No start but cranks and has fuel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SophieJoey, Apr 1, 2019.
  1. Apr 1, 2019 at 7:21 PM
    SophieJoey
    SophieJoey [OP] New Member
    Braden
    2007 PreRunner
    2007 2.4L Manual trans
    Well its been a wonderful 12 years with this truck but for the first time it's given up and won't start. Two days ago the 'ECU-B' 7.5 amp fuse blew and it wouldn't start, new fuse and it worked like new for another day and a half. Today it wouldn't start again, won't fire even once, but I checked every single fuse with the ohm-meter and all are good. I thought the fuel pump went out so I popped the fuel line off the fuel rail and jumpered the 'EFI' relay and 'C/OPN' relay and I got a jet of fuel about 2 feet high. Popped the fuel line back on and with the relays still jumpered I tried starting again but still nothing. I played musical chairs with a few other relays and double checked all the fuses again but no luck. The truck is parked at work so I'm going in early with some tools to see if I'm getting spark but since I'm not getting a single fire I'm betting there won't be any spark.
    ECU-B fuse blew, won't start, replaced fuse and works fine
    2 day later won't start again.
    Verified all fuses good, and fuel pressure to fuel rail, swapped relays around, still no fire.
    Does anyone have any suggestions on what me be causing this? I thought there may be a part that controls all the ignition coils but they're wired directly to the ECU. Granted the ECU-B fuse blew but they're two separate 'ECU's, right? Also I read that a crank sensor or cam sensor could cause this same issue? Any ideas on that?I read elsewhere you can pull the MAF plug, crank sensor plug, and temp sensor plug, and you can sort of force the ECU into 'limp home' mode, I'll give that a try just so I can get it home.
    Any and all help is greatly appreciated, I feel pretty dumb asking to bum a ride at 30 years old.
  2. Apr 1, 2019 at 8:08 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Does the Stereo, Dome light work?
    This is why I ask:
    PzTank likes this.
  3. Apr 2, 2019 at 4:49 AM
    SophieJoey
    Braden
    2007 PreRunner
    Hmm, I swapped the dome fuse for the ECU-b fuse so I dont have some lights right now, but the short pin still reads good.
  4. Apr 2, 2019 at 12:00 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    The short pin is just a conductive bridge ( not a fuse ) that is removed during vehicle shipping to remove battery drain while the vehicle is in transit and storage. It is installed as part of vehicle prep by the dealer.
  5. Apr 2, 2019 at 12:19 PM
    jimmy c
    jimmy c Well-Known Member
    jim
    Port St. Lucie Fl.
    2015 tacoma
  6. Apr 2, 2019 at 12:21 PM
    jimmy c
    jim
    Port St. Lucie Fl.
    2015 tacoma
    long time listener. first time caller. this is for a 2.7 litter. 2007. all the things that fuse works. hope this helps some
  7. Apr 2, 2019 at 12:22 PM
    jimmy c
    jim
    Port St. Lucie Fl.
    2015 tacoma
  8. Apr 2, 2019 at 12:50 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    If the fuse blew, I would check all the wiring back to where ever that ECU lives. If the wiring is good, you probably have a bad ECU. One way to check the wiring is to find the ECU and the fused wire which terminates to the plug in connector. Put a good load on it (say a 50W-75W load). If it works without blowing the fuse the wiring is likely good.
  9. Apr 2, 2019 at 1:11 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You need to ensure that there is not an excessive amperage draw from the radio or there is nothing defective about the dome assemblies. If that can be ruled out then you have a defective PCM which is causing too much resistance.
    You will also have to check wiring to make sure that you don't have an intermittent short circuit either, which is always a possibility on a truck that old.
    There is no easy way to check this. If it is out of your league I would take it to a shop to get professionally inspected.
  10. Apr 2, 2019 at 6:44 PM
    SophieJoey
    Braden
    2007 PreRunner
    So after a few hours of shooting wires I pulled out the ECU-b and found the problem, somehow plug 1I on the back of the ECU-B worked it's way loose and just fell out as I pulled it back. The plug has some sore of molding deformation as the clip has some extra mangled plastic where it should depress and snap into its slot. I cut out enough of it to get the plug to seat properly but will have to take a closer look tomorrow with some daylight. Either way it was a weird situation, I've never had the ECU-b out before or had that plug out so it's a surprise it's held on for this long, and I've never seen a plug with this manufacturing fault before. But thank you all for the good info and insight, and I'm really glad I saved the wiring diagrams I found here a few years ago, they were a Godsend.
    PzTank, Muddinfun and TRDSport10 like this.
  11. Apr 2, 2019 at 6:53 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Thanks for the reply on this thread OP!!! I have an 06 2.7L manual myself, so considering that we likely have the same qiring harness and ECU setup this info might help me some day.
    Glad you found what appears to be the issue!
