NO START plus no 4wd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mad Man Marty, Aug 27, 2015.
  1. Aug 27, 2015 at 9:42 PM
    Mad Man Marty
    Mad Man Marty [OP] Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    got my truck back after frame replacement on Saturday.
    Dropped truck off Wednesday afternoon,and was done Friday morning.
    Day after I picked up,took a ride and engaged 4wd to get up my hill.
    No 4wd. I did not have time to call.
    A few days later,today,I got tech on phone that explained the 4wd actuator sometimes freezes up,especially when not used for long periods of time. I explained I use 4wd all the time,all year long.
    Strike 1.
    So I go to pull my truck out to examine actuator,no start.
    Strike 2.
    Called dealer.getting some resistance,but we'll see.
    So... My question is, truck started fine every time before dealer got their hands on it.
    I get the dreaded clicks when trying to crank.
    Battery may be 5 years old,and is showing 11.75 volts at rest.
    Shouldn't the battery be able to crank,and what are your thoughts on the timing? Battery drain?
  2. Aug 27, 2015 at 10:01 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    11.75 is discharged, and even then, voltage at rest tells you very little. Have the battery load tested. Then look into the 4wd issue after.
    DoorDing and Jimmyh like this.
  3. Aug 27, 2015 at 11:28 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    11.75 would be very low at rest. Hold the meter leads on it and have someone attempt to start the truck. I'll bet that the voltage drops to near zero when it loads up. If so at 5 years old I would suspect a worn out battery to begin with, Not the dealers fault or problem. Just a coincidence.
    adanfon and DoorDing like this.
  4. Aug 28, 2015 at 3:58 AM
    Mad Man Marty
    Marty
    PA
    And the 4wd? Coincidence also?
  5. Aug 28, 2015 at 6:35 AM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Maybe, maybe not. I'd start by checking all the connections at the transfer case actuator and ADD actuator, make sure everything is plugged in tight and no corrosion within the plugs. After the starting issue is resolved.
    DoorDing likes this.
  6. Aug 28, 2015 at 9:18 AM
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    I think they turned your 4WD in to a pee runner. I guess the only logical next step is to go LT.
  7. Aug 28, 2015 at 3:51 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    One thing at a time young Padawan.
  8. Aug 28, 2015 at 7:26 PM
    cheech1
    cheech1 Well-Known Member
    Kaneohe, HI
    08 PreRunner Off Road
    I'm almost willing to bet that if you replace your battery, all will be fine. Test it first though, as the truck wasn't run much due to the frame replacement, and could be just a low battery. But after 5 years, most likely you need a new one.
  9. Aug 28, 2015 at 11:04 PM
    Mad Man Marty
    Marty
    PA
    They did the frame in 1 day.
  10. Aug 29, 2015 at 2:42 AM
    cheech1
    Kaneohe, HI
    One day? I just assumed from reading other's experiences that it took weeks. So yes, check ground connections, but my hunch about the battery still stands. 11.75 volts = insufficient.
  11. Aug 29, 2015 at 5:03 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Exactly... I did the same. Battery was perfectly fine with no signs of wear. After 5 years and winter approaching...I got a new one.
  12. Aug 30, 2015 at 2:36 PM
    Mad Man Marty
    Marty
    PA
    Update.
    I trickle charged the battery at 2 amps overnight.
    Volts started at 11.75, was 12.65 after charge.
    Truck started right up.
    After sitting for a day,12.33. Started right up.
    While cranking,10.35.
    Thoughts on the battery,or the discharge rate would be appreciated.
    My concern is no problem before dealer got a hold of it,and now there is a short causing discharge.
  13. Aug 30, 2015 at 3:05 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Hint: The Battery is 5 years old. Well past the normal expected life. It is not the dealers fault no matter how much you would like it to be. Replace it or you will end up stranded somewhere.
    CurtB and DoorDing like this.
  14. Aug 30, 2015 at 4:28 PM
    Mad Man Marty
    Marty
    PA
    Jimmy,I guess I'll have to get one.
    Ding,I have one.
    I just don't believe in coincidence.
    Thanks.
  15. Aug 31, 2015 at 7:34 AM
    Mad Man Marty
    Marty
    PA
    Yes ding. Thank you.
    I also checked for discharge by removing my negative battery cable,set my multimeter to 10 amps DC,touching the meter's positive lead to the disconnected negative cable,& the meter's negative lead to the battery's negative terminal.
    It should not read anything over 50 milliamps.
    If it does you have parasitic draw.
    Mine read .01, so it appears I'm ok.
    After sitting for 2 days,the battery seams to be holding @ 12.33.
    I'm going to let it sit for another 3 and see what it reads then.
    I think the battery was drawing somehow when the techs were working on my truck.
  16. Aug 31, 2015 at 3:33 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    They were jamming with the stereo!
  17. Aug 31, 2015 at 6:19 PM
    Mad Man Marty
    Marty
    PA
    Could be. They didn't have one in the shop!
  18. Sep 18, 2015 at 9:53 PM
    Mad Man Marty
    Marty
    PA
    Well here's the latest.
    Battery is holding charge. They must of drained it when working on it.
    Looked over all wires,connections. All looks good.
    Met with service manager today.
    He said they will make good on looking at 4wd next Wednesday.
    I'll keep u informed.
  19. Sep 19, 2015 at 8:50 AM
    Pigpen
    Northwest Montana
    Access cab toolbox/ dog bed with seats and headrests deleted, waterproof TRD seat covers, yellow wire mod, diff breather relocated to tail light, engine block heater, Leer topper with Yakima tracks and rack, Yakima rack on cab, Ride Rite with Daystar cradles, CBI hidden front hitch, wired for winch front and rear Warn quick connect, Warn x8000i on external carrier, sway bar delete, trailer plug relocated to bumper, Pelfreybilt IFS and Mid skids, ECGS front diff bushing, ARB CKMA12 compressor, 255/85/16 Backcountrry MT 3 load E tires on stock steel rims, Up2NoGood heated mirror kit, Husky X-act Contour front floor liners, Northstar AGM 24F battery, Pelfreybilt bolt on sliders with kickout and top plates, TRD Pro headlights, Depo smoked tail lights, Energy suspension body mount bushing kit, OME Dakar leaf packs with AAL, Billstein B110 rear shocks, OME 90021 front shocks with 885 coils, SPC LR UCAs, Up2NoGood 2wd low range mod, 4 Wheel Campers Grandby slide in camper
    I'd still buy a battery.
  20. Sep 24, 2015 at 5:44 AM
    Mad Man Marty
    Marty
    PA
    Here is the final.
    Took truck back to dealer yesterday.
    It was the front dif actuator.
    They replaced it free of charge.
    I highly recco the dealer,freedom Toyota of Harrisburg,pa.
    They did right by me.
    The truck is tighter & cleaner than when I brought it in.
    By the way,battery is doing fine.
