind spare Wet Okoles on front seats Wheelers Superbumps Wheelers 2” single AAL ATH corner tie-downs ATH bed stiffeners Line-X’d rear bumper end caps TRD Sport/OR tail lights OEM bed step TRD Pro grille Fortin remote start Leer 180 Sleeping platform in bed 265/70/17 Terra Grappler G2 BPF front recovery point OV Tune 1.04 87 Westin 30” hidden bumper light bar Rago hidden bumper brackets
  2. Jul 18, 2017 at 5:56 AM
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    Is this wired to be plug and play, since youve already installed it?
  3. Jul 18, 2017 at 6:14 AM
    gulzeb
    gulzeb [OP] G
    Gulzeb
    Fort Worth, TX
    Yes. Might not be for JBL systems, but should be on other ones, I think. For reference, I have the 6" display head unit.
  4. Jul 18, 2017 at 6:32 AM
    slowlane
    AZ
    16 double cab MGM
    Why are you selling? How is the install?
    Ive been going back and forth with this amp for a while. I might bite.
  5. Jul 18, 2017 at 9:49 AM
    gulzeb
    gulzeb [OP] G
    Gulzeb
    Fort Worth, TX
    I was getting some white noise at zero to low volumes, and I listen at low volume for the most part, so I pulled it off right after install. Driving around with normal volume music, it should probably not be noticeable. At minimum gain and at one notch above minimum gain, there was no white noise. More than that and it became noticeable at zero volume.
    The install should be a matter of unplugging a harness behind head unit, plugging into one side of amp wiring, and then plugging the other side of amp wiring into head unit.
  6. Jul 18, 2017 at 8:39 PM
    slowlane
    AZ
    16 double cab MGM
    Thats an honest guy. I also listen at lower volumes when the gf is in the car. You would think its the opposite, higher volumes when she is in the car to drown her out. But it would bug me too much if i heard any kind of feedback from the radio. I may have to pass, unless the price drops to a point where im willing to give it a whirl. Shoot me a pm if this doesnt move. Thanks!
    9TRDTCO and gulzeb [OP] like this.
  7. Jul 18, 2017 at 8:58 PM
    gulzeb
    gulzeb [OP] G
    Gulzeb
    Fort Worth, TX
    Yeah, doesn't sound like a good fit for you.
    If I don't get a bite until around noon tomorrow, I'm returning amp to Amazon. I'll get $120 back that way. This thing might just deserve returning.
    The problem is caused by putting speaker level input into the amp, from what I have been reading. Aftermarket head units with RCA out seem to get better results. The factory head unit's own low quality amp puts in a little noise/hiss, which gets amped up to become noticeable with sufficient gain.
  8. Jul 19, 2017 at 4:39 AM
    gulzeb
    gulzeb [OP] G
    Gulzeb
    Fort Worth, TX
    Taking it off the market. Returning to Amazon.
