NO OIL IN THE ENGINE
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Brenda Wirick, Jan 18, 2020.
  1. Jan 18, 2020 at 4:17 PM
    #61
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Prior to going back to the dealer take a sample of the motor oil and send it to Blackstone Laboratory for analysis. Give them the explanation of what happened pending their opinion may put you in a better position to negotiate whatever remedy is due you.
    jackn7, nat103, Big tall dave and 2 others like this.
  2. Jan 18, 2020 at 4:26 PM
    #62
    Wsteven
    Wsteven Well-Known Member
    2018 Tacoma TRD Pro
    Working on them
    After reading this entire thread and that there was a large amount of oil under the truck I have a few comments to make about this 1st is the oil loss for that amount of oil the newbie service tech kid probably missed the old "O Ring" stuck on the filter housing so ended up with double flat O rings that will hold oil pressure until they get hot then out gushes all the oil.
    2nd thing is if you heard loud "knocking and Clicking" that engine life has been severely compromised and it life expectancy is over like we are talking important bearings are damaged, piston rings may have scored the cylinder walls that kind of damage will result in oil burning that can lead to an host of other problems like destroying the catalysis converter and Fail of state emission test..... and 1000's of dollars in cost. As one of the Post here stated Look for a Lawyer that will simply write a Letter first. Explain to the Lawyer everything and that you would like to do it in progressive steps.
    That Dealership service manager is attempting to brush you off when they know darn well that the damage is done and can be severe.
    Auto Engines are not designed (I have not seen any yet) to run without Oil so Basically That Truck should have a full Short block <--- should said long block replacement done at a Dealership of Your choice I would not trust the place that messed up not because I don't think that they can't do the work properly I would be more worried about getting cheap shots from there.
    Again this is My opinion based on working on Toyota Engines and drive trains, Benz Diesel Engines and Hydraulic systems and have seen what oil starvation does to Engines even if it is brief.
    Edit ... one of our sharp readers caught this ... I said Short block when I mean Long Block (short block is no heads)
  3. Jan 18, 2020 at 4:29 PM
    #63
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    Possibly not a bad o ring just a oring not installed/replaced
    This- I wouldn’t wait until the 1k mark to come back. They are hoping you don’t know any better and that they can skate on this screw up
  4. Jan 18, 2020 at 4:31 PM
    #64
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    2017 TRD Sport AC MT
    I had an old Jeep Cherokee that the plug just plain blew out on and dumped 5qts fairly quickly.
    Who knows?
    But you're right... carelessness was involved.
    photogr4x4[QUOTED] likes this.
  5. Jan 18, 2020 at 4:35 PM
    #65
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Ive changed my oil numerous times. Never had issue with oring under 30K,i call BS on dealer
    Brenda Wirick[OP] and scottalot like this.
  6. Jan 18, 2020 at 4:40 PM
    #66
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Lol I have learned to just spot check instead of checking them all.
    Brenda Wirick[OP] likes this.
  7. Jan 18, 2020 at 4:42 PM
    #67
    supmet
    supmet Well-Known Member
    Paul
    Rancho Cucamonga, CA
    2019 White TRD OR 4x4
    I would way way rather have a 200k or lifetime warranty on an engine that ran dry for a few minutes than have an engine installed by a dealership. I'd put money the engine is fine and will run 300k miles no problem. Tolerances on modern engines are insanely tight, you're not gonna score cylinder walls on a 30k mile engine driving it with no oil for a couple minutes. Plus there was probably still oil coating most parts even if it was "dry"
    We've established dealerships can't even change oil right, but you want them to replace an entire engine??
    Personally I'd push for their platinum whatever warranty for 100k and lifetime on the engine and call it a win.
  8. Jan 18, 2020 at 4:48 PM
    #68
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    This ^^^^^^^^^X2^^^^^^^^^^^ the damage that has been done to this engine can NOT be undone. the least Toyota needs to do in this situation is provide you a Lifetime Warranty on this Engine and include free oil changes until it fails. Just my .02
  9. Jan 18, 2020 at 4:54 PM
    #69
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Sounds like the oil filter was double gasketed...or the oil plug fell out
  10. Jan 18, 2020 at 4:54 PM
    #70
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    I wished I asked for lifetime warranty on my accord tranny when tranny fluid leaked out.
    I was a rook back then.
    Hopefully they did not add oil to tranny.
    tonered[QUOTED] likes this.
  11. Jan 18, 2020 at 4:56 PM
    #71
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Ho.. LEE ... FUDGE
  12. Jan 18, 2020 at 4:59 PM
    #72
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    I retract my above statement after reading the later post about the oilshitski all over underneath. Sounds like filter housing plug, no?
  13. Jan 18, 2020 at 5:01 PM
    #73
    Lucifer1
    Lucifer1 Well-Known Member
    Lucifer
    Plano TX
    2023 Silver TRD Sport Access cab V6 automatic
    Toyota Bed divider
    Open a case with Toyota, contact the free Attorney referral service in your area (there is one)there are lawyers who specialize in this kind of work who will take a case like this on a contingency basis (no cost to you) and whatever you do, don't sign anything the dealer presents to you, if its not exactly what you want. and you have reviewed all your legal options.once you do, you are stuck right there. signing means you have accepted their repair. and they are done with you.
    Good Luck
  14. Jan 18, 2020 at 5:01 PM
    #74
    TomTwo
    Bill
    I-85 Southbound
    @Brenda Wirick remember you did nothing wrong in this situation and you are the victim. Play your position. :thumbsup:
  15. Jan 18, 2020 at 5:05 PM
    #75
    photogr4x4
    photogr4x4 Well-Known Member
    Canada
    TRD OR
    Nada
    I definitely stand with anyone saying push for warranty especially lifetime on the engine.
  16. Jan 18, 2020 at 5:07 PM
    #76
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    They owe you a new engine or truck. A truck would be easier. But don’t settle for less than an engine. I hope you get an admission in writing.
  17. Jan 18, 2020 at 5:08 PM
    #77
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Contact the DSM...warranty and free oil changes till 100k.
    But I wouldn’t think it would be hurt....it takes a lot more than no oil to blow up a Toyota
  18. Jan 18, 2020 at 5:12 PM
    #78
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    I bet the motor is fine.....
    But if this happened to me, I'd drive it 60k and trade her in as long as it didn't give me issues beforehand
  19. Jan 18, 2020 at 5:15 PM
    #79
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    Not pistons, but rings. Real damage will be the rod bearings, and or crankshaft.
    Lucifer1 and Brenda Wirick[OP] like this.
  20. Jan 18, 2020 at 5:18 PM
    #80
    Evlkarl
    Evlkarl Well-Known Member
    The Devil,s Bum Phoenix AZ
    2019 black SR5
    nothing big yet Tac Bar K@N Filter Side Steps
    Brenda in case you end up with a new truck feel free to post the vin of your old truck here on this forum so nobody will end up buying it. I have seen it too many times Dealers had to buy back a car under the lemon law run it thru the detail shop and dropped it in the used car lot without performing any work on. Kinda like change the oil/filter and drop it in the used car lot.
