No Throttle Response Randomly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PLC721, Apr 16, 2013.
  1. Apr 27, 2013 at 5:31 PM
    #121
    PLC721
    PLC721 [OP] Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Well i have headers and intake, looking into y-pipe and dynomax turbo muffler.
    One day the truck would ideally have a ucon on it :cool:
  2. Apr 29, 2013 at 8:11 AM
    #122
    SDHQ OFFROAD
    SDHQ OFFROAD Cuz Stock Sucks!
    SALES
    Gilbert AZ
    Send me the part # from your filter, or the measurements (height/flange/top cap dia.) ect and ill cross it with AFE to see if we have a pre-filter on the shelf.
  3. May 8, 2013 at 8:44 AM
    #123
    MJ slasher
    MJ slasher Well-Known Member
    MJ
    Dallas, TX (Princeton)
    2012 TX PRO Supercharged
    20% tint all around, Bug Shield, painted (Not dipped) badges, roof rack, step tubes. TRD Supercharger
    My 2012 had the same issue, but it didnt start happening until after I had the brakes checked by Toyota.
    My brakes were really grabby at 16,000 miles, and squealing. Took the truck in, they adjusted the brakes and main brake control arm (Something like that).
    Leaving the dealership, on the highway I lost all throttle for 3 - 5 seconds, engine was still on, but 0 response from pressing the gas. After 3 0r 4 seconds it would recover. This happened several times in the following weeks.
    It had something to do with the brake work done by Toyota, I know it did. I eventually got pissed off and traded that Taco in.
  4. May 8, 2013 at 10:05 AM
    #124
    PLC721
    Patrick
    Chandler, Az
    what did the dealership have to say? I do all my own brake jobs :eek:
  5. Aug 11, 2013 at 9:09 PM
    #125
    PLC721
    Patrick
    Chandler, Az
    For those still subb'd i pulled the plugs, and they all look like this
  6. Aug 12, 2013 at 7:20 AM
    #126
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    How does the engine sound and feel when it bogs?
  7. Aug 12, 2013 at 8:30 AM
    #127
    PLC721
    Patrick
    Chandler, Az
    Like its choking kinda gets a deeper tone
  8. Aug 12, 2013 at 8:41 AM
    #128
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Running super rich. I think that what you have planned, as for upcoming mods, will likely solve your problem.
  9. Aug 12, 2013 at 8:53 AM
    #129
    PLC721
    Patrick
    Chandler, Az
    So maybe scrap the plans for the new fuel pump?
  10. Aug 12, 2013 at 8:55 AM
    #130
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I would still do that as well. Doesn't hurt, and gives you a service-able fuel filter.
    Toyota of America was dumb for taking that out. Fail. Toyota - rest of the world has it.
  11. Aug 12, 2013 at 8:58 AM
    #131
    PLC721
    Patrick
    Chandler, Az
    One last thing I've been reading up on. 02 sensors, could they be signaling that it's running too lean and the maf will richer the mixture to the point of bogging?
  12. Aug 14, 2013 at 12:06 PM
    #132
    PLC721
    Patrick
    Chandler, Az
    Adding a new twist to this as i have been thinking long and hard on the issue, i almost want to think it started after installing the long tube headers or the are intake
    :frusty::frusty::frusty::frusty:
  13. Aug 14, 2013 at 12:18 PM
    #133
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What intake do you have again?
  14. Aug 14, 2013 at 12:18 PM
    #134
    PLC721
    Patrick
    Chandler, Az
    Afe stage 2si
    I had an AEM Prior to that though
  15. Aug 14, 2013 at 12:21 PM
    #135
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    And you have made sure that all hose clamps are properly secured, MAF is in tight and properly?
    That you header to head nuts are tight for no exhaust leaks?
    When are you getting the new fuel pump?
  16. Aug 14, 2013 at 12:22 PM
    #136
    PLC721
    Patrick
    Chandler, Az
    I'll double check the headers tomorrow and also i'll double check the 02 sensor bung i remember that it was a PITA to get the stock wire to plug in
  17. Aug 14, 2013 at 12:24 PM
    #137
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I added an EDIT in my last post too.
  18. Aug 14, 2013 at 12:25 PM
    #138
    PLC721
    Patrick
    Chandler, Az
    After i make my final tuition payment for this semester, maybe friday or next friday
    I was just going to order everything at once lol
  19. Aug 17, 2013 at 8:09 AM
    #139
    BamaToy1997
    Bill
    Navarre, FL
    FYI, most all of the manufacturers have moved to the internal fuel filter. Very few vehicles have them anymore. Toyota, Ford, GM, Chrysler, etc. Sucks, yes, but Toyota wasn't the only one who did it.
    First off, in reference to your PM, don't EVER worry about bothering me with a question. I am more than happy to help as much as I can with any problems. Everyone should feel free to ask for input. That is why many of us are here.
    So you BELIEVE that it MIGHT have started after long tube headers and/or ARE intake? Long tube headers will change the air flow through the exhaust. The question would be if the increased flow is causing fault with the A/F sensor. Here is my professional opinion. You might not like it, but everyone knows I am honest, and don't pull punches here. If you want to try your best to save you money, and only buy what you NEED to buy instead of throwing parts at it, then you have to go back to the basics.
    You need to first reinstall the factory headers. Will this fix it? We don't know obviously, but since you THINK it may have started back then, then the only way to know for sure is work backwards. Perhaps since the ARE intake is easier, swap back to factory intake first and drive it. We need to eliminate any changes that have occurred around the time your problem first came up. Next comes the REAL pain in the but part: Disconnect your battery, then remove and clean EVERY ground under the hood. Faulty electrical grounds are one of the most common intermittent gremlins in modern vehicle performance issues today. Ask any professional technician, and they will say the same thing. Once you have cleaned all the grounds, do the same with the starter cable at the starter, and both of the battery cables. Connect the "+" cable back first, then the "-" cable last. Remember that at this point the ECU will have reset and it may take a few drive cycles to allow the ECU to settle down and learn it's defaults.
    Those are my suggestions to start with, and those would be the exact steps I would take with a vehicle that came into my shop.
  20. Aug 17, 2013 at 9:15 AM
    #140
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
