noise after removing 2nd charcoal air filter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by decrowe, Oct 5, 2009.
  1. Oct 5, 2009 at 10:10 AM
    decrowe
    decrowe [OP] Member
    dcinwyo
    casper, wy
    2007 tacoma dblcab long box
    air bags on the rear
    New to the forum, but have loved it so far.... did the map light, fog light, dtrl, and turn signal mods the last two days. Great stuff... now to the next issue.......
    Removed the secondary charcoal air filter yesterday, now I have a wierd noise, almost like the air filter is gone..... kinda of whumfp sound, not all the time, just occassional at about 1500rpm and right after start up. Has any one else had this happen? Did I knock a vaccum line off? Thanks for any help.
  2. Oct 5, 2009 at 10:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welcome to TW!
    Sorry to hear you removed the charcoal filter.
  3. Oct 5, 2009 at 10:33 AM
    decrowe
    decrowe [OP] Member
    dcinwyo
    casper, wy
    Thanks, great forum. Why are you sorry that I removed the charcoal filter?
  4. Oct 5, 2009 at 10:36 AM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    It does not do anything.
  5. Oct 5, 2009 at 10:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What he said ^^^
  6. Oct 5, 2009 at 10:54 AM
    decrowe
    decrowe [OP] Member
    dcinwyo
    casper, wy
    It does not do any thing by removing it??? or it does not do anything any by leaving it? or both???
  7. Oct 5, 2009 at 11:01 AM
    PR45
    PR45 Well-Known Member
    Los Angeles
    PreRunner SR5 4cyl
    That's intake noise, probably. I have not looked at the whole filter/box thing yet. I read the threads and claims about removing it. It does not seem worthwhile based on what I've seen.
    My primary concern when dealing with ANYTHING to do with the evap system is gasoline fumes. If removing this screen/filter allows gas fumes into the airfilter box and subsequently outside of that, you could be hearing a "fwuuump" followed by a fire.
  8. Oct 5, 2009 at 11:15 AM
    decrowe
    decrowe [OP] Member
    dcinwyo
    casper, wy
    Ya, i can understand that. it only does at about 1500rpm low to moderate accelation, if i stomp it, it does not make the sound? I will give it a few days, I can always put it back in.
  9. Oct 5, 2009 at 11:30 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Both. Taking it out doesnt hurt anything that I can tell.
