No valve clearance checkups needed for 2TR-FE can someone confirm?
Discussion in 'Technical Chat' started by cycledrum, Jan 28, 2008.
  1. Jan 28, 2008 at 7:41 AM
    cycledrum
    cycledrum [OP] Well-Known Member
    Union City, CA
    88 4X4 Pickup xtra cab, SR5
    The 60k, 90k, 120k mile service chart for 2005+ Tacoma's (at www.smg.toyotapartsandservice.com
    - valve clearance inspection required except for 2TR-FE motor (not required!?)
    Can any tech gurus confirm and say why. I thought the 2.7L was a DOHC shim under bucket that requires the clearance checkups.
    I don't have a Tacoma, but doing research. This would be really cool as valve clearance inspections / adjustments are pricey (And I'll bet most shops and owners skip right over them).
    So, the 4L V6 does call for valve clearance inspections at 60k, 120k ...
    more pricey than just extra initial cost and fuel burn!
  2. Jan 28, 2008 at 7:42 AM
    cycledrum
    Union City, CA
    sorry link above doesn't work. type it in it should.
  3. Jan 28, 2008 at 9:39 AM
    cycledrum
    Union City, CA
    Hi Phantom,
    I have an '88 Toyota Pickup 4WD, 4 cyl, 5spd, xtra cab, with larger wheels/tires (came that way). Main complaints are -
    * tired of shifting (I get that fix on my motorcycle)
    * Certifiably underpowered (this thing can't do over 55 mph up a decent freeway grade, no passengers, no cargo), it's just flat out underpowered.
    I drive mostly in the suburbs, paved roads, sometimes tote a dirt bike, street bike, bicycle, so ...
    a 4 cylinder, automatic, 2WD should fit the bill just fine.
    I think I'm ok with the 5 lug, 15in. wheels/ 215/70-15 tires, but wow they appear a little small on the Gen 2 Taco automatic 4 cyl, Access.
    I see you can get the 16 in 245 tires on the 4 cyl access cab, but only on the manual transmission ... ah darn.
  4. Jan 28, 2008 at 9:42 AM
    cycledrum
    Union City, CA
    any rate, a Toyota tech confirmed the 2.7L 2TR-FE motor has hydraulic lifters, so no expensive valve clearance checks needed. Seems a good thing.
  5. Jan 28, 2008 at 10:02 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    The new Tacoma's have 59 more horsepower then that old '88 4 cylinder had. Between that and having the proper sized tires (I should duck at this point) you'll probably be more than satisfied with the performance of the 2.7/auto. Happy shopping!
