No Throttle Response Randomly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PLC721, Apr 16, 2013.
  1. Apr 16, 2013 at 9:19 PM
    PLC721
    PLC721 [OP] Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Yeah but it did it before i had the pedal cut :(
  2. Apr 16, 2013 at 9:21 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    The recall/reflash makes that happen..in a effort to stop a stuck or wide open throttle. Its the fix for the stuck throttle problem a few years ago. I refuse that recall every time I go to the dealership..
  3. Apr 16, 2013 at 9:21 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    that's odd, stock taco's shouldn't have done that.
  4. Apr 16, 2013 at 9:22 PM
    PLC721
    Patrick
    Chandler, Az
    I really cant pin point it since its so random, but i find myself not even wanting to go on longer trips due to the fact that it will probably happen.
  5. Apr 16, 2013 at 9:26 PM
    MonkeyProof
    SoCal- SGV
    The pedal was cut to create a larger distance from the bottom of the pedal to the floor mat. If was thought that if a owner had aftermarket floor pads the pedal would get stuck on the aftermarket floor mat. The recall consisted of three things..modify the stock pedal, remove and replace with new updated floor mat hooks and a reflash of the ECU as mentioned by rich91710
  6. Apr 16, 2013 at 9:27 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The reflash MAKES it happen.
    Thanks lawyers.
  7. Apr 16, 2013 at 9:29 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    No. The reflash is because of the alleged " Unintended Accelleration Problem " of a few years ago.
    The modified firmware causes this to happen:
    The only way the ECU knows if you press the brake or not is via the brake switch.
    So if you are booking down the freeway and the brake switch vibrates and closes the contacts ( even though you are not pressing the brake pedal ) the ECU gets a momentary signal that says you pressed the brakes and you have the throttle >25% open at the same time the ECU dumps the engine down to idle speed.
    Adjust the brake switch position or replace the switch if it is defective that should correct it.
  8. Apr 16, 2013 at 9:29 PM
    95 taco
    95 taco Battle Born
    ok,i wasn't sure what all the recall consisted of.
    patrick, does this sound like it? http://www.tacomaworld.com/forum/2nd-gen-tacomas/248882-dead-throttle-2011-a.html
  9. Apr 16, 2013 at 9:30 PM
    PLC721
    Patrick
    Chandler, Az
    Okay i feel like that could be it, except that it happened several times before i had the re-flash
  10. Apr 16, 2013 at 9:33 PM
    BradyT88
    BradyT88 Well-Known Member
    The fact that it happened before the reflash means that that is most likely not the problem.
  11. Apr 16, 2013 at 9:37 PM
    PLC721
    Patrick
    Chandler, Az
    You guys thinking more electronic than mechanical?
  12. Apr 16, 2013 at 10:28 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    I've had the pedal chopped and I guess they reflashed at the same time but I've never had that happen???
  13. Apr 16, 2013 at 10:34 PM
    PLC721
    Patrick
    Chandler, Az
    I might pull my throttle body and inspect it. Any tips for things I should look for?
  14. Apr 16, 2013 at 10:46 PM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    About the MAF, I'm almost positive that if it fails, the truck goes into safe mode and runs super rich.
  15. Apr 16, 2013 at 10:50 PM
    #35
    PLC721
    Patrick
    Chandler, Az
    I also noticed I do not have the little white spacers on my MAF
  16. Apr 17, 2013 at 7:48 AM
    #36
    PLC721
    Patrick
    Chandler, Az
    May try replacing brake light switch and start from there
  17. Apr 17, 2013 at 10:34 AM
    #37
    MassAppeal16
    MassAppeal16 Well-Known Member
    Carrollton, KY
    17 TRD MGM DCSB
    This was happening to me when I first bought my truck. The guy I got it from had a programmer on it previously and a CAI and throttle body spacer. Before he sold me the truck he took the CAI and spacer off. The programmer was still set for all of that in there so it would shut my engine down anytime i got over 55mph. I removed it and now it runs like a dream. Not sure this helps at all... but hope it does.
  18. Apr 17, 2013 at 10:35 AM
    #38
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    I have an extra throttle body if ya wana borrow it. I'd need it back eventually. It has about 70k miles on it but it works as far as I know
  19. Apr 17, 2013 at 11:21 AM
    #39
    PLC721
    Patrick
    Chandler, Az
    That would be awesome i will let you know man!
  20. Apr 25, 2013 at 10:13 PM
    #40
    PLC721
    Patrick
    Chandler, Az
