No start
Discussion in '1st Gen. Tacomas (1995-2004)' started by Arnbwn, Nov 8, 2019.
  1. Nov 8, 2019 at 12:26 PM
    Arnbwn
    Arnbwn [OP] Member
    Arnold
    96 tacoma
    I have a 96 tacoma 2.7 5 speed I was driving from Tennessee to Missouri and stopped for fuel ,filled up and truck will not start .i did notice when trying to start the check engine light no longer comes on with the key I'm getting to spark and no fuel I'm thinking possible pcm any help would be great!!
  2. Nov 8, 2019 at 12:27 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Codes?
  3. Nov 8, 2019 at 12:28 PM
    Arnbwn
    Arnbwn [OP] Member
    Arnold
    96 tacoma
    No codes cannot communicate with pcm I've been checking power and ground but can't find the schematic I'm needing
  4. Nov 8, 2019 at 12:43 PM
    Arnbwn
    Arnbwn [OP] Member
    Arnold
    96 tacoma
    I found the schematic on the pcm I have power and ground so I guess the pcm is bad
  5. Nov 8, 2019 at 12:45 PM
    Arnbwn
    Arnbwn [OP] Member
    Arnold
    96 tacoma
    If anyone has a pcm with part nunber 89661-04190 I would appreciate it
  6. Nov 8, 2019 at 2:25 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard
  7. Nov 8, 2019 at 2:25 PM
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    Welcome and good luck getting this sorted.
  8. Nov 8, 2019 at 2:32 PM
    Arnbwn
    Arnbwn [OP] Member
    Arnold
    96 tacoma
    I'm glad to be on here I believe the pcm is the culprit I'll let you no when I replace it
  9. Nov 8, 2019 at 2:33 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    It's weird that it would just die at a fuel stop.
  10. Nov 8, 2019 at 2:37 PM
    Arnbwn
    Arnbwn [OP] Member
    Arnold
    96 tacoma
    I agree
  11. Nov 8, 2019 at 3:47 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    There's more to diagnosing a bad PCM than that, isn't there? I guess I'm just seeing what's here in the thread, but pulled over for gas and filled up and now truck won't start and you verified juice and ground at the PCM so PCM is bad? I'm not saying it isn't that, I'm just thinking there could be a few other culprits to check before jumping to a bad PCM right?
  12. Nov 8, 2019 at 4:03 PM
    Arnbwn
    Arnbwn [OP] Member
    Arnold
    96 tacoma
    You are correct sorry I'm new to this I checked all the wiring and there is nothing coming from the pcm to anything else no signal at all grounds are all good there's really nothing left to check
  13. Nov 8, 2019 at 4:13 PM
    cruiserguy
    Elijah
    SEKS
    No, I'm not correct man, I just don't want you to spend on a PCM quite yet.
    So just for clarity, you turn the key and hold to start and what happens? Does the engine turn and turn but not fire up? Does the starter just click loud once and then nothing?
  14. Nov 8, 2019 at 4:15 PM
    cruiserguy
    Elijah
    SEKS
    Or maybe I misread, you already checked all of that stuff like fuel pump, etc?
    You double checked fuses, under the hood fuses as well?
  15. Nov 8, 2019 at 5:06 PM
    Arnbwn
    Arnbwn [OP] Member
    Arnold
    96 tacoma
    Yep I checked all fuses engine turns over good but no fuel and no spark thank you for all the input I don't want it to be a pcm but it really looks like it is
    cruiserguy likes this.
  16. Nov 8, 2019 at 5:10 PM
    cruiserguy
    Elijah
    SEKS
    When the knock sensors fail they can cause no start condition. I think same with crank position sensor.
  17. Nov 8, 2019 at 5:13 PM
    Arnbwn
    Arnbwn [OP] Member
    Arnold
    96 tacoma
    I thought the same thing but when you turn the key on the check engine light doesn't come on but the rest of the lights come on so that tells me the pcm is not firing up to do the self check
  18. Nov 8, 2019 at 5:14 PM
    cruiserguy
    Elijah
    SEKS
    Oh I missed that I guess. Gotcha gotcha. Sucks. My bad.
  19. Nov 8, 2019 at 5:15 PM
    Arnbwn
    Arnbwn [OP] Member
    Arnold
    96 tacoma
    No problem I appreciate all the help it only has 306000 miles on it
  20. Nov 8, 2019 at 5:38 PM
    cruiserguy
    Elijah
    SEKS
    Even then, it's just so rare for the ecus to fail. But it does happen
