NO OIL IN THE ENGINE
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Brenda Wirick, Jan 18, 2020.
  1. Jan 18, 2020 at 2:13 PM
    Brenda Wirick
    Brenda Wirick [OP] Member
    Brenda
    2017, 4wd, Charcoal, SR5
    none
    Excellent suggestion on the extended warranty. When I take the truck back for the 1000 mile follow up I will definitely insist on the warranty.
    There was a HUGE mess under the truck when it came to a stop on the side of the road. The dealership steam cleaned under the truck to clean up all the oil that sprayed the underside. It smelled SO bad when I was driving it, I thought it was the semi in front of me.
    The service manager at the dealership admitted it was an error of the mechanics for not following up after the service job. He showed be the part, now I am not a mechanic so I really do not know what I was looking at. He showed me the cylinder, which he said holds the oil in the truck, and it had a 2" flat side, which he said was due to either a bad O-ring or the cylinder not screwed in properly. Nevertheless, he admitted that it was their fault. He is emailing me with all the details. I am disappointed in that I have not received an email as of right now.
    What a mess!
    eurowner likes this.
  2. Jan 18, 2020 at 2:14 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Dry and without lube. That is what the dealer is doing to you.
    No code is going to set, especially that fast, when you have damaged bearings, piston rings and cylinders. They owe you a new engine or a tear down, complete inspection, and long term warranty on the engine.
    I'd push it up the Toyota chain before the dealer conveniently ''forgets all about it.
    jackn7, Gunshot-6A, Garab and 8 others like this.
  3. Jan 18, 2020 at 2:15 PM
    kite_325
    kite_325 A simple human, being
    North Carolina
    2017 TRDOR
    This and also a perfect time to go to the Toyota dealership on the other side of town or the next town over from now on
  4. Jan 18, 2020 at 2:16 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Cylinder, guessing the oil filter.
  5. Jan 18, 2020 at 2:18 PM
    psc199333
    psc199333 Well-Known Member
    Phillip
    2016 Trd off road
    Next time run that son of a bitch till it is locked up tighter than a tick. That way they have no option but to give you a new engine, which is what they SHOULD be giving you this time.....
  6. Jan 18, 2020 at 2:18 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    That’s what I’m understanding. Sounds like they didn’t put that o ring onto it in the right groove and the oil pressure was enough to shoot nice hot oil out past the threads on the filter housing
  7. Jan 18, 2020 at 2:18 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Over my 40+ years of lubricants, about 1 time a year I hear, see, read about a shop at any given level forgetting to completely refill. Point is, it happens. Dealer owes you a new engine or some kind of rock solid guarantee to replace your engine.
    It's Jan 18th. Wow.
  8. Jan 18, 2020 at 2:19 PM
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    2017 TRD Sport AC MT
    If they had forgotten to put oil back in it the OP would have had some idea when they left the dealer.
    I doubt they forgot to fill it, but also a "bad O ring" is doubtful too... I suspect someone at the dealer missed one vitally important step.
  9. Jan 18, 2020 at 2:23 PM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    @Brenda Wirick I’d recommend going back to the dealerships service department and calmly state that you don’t feel confident with having ran an engine with no oil and the potential damage to the cylinders, bearings and internal components. That you’re not comfortable with their course of action.
    If I were in your shoes I wouldn’t settle for anything less than a new engine. Period
  10. Jan 18, 2020 at 2:24 PM
    Biged_72455
    Biged_72455 Active Member
    99 Tacoma sr5 2wd 2.4
    I’m on team “somebody’s ass better be getting FIRED and you get a new engine!”
  11. Jan 18, 2020 at 2:32 PM
    iptman
    iptman Well-Known Member
    Northen VA
    2018 TRD Pro, 1997 Land Cruiser, 1977 Land Cruiser
    No way a dealer gives anyone a new engine for this without a lawyer. We're talking about $5k easy for the work. I don't care how insistent you all think you'd be. Only way this is resolved is through TMS which is the way she should go at this point. Get names of all people involved and start making phone calls to TMS.
  12. Jan 18, 2020 at 2:33 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Push for extended warranty. Everyone f's up sometimes and there are consequences. Make them give you a warranty.
    With that said, you should have learned a lesson as well. When you have work done like oil change or tires changed, visually inspect the work. In this case a quick look underneath at the ground would have saved you a lot of grief. Good luck.
  13. Jan 18, 2020 at 2:33 PM
    SVMTRCSR
    SVMTRCSR Member
    2019 Silver SR/SX ACV6
    jackn7, Garab and Brenda Wirick[OP] like this.
  14. Jan 18, 2020 at 2:36 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Sergio W and Brenda Wirick[OP] like this.
  15. Jan 18, 2020 at 2:37 PM
    #35
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    Not sure if you can afford it but I would want to trade it in to them on a new one at a great deal . That truck would make me uneasy all the time .
  16. Jan 18, 2020 at 2:39 PM
    #36
    NM Lance
    NM Lance Well-Known Member
    In big, and bold letters, please let everybody on here know which dealership did this to you. They owe you an engine of equal quality and mileage after what you just described.
    Big and bold letters, please. And, casually mention you asked for help in an online forum and mentioned their name when you speak with them again.
  17. Jan 18, 2020 at 2:40 PM
    #37
    nat103
    nat103 Well-Known Member
    KY
    2017 DCSB OR
    Unless it’s lifetime warranty I wouldn’t be happy
    Brenda Wirick[OP] likes this.
  18. Jan 18, 2020 at 2:44 PM
    #38
    dr4g1116
    dr4g1116 Well-Known Member
    2019 Silver Sky Metallic TRD OR SB M/T
    Lifetime warranty or new engine. If not, sue for damages and keep the truck. The wear on a motor that is run without oil can be detrimental to the longevity of the engine. I can guarantee there is some scoring of the piston walls and a drop in compression.
  19. Jan 18, 2020 at 2:46 PM
    #39
    TA2016
    Oregon
    A couple of months ago I got 4 new tires. When I got my truck home I jacked it up and loosened all the lug nuts, tighten them with a torque wrench and rechecked them myself after 100 miles. I don't trust anyone touching my truck.
  20. Jan 18, 2020 at 2:50 PM
    #40
    FritoBandito
    FritoBandito Well-Known Member
    Texas
    2016 Limited 4X4 DCSB
    Brenda - the dealer owes you a new engine.
