noise behind passenger side airbag
Discussion in '2nd Gen. Tacomas (2005-2015)' started by meh129, Dec 4, 2011.
  1. Dec 4, 2011 at 1:33 PM
    meh129
    meh129 [OP] Member
    Houston
    10 PreRunner SR5
    I have a 2010 Tacoma and have what sounds like a nut that has come and moves back and forth, left or right, it moves when i accerate, brake or turn left or right. The sound is either in the vents or by the passenger side air bag.
    I have remove the glove box, radio and even the fan but cant find what it is.
    If it is in the vent would the object fall into the fan?
    I search the threads but none seem to describe what I am hearing.
    Any suggestions would be helpful.
  2. Dec 4, 2011 at 1:37 PM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total Chaos 3.5 Long travel, Defined SUA
    i know the Tacomas have a rattle in the air box under the hood which is on that side and sounds like a rattle when idling or accelerating
  3. Dec 4, 2011 at 1:37 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
  4. Dec 4, 2011 at 3:43 PM
    meh129
    meh129 [OP] Member
    Houston
    10 PreRunner SR5
    Pull fan and it is not loose and spin quietly. also the noise doesnt happen when idle.
    Sounds like a marble rolling around over a wash board.
  5. Dec 4, 2011 at 6:38 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    I thought it was the airbag assembly on my truck but eventually tracked it down to the wiring harness' plastic collar in the firewall. The fix is to put a thick piece of stiff adhesive foam (about 3/4" thick) onto a steel brace (it's next to the blower fan) to put downward pressure on the harness, thereby putting a bit of pressure onto that noisy plastic collar.
    Toyota has a TSB for it (TSB-0106-10) if you don't have foam. Mine was just some kind of 3/8" windowstripping and I doubled it up. No idea how that combination of parts sounded entirely metallic but my dash has been silent as a mouse ever since.
    If your rattle is what I was experiencing it's worst around 1600 rpm, although it occurred during a much wider range of engine speeds. Drove me insane.
