Noico / Dynamat / Sound Deadening material application
Discussion in 'Audio & Video' started by Cardsallday13, Feb 23, 2019.
  1. Feb 27, 2019 at 5:08 PM
    pdxmonkeyboy
    pdxmonkeyboy Well-Known Member
    2019 TRD OR, Cement access cab
    I'm going to do mine and post some Db meter readings before and after.
  2. Feb 27, 2019 at 5:29 PM
    Cardsallday13
    Cardsallday13 [OP] Well-Known Member
    2017 DCSB TRD Sport 4x4
    Just the doors?
  3. Feb 27, 2019 at 9:33 PM
    pdxmonkeyboy
    Doors, floor, entire back wall, and if I can find decent instructions to get the headliner down, the roof.
    I have very acute hearing and the truck is pretty noisy. A great deal is coming from the back panel and access door.
  4. Feb 28, 2019 at 4:23 AM
    Cardsallday13
    yea that's what i hear too. a lot of noise coming from behind the back seat
  5. Feb 28, 2019 at 4:24 AM
    Cardsallday13
    what does the noico under the speaker give you? reduced vibration?
  6. Feb 28, 2019 at 5:48 AM
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    In doing some research, hitting that area will reduce vibration and helps with midrange as that frequency is commonly the resonant frequency for a sheer metal panel.
    If you are not going to do the whole door I’d hit at least the area around the speaker hole. That area is just thin sheet metal and it’s even more compromised by cutting a hole in it for the speaker. The speaker is going to transmit its vibrations to it, even more so with a better quality one. I know Dynamat sells speaker kits specifically for that purpose.
  7. Feb 28, 2019 at 5:50 AM
    Cardsallday13
    Thanks. I though about getting around the speaker and then the area just behind the speaker.
  8. Feb 28, 2019 at 6:11 AM
    Cardsallday13
    Are they same clips as in the door?
  9. Feb 28, 2019 at 8:00 AM
    pdxmonkeyboy
    honestly, if you have the door skin off you might as well do the whole door. Everytime you close the door you will be impressed.
    it's a BIG difference.
    xxTacocaTxx likes this.
  10. Feb 28, 2019 at 8:47 AM
    avi8or_co
    ^^^^^.....that. From “clang” to “Thunk!”. Sounds like a bank vault closing inside, you feel it in your chest and like a pressure (almost ear pop) in your ears
  11. Mar 1, 2019 at 6:34 AM
    Cardsallday13
    would scissors work on the glue? I had a really hard time getting the glue to come apart. could also be because it was cold too
  12. Mar 1, 2019 at 6:37 AM
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    hemitruk likes this.
  13. Mar 1, 2019 at 7:56 AM
    pdxmonkeyboy
    in regards to getting through the glue.. a hair dryer would work wonders.
    also.. although not ready applicable here.. one trick I almost always use to get things unstuck with adhesive (emblems, adhesive gadgets, etc) is DENTAL FLOSS! get a nice long piece, string it around both hands and saw through the adhesive.
    cheers.
    Manfred likes this.
  14. Mar 1, 2019 at 11:56 AM
    avi8or_co
    I used a box cutter/razor blade but I don’t see why scissors wouldn’t. Warming it up a bit would help. Mine was pretty much open door garage temperature (70s in Florida). Hit the glue with a hair dryer and then pull at a corner, it will stretch like you’re pulling gum from the bottom of your shoe. Once you get it started cut as you pull. Some will be on the plastic, some will stay on the panel. Then later I’d heat it back up when your done and press it in place.
  15. Mar 1, 2019 at 12:25 PM
    #35
    Cardsallday13
    Thanks.
  16. Mar 1, 2019 at 7:43 PM
    #36
    Cardsallday13
    Did the back door tonight and already a difference at high speeds
  17. Mar 2, 2019 at 5:11 AM
    #37
    suppra87
    suppra87 Well-Known Member
    Tim
    MD
    15' Black DCSB TRD OR
    I went overboard on the Noico 80mil when I did the back wall and floor of my truck. I put it in the doors too, but more along the ideal 20-30% coverage for this material. Admittedly, I began reading more about the material AFTER I applied most of it hahaha. I also applied Mass Loaded Vinyl to the entire floor. Later I went back and put the MLV on the back wall and door panels. Ill admit its not Lexus quiet but mitigates the majority of the hum from my tires. I did the same to my previous 3rd gen 4runner, well worth the time and effort involved.
  18. Mar 2, 2019 at 11:59 AM
    #38
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Thinking about doing the roof and floor . So doing the floor first before roof would have better results ? Not wanting to do both at same time .
    Edit
    Already did all doors (fatmat) in and out and ensolite on inside of doors
  19. Mar 20, 2019 at 6:42 AM
    #39
    Cardsallday13
    did you have to remove the seats to get it off?
  20. Mar 20, 2019 at 8:38 AM
    #40
    xxTacocaTxx
    xxTacocaTxx Well Unknown Member
    Best Slope CO
    2017 TRD OR DCLB 4x4 OMGWTFLOLBBQ
    RCI skid plates Mobtown sliders Lots of patches and MESO stuff
    That is almost exactly what mine looks like. Tried to cover as much of the outer panel as I could, and as much of the inner panel as I could without covering the factory holes for screw/plugs/whatnot. Road noise is much less, and the doors make a solid, deep sound when closing.
