NO OIL IN THE ENGINE
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Brenda Wirick, Jan 18, 2020.
  1. Jan 18, 2020 at 2:53 PM
    #41
    Brenda Wirick
    Brenda Wirick [OP] Member
    Brenda
    2017, 4wd, Charcoal, SR5
    none
    LEGACY TOYOTA, TALLAHASSEE, FLORIDA
  2. Jan 18, 2020 at 2:56 PM
    #42
    420taco
    420taco Well-Known Member
    Justin
    PA
    Yeah I don’t think I’d be happy with anything less than a new engine. And no way in hell would I want the same dealership doing the swap.
    wilcam47 and Brenda Wirick[OP] like this.
  3. Jan 18, 2020 at 2:57 PM
    #43
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Find a reputable independent mechanic. Tell him what happened and ask him to perform (1) a compression test on all cylinders; (2) a leak-down test; (3) examine the cylinders for scoring; and (4) listen to the bottom end. This should run you about $250. Ask him to note any parameters that are out of spec, and anything which appears to be a sign damage as a result of low oil. If everything appears okay, THEN ask the dealer for the free, 100K warranty. If ANYTHING is out of spec according to the independent mechanic, then have him detail that on company letter-head, take it to your Toyota dealer and tell them you want a new engine AND the cost of the independent inspection.
    bbrown, Blockhead, Bobcdn and 6 others like this.
  4. Jan 18, 2020 at 3:01 PM
    #44
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I don't trust them either. When I took delivery of my truck the AT fluid was a quart low, all 5 zerks were dry and the rear diff was weeping.
  5. Jan 18, 2020 at 3:09 PM
    #45
    tbr3345
    tbr3345 Well-Known Member
    Tom
    Sacramento, CA
    2010 TRD Sport DBL Cab Silver Streak Mica
    New engine Give them a Choice New Truck or New Engine. Find an attorney who write letter first. Some time knowing an Attorney is involved will get them moving. My cousin is an attorney. He wrote a letter to the absentee landlord of property behind me over an issue with tree damaging my shop and the attached deck. Problem solved. This was after I tried for 2 being a nice guy.
  6. Jan 18, 2020 at 3:10 PM
    #46
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Yeah like as long as your grandchildrens children's step child
    OP, just because the computer says it's fine. It's probably not if it starved without 6 qts of oil. My guess is they forgot to refill it not that it 'leaked" no way 6 qts can leak that quickly unless they forgot to put the filter or bolt back on in which case they would have a mess
    wilcam47 and Bodyguard89 like this.
  7. Jan 18, 2020 at 3:15 PM
    #47
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    WTF? Another dealership from hell. If this motor ran without oil; it will eventually have a major meltdown. New motor or let it sit in there lot till the bank takes it back. Toyota's are junk anyways.
    Brenda Wirick[OP] likes this.
  8. Jan 18, 2020 at 3:20 PM
    #48
    KGTaco
    KGTaco Well-Known Member
    Southern California
    2019 Tacoma TRD 4x4 Offroad
    King 3.0/Bumps/Deavers/33s
    :popcorn:
    Any 2019 Sr5 on the lot heavily discounted that they can trade you up for?
  9. Jan 18, 2020 at 3:29 PM
    #49
    TA2016
    Oregon
    Brenda, while you are deciding what action to take with the dealership, check you oil dipstick regularly. If you notice the oil level dropping, make sure the dealership documents that in your file and get a paper printout for your records.
  10. Jan 18, 2020 at 3:30 PM
    #50
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    with them not putting oil in the engine you can expect advanced wear on any metal to metal surfaces. They owe you a legitimate reason and an extended warranty
    This is why i change my own oil. The kids they have at the dealerships they pay 10/hr from superlube to change oil on the weekends.
  11. Jan 18, 2020 at 3:34 PM
    #51
    Taco16LB
    Taco16LB Well-Known Member
    Ask the dealership owner , to take his car or a favorite collector car of his , and empty the oil , drive it a similar amount and then ask to know what he does in the future .
  12. Jan 18, 2020 at 3:35 PM
    #52
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    I’m impressed you drove the truck after they said to drive 1000 miles. Maybe due to lack of knowledge but I’m with everyone else here as I wouldn’t accept anything but a brand new crate engine in this case.
  13. Jan 18, 2020 at 3:37 PM
    #53
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    She commented that there was a huge oil spill under the truck and oil all under it. Looks like the o ring that good on the filter housing wasn’t metaled correctly and the oil pressure forced oil past the threads on the housing
    Spare Parts, FishnTx and Bleep100 like this.
  14. Jan 18, 2020 at 3:42 PM
    #54
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    There's no doubt in my mind that they forgot to add the oil. and the pistons are all messed up now. OP you need to get them to do a tear down on that engine. It's probably toast
  15. Jan 18, 2020 at 3:43 PM
    #55
    TA2016
    Oregon
    This article talks about a Demo possibly being a good deal under the right conditions. I think not running the engine without oil would be top on that list. Watch out when they say it was the owner's demo and he/she took good care of it.
    https://www.edmunds.com/car-buying/can-buying-a-demo-car-save-you-money.html
  16. Jan 18, 2020 at 3:46 PM
    #56
    auskip07
    Skip
    Atlanta, Ga
    Pistons?
  17. Jan 18, 2020 at 3:47 PM
    #57
    Clipper16
    Clipper16 Well-Known Member
    Gil
    Tennessee
    2018 TRD Sport ACLB Intense White Tech and Pro
    Pull the filter and check for metal.
  18. Jan 18, 2020 at 3:54 PM
    #58
    photogr4x4
    photogr4x4 Well-Known Member
    Canada
    TRD OR
    Nada
    Are you thinking no gasket or just no torque to the plug? All things considered it could be both given the situation and the carelessness of whoever changed the oil.
  19. Jan 18, 2020 at 4:00 PM
    #59
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    They owe you a new engine...no question about it.
  20. Jan 18, 2020 at 4:05 PM
    #60
    Mopar Mussel
    Mopar Mussel Well-Known Member
    Jurgis
    2025 Corolla Hybrid LE, 2006 SAAB 9-5 Aero
    I would try to get a new engine, if you could. I cut my teeth on old Subarus with cooked rings, which meant lots of oil consumption and low oil levels. Those Subaru motors don't do great without enough oil.
    Engines spin FAST, and a lot can get messed up in a short time if they are not properly lubricated.
