Noise Coming from driver side in 4wd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hassman, Dec 1, 2014.
  1. Dec 1, 2014 at 3:35 PM
    Hassman
    Hassman [OP] New Member
    Calgary AB
    2011 Tacoma TRD
    6" Pro Comp Lift w/King Remote Reservoir Suspension, Flow Master Exhaust, K&N Cold Air
    I Have a 2011 Tacoma With 6" lift.
    I am having an issue with my truck when it is in 4wd when I let off the gas pedal at 40-100km+ it sounds like there is a growling or grinding under the drivers side and some vibration, when I put the pedal down it goes away and when in 2wd there is no noise at all. the problem is much louder when it is -20°C or colder.
    what could be the possible problem I am having, has anyone else had similar issues?
    Thanks!
  2. Dec 1, 2014 at 3:44 PM
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Needle bearing?
