No Throttle Response Randomly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PLC721, Apr 16, 2013.
  1. Apr 25, 2013 at 10:24 PM
    #41
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    True, but there is no "sudden" power loss. And you wont even notice the power losses until you floor it and your only getting like 70-80% power you used to. Thats how the safe mode works.
    Also you'll drink fuel like it's going out of style.
    This very well could be your fix. + It's waaay cheaper then the toyota replacement.
  2. Apr 25, 2013 at 10:27 PM
    #42
    PLC721
    PLC721 [OP] Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    For the first 40k miles of the truck i had a habit of running it til the light was on and then some before filling up. IT only happens when im driving a little on the hard side which could be my fuel pressure isnt keeping up causing my truck to lean out
  3. Apr 25, 2013 at 10:37 PM
    #43
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    All it would take is for you to have filled up from a bad gas station that had broken filters in its pumps and a dirty tank in ground.
    Luck of the draw basically. It's rare but not unheard of, handed to a bunch of vehicles locally here too.
  4. Apr 25, 2013 at 10:39 PM
    #44
    PLC721
    Patrick
    Chandler, Az
    For 155 bucks and a few hours of time I may do it
  5. Apr 25, 2013 at 10:40 PM
    #45
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    + Peace of mind is a wonderful thing. I'd say shoot.
  6. Apr 25, 2013 at 10:41 PM
    #46
    PLC721
    Patrick
    Chandler, Az
    Is there a write up on x-runner underground?
    Did you install it on your X?
  7. Apr 25, 2013 at 10:43 PM
    #47
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Yes & yes.
    Let me find it one sec.
  8. Apr 25, 2013 at 10:48 PM
    #48
    PLC721
    Patrick
    Chandler, Az
    Are you saying with the new pump I'll drink fuel or when the trucks in safe mode?
  9. Apr 25, 2013 at 10:59 PM
    #49
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Do you have an ultra gauge?
  10. Apr 25, 2013 at 11:00 PM
    #50
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    So when the truck cuts power do the RPMs hold steady, drop due to the lost power, or blip higher?
  11. Apr 25, 2013 at 11:01 PM
    #51
    PLC721
    Patrick
    Chandler, Az
    Drop down to idle slightly fluctuating
  12. Apr 25, 2013 at 11:02 PM
    #52
    PLC721
    Patrick
    Chandler, Az
    Scanguage 2
  13. Apr 25, 2013 at 11:03 PM
    #53
    Blackdawg
    Monte
    Wyoming/St. Louis
    Try driving without it a few times. Or for a while.
  14. Apr 25, 2013 at 11:04 PM
    #54
    memario1214
    Colton
    Missoula, MT
    But the truck will remain running and go to low idle then?
  15. Apr 25, 2013 at 11:05 PM
    #55
    PLC721
    Patrick
    Chandler, Az
    Just got it like 3 weeks ago, this has been happening for like 18months at least maybe 2 years actually
  16. Apr 25, 2013 at 11:05 PM
    #56
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    When the truck is in SAFE mode you will drink fuel like a pig. I'd say I was going through easily 50% more fuel.
    You'll know if thats your issue, you'll throw tons of codes and be at the mercy of gas pumps till you get it fixed.
    So i just spend 20 minutes combing through the X-runner Underground website and can't find the damn how-to. But I do know the kit comes with very detailed instructions as I has used them. Also I have a spare full kit laying around in my storage unit somewhere.
  17. Apr 25, 2013 at 11:05 PM
    #57
    PLC721
    Patrick
    Chandler, Az
    Correct, never dies just bogs down and wont accelerate
  18. Apr 25, 2013 at 11:06 PM
    #58
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Heres a 4Runner install I found
  19. Apr 25, 2013 at 11:14 PM
    #59
    memario1214
    Colton
    Missoula, MT
    Don't hold me to it, but I am nearly positive it is your fuel pump. A clogged filter will not allow the pump to maintain proper fuel pressure and you will lose power, especially under hard acceleration. This effect can be accentuated by a low gas tank.
    As for the install, URD provides some pretty good directions. Also, I did just do it 2 days ago (albeit my first time), but I am pretty sure I could walk you through it by memory.
  20. Apr 25, 2013 at 11:16 PM
    #60
    memario1214
    Colton
    Missoula, MT
    And I still have the directions so if I really had to I could put them in a pdf and send them to you... I'm surprised there isn't a pdf of that hangout out somewhere. I might have to change that.
