No Throttle Response Randomly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PLC721, Apr 16, 2013.
  1. Apr 26, 2013 at 7:37 PM
    #101
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Ok. I must have missed that about the functions before and after Maf Cal.
    I don't have any clips for my sensors. As well as none for the 4wd plugs which aren't plugged in. Man I wished you lived closer. This is bugging the crap out of me.
  2. Apr 26, 2013 at 8:26 PM
    #102
    PLC721
    PLC721 [OP] Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    I have a lot of family in Texas :spy:
  3. Apr 26, 2013 at 8:53 PM
    #103
    PLC721
    Patrick
    Chandler, Az
    Also adding to it....my truck always smells like gas while driving...
  4. Apr 26, 2013 at 9:23 PM
    #104
    Super Werty
    Super Werty Sleeper 4x4
    Arizona
    07 TRD Tacoma
    air and fuel
    thats not good. Take some pics of the engine bay...detailed pics....maybe one of us can spot something wrong
  5. Apr 26, 2013 at 9:24 PM
    #105
    PLC721
    Patrick
    Chandler, Az
    Lol trade trucks for a week or so? ;)
    I'll shoot you guys some pics tomorrow
  6. Apr 26, 2013 at 9:58 PM
    #106
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I knew a guy who kept complaining of the faintest gasoline smell. Only after it had been running. Never when off. There ended up being the slightest knick in the #6 cylinder fuel rail injector bung.
    Very hard to find and diagnose. I ended up swapping out a slightly larger O-ring from one of my RC Engineering injectors. Short of replacing the fuel rail, it worked.
  7. Apr 26, 2013 at 10:28 PM
    #107
    PLC721
    Patrick
    Chandler, Az
    Interesting, i appreciate all the helpful information!
  8. Apr 27, 2013 at 4:11 PM
    #108
    PLC721
    Patrick
    Chandler, Az
    Cleaned the throttle body and used MAF Sensor Cleaner on all the connections around the throttle body and maf. Truck has better throttle response forsure!
    Also the o2 sensors for the headers are super dirty, should i spray those connectors off as well?
  9. Apr 27, 2013 at 4:13 PM
    #109
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That is a simple fix and good start! Now the question is, does it fix it? o_O
  10. Apr 27, 2013 at 4:14 PM
    #110
    PLC721
    Patrick
    Chandler, Az
    Time will only tell me friend :)
    Still planning on doing the Urd Fuel Pump kit here soon.
  11. Apr 27, 2013 at 4:18 PM
    #111
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yup. I remember you mentioning that you filter was clean. How long ago had you cleaned it? Prior to this issue.
    Also, not sure if aFe makes a hydrophobic filter for their filters, but if they do, that would be a layer of protection for the filter, against the larger particles, while off-roading in really dusty areas. Which will in turn help keep the other parts cleaner longer.
  12. Apr 27, 2013 at 4:24 PM
    #112
    PLC721
    Patrick
    Chandler, Az
    Well this issue has been happening for 2 years now, literally once every couple of months. I always make sure the filter is clean. I've been thinking about switching to the new style TRD. Yes i know its not as free flowing, but might be better for me offroad?
  13. Apr 27, 2013 at 4:29 PM
    #113
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Don't swap. That is a poor design by K&N. Causes MAF sensor turbulence issues. Just add a pre-filter if you can. Old rally cross trick. Except they used panty hose. Way back in the day before pre-filters.
  14. Apr 27, 2013 at 4:31 PM
    #114
    PLC721
    Patrick
    Chandler, Az
  15. Apr 27, 2013 at 4:37 PM
    #115
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Correct, but the TRD/aFe is a large filter. So it would need to be able to fit over. You would need to take a measurement and find out if there is one that fits.
  16. Apr 27, 2013 at 4:41 PM
    #116
    PLC721
    Patrick
    Chandler, Az
    I'm pretty sure afe makes one, i'll see if i can track one down tomorrow.
    Sdhq Offroad actually has them. sweet lol
  17. Apr 27, 2013 at 4:44 PM
    #117
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If you do. Post it up.
  18. Apr 27, 2013 at 4:45 PM
    #118
    PLC721
    Patrick
    Chandler, Az
  19. Apr 27, 2013 at 4:48 PM
    #119
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Well there you go sir! Lol. Didnt take long at all. Power of the internet. Lol
  20. Apr 27, 2013 at 4:49 PM
    #120
    CASTRATE
    CASTRATE Well-Known Member
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    I '02 cummins would dead pedal at times before I replaced my injection pump. I don't know if that could be an issue on a Tacoma. I don't know squat about gas burners
