No tow package, can I still tow trailer??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Atxtoolz, Oct 12, 2010.
  1. Oct 12, 2010 at 7:24 AM
    Atxtoolz
    Atxtoolz [OP] Well-Known Member
    05 PreRunner
    Hello guys I have a 05 double cab prerunner with out tow package, can I just add tow hitch and pull trailer?
  2. Oct 12, 2010 at 7:29 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    As long as you pull what the truck is rated for you will be fine.
  3. Oct 12, 2010 at 7:45 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    yep, I tow with mine using a hitch I put on myself without any issues. You'll need a wiring harness for lights also and a brake controller if your trailer has brakes.
  4. Oct 12, 2010 at 9:18 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    Is there any difference in the truck? I mean.. are the numbers they quote the difference between towing with a bumper ball vs the class III?
    If you install a hitch, you should be good as anything else. Unless its an automatic. Then, well.. be careful if its heavy.
  5. Jun 3, 2014 at 8:26 AM
    taco206
    taco206 Well-Known Member
    Mill Creek, WA
    14 DCSB SR5 PreRunner 2.7L
  6. Jun 3, 2014 at 11:04 AM
    jharkin
    jharkin Well-Known Member
    Jeremy
    Massachusetts
    14 DCSB TRD OR
    12volt/20amp bed outlet access tonneau
    The factory tow package also includes transmission and engine oil coolers - I'm going to take a guess that is the main reason why they allow a higher tow rating.
  7. Jun 3, 2014 at 11:07 AM
    ReidStylez
    ReidStylez Well-Known Member
    Reid
    Kansas City
    11 PreRunner SR5
    They also include wiring for trailer brakes which helps with the higher tow rating.
  8. Jun 3, 2014 at 11:14 AM
    RevoTaco
    RevoTaco Well-Known Member
    SoCal
    Sold - 08 6SP 4x4 AC TRD Off-Road
    http://www.tacomaworld.com/forum/towing/4031-tacoma-towing-bible.html
    Get some popcorn and read away. Everything you need to know.
    But I quoted the tow package differences below for you.
    This “towing package” consists of a class IV receiver hitch, supplemental engine oil cooler, transmission cooler (again automatic transmission only), Heavy-Duty battery, 130 amp alternator, fully functional 7-way round plug, and a plug and play brake controller pigtail.
  9. Jun 3, 2014 at 11:20 AM
    txmxer
    txmxer Well-Known Member
    California and Texas
    06 dc tacoma
    - Total Chaos 3.5 Long travel kit - Fox 2.5 coilovers w/ resis -Prerunner bumper -Fiberglass front fenders -Fiberwerx tt bedsides - Dmz Sua - fox 2.5x16 triple bypasses
    Our tacoma came without a tow package and we had a hitch added, as well as transmission and engine oil coolers and helper bags for what we were towing. Had no problems towing our trailer.
  10. Jun 4, 2014 at 6:19 AM
    ReidStylez
    Reid
    Kansas City
    11 PreRunner SR5
    Did you use factory oil cooler and transmission cooler? How much did it cost?
  11. Jun 4, 2014 at 6:30 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    the bumper is only rated for 3500 LBS where with factory tow package it’s rated at 6500lbs. the bumper is not as strong as a class 3 hitch.(the metal of the bumper it self is not as strong or thick as whats used for a hitch.)
    also WITH the factory tow package it add’s bugger battery, bigger alternator, larger oil cooler and a trans cooler. also pre wired for a brake controller so all you have to do is buy one and plug it in. there is a plug under the driver side lower dash some where i don’t know exact location.
  12. Jun 5, 2014 at 6:41 AM
    ReidStylez
    Reid
    Kansas City
    11 PreRunner SR5
    The only thing I'd really be worried about if you don't have the tow package but you do have the class III hitch setup is that you won't have a transmission and oil cooler to help for longer pulls and trailer brakes. If you're going to pull something heavy short distances then it wouldn't really be a huge issue as long as you don't pull up long hills at high speeds or stress it too much.
  13. Apr 14, 2018 at 4:48 PM
    nobescare
    nobescare Well-Known Member
    Mark
    43.5448° N, 80.2482° W
    2019 Highlander SE
    My 2005 prerunner had frame failure Aug 2024
    i know this is an old forum but i'm with the same vehicle. prerunner, automatic, 4.0l engine, 2WD, no tow pkg., with GVWR of 52350 lbs. i have the class iv hitch and have a brake controller and am getting the 7pin wiring assembly installed. plan on renting a Coleman Travel Trailer at 3100 lb. the towing bible is great but there's no consistency. i'm calculating i'm good to tow this. if all goes well i'd probably buy a used TT with a weight of around 3500 lb. looking for comments, opinions etc.
