No TPMS on Spare?
Discussion in 'Wheels & Tires' started by NOVA DC, Oct 22, 2010.
  1. Oct 22, 2010 at 3:50 PM
    NOVA DC
    NOVA DC [OP] Member
    Northern VA
    2011 DC SB 4X4
    Access LE, Step Rails, bed divider, Pop & Lock
    I just purchased a 2011 MG 4X4 DC. According to the Users Manual, you're not suppose to rotate it out when rotating the tires. I'm assuming that this is because it doesn't have a TPMS sensor. Is this correct? I was thinking about installing the sensor in the spare and using it in a five tire rotation. Doesn't seem to make sense to just let the spare age out. Is there a reason I can't do this?
    Thanks
  2. Oct 22, 2010 at 3:59 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Why would you want to rotate a spare tire in? I was always under the impression that my spare tire is just that, a spare..
  3. Oct 22, 2010 at 4:04 PM
    NOVA DC
    NOVA DC [OP] Member
    Northern VA
    2011 DC SB 4X4
    It should be a full size spare with same rims. So it should be an exact replica of the four tires touching the road. If I rotate the spare out, then all 5 tires get even wear. If it just sits as a spare, the rubber will degrade with time. I can get better use out of the tire if I can use it.
  4. Oct 22, 2010 at 4:06 PM
    08pretaco
    az
    my spare was not on a rim that was the same as the rest...mines spares on a shitty black rim...then again I have the cheapest 6 lug Toyota makes
  5. Oct 22, 2010 at 4:11 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Can't think of a reason you'd want to rotate the spare in but you certainly can. It's a full size spare but mine didn't match the other wheels asthetically. But, to answer your question, there IS a TPMS sensor on the spare.
  6. Oct 22, 2010 at 4:11 PM
    NOVA DC
    NOVA DC [OP] Member
    Northern VA
    2011 DC SB 4X4
    I haven't looked under there yet. I should check. I have the SR5 with upgraded rims. I'll be disappointed if it's not the same tire and rim as the others.
  7. Oct 22, 2010 at 4:13 PM
    Pugga
    Massachusetts
    It'll be the same tire (at least that was the case on mine) but the rim didn't match. I got alloy rims, the spare was steel.
  8. Oct 22, 2010 at 4:25 PM
    NOVA DC
    NOVA DC [OP] Member
    Northern VA
    2011 DC SB 4X4
    Well, if that's the case, it makes no sense rotating it out. My reason for wanting to rotate the spare out is due to experience where I rarely have had to use the spare. If the spare is more than 5 or so years old, it's not safe to run them full time
    Thanks everyone. I'll take a look at the spare tomorrow.
  9. Oct 22, 2010 at 4:28 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    Your spare tire will be a black steel wheel, it has NO TPMS in it. Earlier models came with an alloy wheel and TPMS, but that has since been phased out.
  10. Oct 22, 2010 at 4:32 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    right to all above...should be a standard black steel wheel and no TPMS in the spares from 09+
  11. Oct 22, 2010 at 4:33 PM
    Pugga
    Massachusetts
    Damn man, when did they phase that out??? The spare is the one tire that stupid system actually makes sense to be monitoring! Sorry OP, I wasn't aware they phased out a good idea...:eek:
  12. Oct 22, 2010 at 4:35 PM
    Bryan07sport
    Bryan07sport Well-Known Member
    Bryan
    Smyrna, Delaware
    '22 TRD off-road.
    Bilstein 6112/5100. Icon progressive AAL. Overland Torque Tune. Toyota roof rack. Toyota bed extender. Gator trifold tonneau. Bora .75" wheel spacers. 265/75r16 tires.
    Interesting... yeah mine's definitely a ugly utilitarian steel wheel, full size rim and tire, but does have the tpms in it. I don't know why they'd phase that out. I think that is the most important part of the tpms for me. I can look straight at the other 4 tires and see, but if the spare is flat and I need it I'm SOL. I like the fact that once a year or so my light comes on reminding me to add a little air to the spare...
  13. Oct 22, 2010 at 4:35 PM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Plus the spare is a PITA to get out with that crappy crank assembly that toyota threw under our trucks. I wouldn't want to drag the spare out every 5000 miles.
    BTW welcome to tw from one NOVA resident to another!
  14. Oct 22, 2010 at 4:37 PM
    Bryan07sport
    Bryan
    Smyrna, Delaware
    '22 TRD off-road.
    Beat me to it...
  15. Oct 22, 2010 at 4:41 PM
    Pugga
    Massachusetts
    Yeah, that surprised the hell out of me to hear they phased it out! It's the only one you can't see and would completely suck if it went flat when you finally do need it! It's a friendly reminder to take it out, air it up and I usually clean it up while it's off the truck (I live in NE and it accumulates quite a bit of sand/salt).
  16. Oct 22, 2010 at 4:55 PM
    spp
    spp OC, Kalifornia
    OC California
    They discontinued the Spare TPMS in 2009 thank goodness.
    The owners manual now refers to the spare as a temporary spare as there is no TPMS.
    Just legal CYA by Toyota.
  17. Oct 22, 2010 at 4:55 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    That is a good reminder :thumbsup:
    My 95 toyota the chain/cable had to get cut off even with the best of maintenance...after about 10 winters that system rusted up pretty good. The spare rode in the bed for the rest of its life....
    Also my spare sensor (I have a 06) always likes to go off in winter on the coldest day .. murphys law :rolleyes:
  18. Oct 22, 2010 at 4:58 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    x2^^^^^^^^^^^
  19. Oct 22, 2010 at 5:11 PM
    NOVA DC
    NOVA DC [OP] Member
    Northern VA
    2011 DC SB 4X4
    Thanks for the welcome. I'm in Herndon.
    So the consensus here that the '11 spare doesn't come with TPMS and is mounted on the standard Steel Rim. Must just be another cost saving major.
    My last truck was a 01 Dakota 4X4 and it had the same rim and tire as the rest of the original equipment. No TPMS during that era, though. Now I have two cars with no spare tire at all, just run flats on one and a repair kit on the other. At least the Tacoma has a full size spare.
  20. Oct 22, 2010 at 5:13 PM
    08pretaco
    az
    If you really want to see for yourself if the tire is on a rim like the rest of the 4 are....go take a peak!
