Noise from front end while turning in 4x4
Discussion in 'North East' started by Skell, Aug 28, 2017.
  1. Aug 28, 2017 at 1:31 PM
    Skell
    Skell [OP] KORE
    Tony
    NE PA
    2015 DCSB, grey
    custom car grill, KORE sliders, light bar, KORE bed bars w/ tire and high lift mount. MOBTOWN front IFS skid.
    15 double cab short bed 4x4 sr5. 40k miles . Only in 4x4, only after turning in one direction for a bit. Makes a clicking that increases in frequency if the wheel isn't not straightened. This is on low traction, off roading conditions.
    Any suggestions where to look?
  2. Aug 28, 2017 at 1:40 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Look for a torn CV boot and grease. It sounds like all your grease has been spun out.
    Stop making sharp turns in 4WD and you can drive a long time before it fails.
    Mine was dry for 275000 miles. It clicked the whole time while turning in 4WD. I intended to change it when it failed. It never did.
  3. Aug 28, 2017 at 1:42 PM
    Skell
    Skell [OP] KORE
    Tony
    NE PA
    2015 DCSB, grey
    I can have it in 4x4 and crank the wheel and it doesn't start making noise immediately, only after i've gone a few feet, as soon as I straighten the wheel, it stops.
  4. Aug 28, 2017 at 1:57 PM
    koditten
    Kirk
    Central Michigan
    Take quick look under the truck, then go from there.
  5. Aug 28, 2017 at 2:31 PM
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Sorry to hear about your troubles... Not mechanically inclined enough to give over the interwebs diagnosis.
    JDAM likes this.
  6. Aug 28, 2017 at 2:33 PM
    eon_blue
    eon_blue Most Improved Member
    Any excessive play in the CV axles when you grab them by hand?
  7. Aug 28, 2017 at 5:50 PM
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Were you able to check it out?
  8. Aug 29, 2017 at 4:44 PM
    Braves95
    Braves95 Go Clemson Tigers
    David
    Central PA
    17 MGM TRD Off Road DCSB P&T 6MT
    Fab Fours Bumper Block Heater Dual Exhaust Flow Master Smittybilt 12k Winch Synthetic Rope Bed Mat Roof Rack Puddle Lights 17" Rockstar Wheels NittoTerra Grapplers Power TailGate Lock Tonneau Cover w/lights Mobtown sliders MT Remote Start Tinted Windows Front And Rear Camera BRC Competition Diff Breather Bed Step Weather tech Floor Mats TRD Pro Tail lights TRD MT Shift Knob ARB dual compressor URD short shifter Kings 2.5 OEM W/remote resi. Click adjuster.
    Yeah. Did u get it figured out?
