No Throttle Response Randomly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PLC721, Apr 16, 2013.
  1. Nov 13, 2013 at 6:08 AM
    #181
    PLC721
    PLC721 [OP] Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    How much time should i give myself to replace the fuel pump?
  2. Nov 13, 2013 at 6:27 AM
    #182
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    About three hours, being your first time. Should take a lot less, but good to have extra time.
  3. Nov 13, 2013 at 7:12 AM
    #183
    PLC721
    Patrick
    Chandler, Az
    And the deatschworks is a good one in your opinion?
  4. Nov 13, 2013 at 7:22 AM
    #184
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yes sir.
  5. Nov 13, 2013 at 7:25 AM
    #185
    PLC721
    Patrick
    Chandler, Az
    :cheers:
    Thanks for all the help good sir.
  6. Nov 13, 2013 at 9:13 AM
    #186
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    When you do yours, I wouldn't mind getting in on that. At some point I should install my Walbro in mine to :p
  7. Dec 20, 2013 at 10:05 PM
    #187
    PLC721
    Patrick
    Chandler, Az
    Are the denso up stream 02 sensors from rock auto the best replacement? I'm kind of back to throwing parts at it trying to fix it. Hopefully installing my fuel pump next weekend
  8. Mar 14, 2015 at 7:43 PM
    #188
    Count Coconut
    Count Coconut Active Member
    Len
    Toronto
    2006 TRD Sport
    Softopper Bilstien 5100 (4) Custom add a leaf pack Custom suspension rubbers (front and rear) Custom bed racks Custom roof rack Custom air breathers (5) Water proofed exterior electrical connectors Custom rock sliders Custom bed rail mounts for Hi Jack extreme, shovel, axe Wild Country Roof Top Tent ECGS front differential bushing Custom Overland 4'x8' trailer Onboard video system Modified exhaust (back end only)
    OP, did you ever get that power loss figured out? last post was 2013?
  9. Mar 14, 2015 at 7:58 PM
    #189
    PLC721
    Patrick
    Chandler, Az
    Nope, traded the truck in over it honestly, now the dealer is working on it
  10. Mar 15, 2015 at 6:40 AM
    #190
    Count Coconut
    Len
    Toronto
    2006 TRD Sport
    Sorry to hear that. I will soldier on!!!
  11. Mar 15, 2015 at 8:54 AM
    #191
    PLC721
    Patrick
    Chandler, Az
    What issues are you having?
  12. Mar 16, 2015 at 6:33 AM
    #192
    Count Coconut
    Len
    Toronto
    2006 TRD Sport
    Loss of power when accelerating to get on highway. Feels like I just took my foot off the gas. Happened once a month or so until last Friday. Coming home on the highway cruising at 100-110 Kph it would just cut out for 5-10 sec, or when I would move the gas pedal all the way down or off and back it would go back to normal. I can shift into 4th (automatic) while this is happening and no change occurs. (does not reset) Also the RPM's dont come up like they would if the gas was on.
    This tells me it's not transmission related, or RPM related. I'm thinking it's the Throttle position sensors, or fuel pump.
    I just removed and cleaned my MAF and Throttle body. Both were carboned up, but I lost power a couple times on the way into work again today.
    I have ordered a new UDR fuel pump and filter combo and a new accelerator assembly (pedal) Hope this fix's the issue.
  13. Mar 16, 2015 at 12:35 PM
    #193
    Jrahn0822
    Jrahn0822 Well-Known Member
    Jake
    Iowa
    07 DCLB
    Sounds like fuel pump. Mine did the same thing, got a fuel pump and I was fixed :)
  14. Mar 17, 2015 at 7:36 AM
    #194
    Count Coconut
    Len
    Toronto
    2006 TRD Sport
    Yesterday discovered my break light was on in parking lot when I got back to the truck. Found the break light switch not set properly. Adjusted that (30 seconds) and it looks like the loss of power issue is gone. (so far) I will report back in a few days to make sure. Sucks that I just bought $400 worth of parts though......
  15. Apr 30, 2015 at 6:24 AM
    #195
    clintoniusrex
    clintoniusrex Member
    V6 4x4
    After ten pages of suggestions, did anybody actually try changing the fuel filter and did it solve the problem?
    I have the same problem. I'm in Africa. Truck runs okay around town, but when I'm out on the horrible roads in the country going at any sort of speed for a couple hours, what you describe happens. I have to figure it's because sediment from the horrible gas I've been using the past 1.5 years is getting kicked up and clogging the filter. Does that sound reasonable?
    Does anyone know if I can just clean the fuel filter when I take it out? The part would be hard t come by here. Thanks!
  16. Apr 30, 2015 at 6:59 PM
    #196
    Count Coconut
    Len
    Toronto
    2006 TRD Sport
    It's been a month and it has not happened at all since I readjusted that stupid break light switch! I had just bought $400 worth of parts to throw at this stubbornly refusing to believe you guys that said to check the break switch...... I wish I had listened sooner, it just seemed to silly to be the cause of this.
    Thanks again to all of your help. I will install the external fuel pump and filter unit from URD anyway when I get the time.
  17. Apr 30, 2015 at 7:01 PM
    #197
    Count Coconut
    Len
    Toronto
    2006 TRD Sport
    Highly recommend you look at adjusting the switch. If you are bumping around on roads it's all the easier to have the break pedal wiggle and cause this issue. I didn't believe it.... now I'm happily eating crow. (but driving smoothly while doing it!)
    Jon G likes this.
  18. Dec 21, 2020 at 5:01 AM
    #198
    Jon G
    Jon G Hoarding Tacomas one at a time,
    Jon
    St John's Newfoundland Canada
    02, 04 & 07 Tacoma
    Magnaflow 2.5 Catback Exhaust K&N filter
    Having this problem with my 2007 4.0L
    Has anyone thought of the drive by wire throttle assembly ?
  19. Dec 21, 2020 at 5:03 AM
    #199
    Jon G
    Jon
    02, 04 & 07 Tacoma
