Noise in Reverse
Discussion in '1st Gen. Tacomas (1995-2004)' started by Albinator, Jun 5, 2016.
  1. Jun 5, 2016 at 11:38 AM
    Albinator
    Albinator [OP] Well-Known Member
    Utah
    2000 Tacoma 2.7 Manual SR5 4x4; Manual Hub
    Hi all. I noticed a noise when backing up and decided to see if any of you might know what it is?
    You can barely hear it when the truck is in gear going forward and can definitely hear it when it's in reverse. It only makes the noise when in gear and the clutch is engaged.
  2. Jun 5, 2016 at 11:54 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Throw out bearing? They start to squeal when they go bad
    Kolter45 likes this.
  3. Jun 5, 2016 at 11:55 AM
    eon_blue
    Azusa, CA
    Its a cheap part but you have to drop the trans to replace it, might as well put in a new clutch while you're at it if that turns out to be the issue.
  4. Jun 5, 2016 at 12:01 PM
    04rktaco
    04rktaco Well-Known Member
    Lee
    California City, Ca.
    '04 4x4 xtra cab 4x4 TRD. 2014 Tundra crewmax TRD 4x4
    All Pro UCAs King coil-overs All Pro rear springs Modified All Pro Bumpers. Home made skids and sliders. Lefty 4.7 transfer case. Stock e locker rear stock 4:10's Tundra Brakes 285/75/16 Falcon Wildpeak AT3W stock wheels with 1.25 spacers BAMF lca skids. 2014 Tundra crewmax TRD 4x4 5.7 v-8 with leather interior. RCI Metalworks full set aluminum skidplates All Pro rock sliders
    Check your center support bearing on the rear driveshaft. The rubber could be so distorted that's it's rubbing on the driveshaft or the bearing has broke loose and is turning in the rubber.
  5. Jun 7, 2016 at 8:34 AM
    Albinator
    Utah
    Right now I'm going to rule out the throw out bearing for now since all research I'm doing shows that being the problem when the clutch is engaged, but this is happening when it is being disengaged. I will check the center support bearing. Is that also the carrier bearing?
  6. Jun 7, 2016 at 9:05 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Dry u-joints? Likely need to be lubed anyway.
    Something coming into contact with the driveline? Gas tank skid ?
  7. Jun 7, 2016 at 9:12 AM
    Albinator
    Utah
    Here is me checking the carrier bearing. Could this be the noise?
  8. Jun 7, 2016 at 9:19 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    its supposed to have some play as its got a rubber bushing in there but if the bushing is tore up or cracked it needs replaced. Hard to tell if the bearing is bad unless you lift the rear end off the ground and rotate the driveshaft. Even then it might not be noticeable. center bearing usually cause a noticeable vibration at driving speeds. Id go with greasing the ujoints if possible if they dont have zerks then most likely you need to replace the u-joints.
  9. Jun 8, 2016 at 7:40 PM
    Albinator
    Utah
    No zerks...I hand tested all of the u joints and there's really no play in them.
  10. Jun 10, 2016 at 8:29 PM
    Albinator
    Utah
    Any other thoughts with the two videos I posted?
  11. Jun 11, 2016 at 7:00 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    My vote is u joint.
    If you think its carrier bearing just spray some penetrating lube on both sides of it which should temporarily stop it from squeaking.
  12. Jun 21, 2016 at 1:02 PM
    Taco Man in HD
    Taco Man in HD DC TRD MallRunner
    Ohio
    2004 DC Tacoma PreRunner
    Methods, Red Labels, and other bro stuff.
    OP, did you ever get this one resolved? I have the same squeak in reverse and am trying to determine if it's the cardan joint or the carrier bearing.
  13. Jun 21, 2016 at 1:57 PM
    oldschoolbmx
    oldschoolbmx Well-Known Member
    Harry
    02' Tacoma TRD, 14' T4R SR5, 17' Tundra CM Ltd
    Magnaflow cat-back, K&N, B&M short shifter
    Mine made that same noise. Wasn't sure if it was the u-joints or center bearing so I did all of them. Took care of it. The u-joint at the rear was toast, fyi. Front one seemed ok but I replaced it since I had the drive shaft out.
  14. Jun 24, 2016 at 1:04 PM
    Albinator
    Utah
    I have not figured out the noise yet. I plan on trying to use penetrating oil in the carrier bearing as it was mentioned on here or get my ujoints greased up to see if that does anything. What gave you the idea with it being a cardan joint vs a u joint? I ask because I didn't think of that one.
  15. Jun 24, 2016 at 1:45 PM
    Taco Man in HD
    Ohio
    I took my rear driveshaft out to replace the rear-most u-joint to see if that would fix it (it didn't) and the cardan joint seemed to squeak when I moved it around. This thread has more info on trying to service it, but I haven't tried anything other than greasing the driveshaft zerks and pb blaster around the carrier bearing.
    Just dealing with the squeaks for now, haha.
  16. Jun 24, 2016 at 1:47 PM
    tan4x4
    Rick
    Folsom, CA
    So ..... after many suggestion over 3 weeks, you've done nothing ??? :rolleyes:
    Doing, not talking, gets things done.
    PROseur likes this.
  17. Jul 7, 2016 at 1:22 PM
    Albinator
    Utah
    My father-in-law wants to troubleshoot it with me. He left soon after I posted this and gets back this weekend so hopefully sometime between now and next week we can figure out what's going on. Plus, a newborn and two other kids takes some time out of your schedule.
  18. Jul 7, 2016 at 7:00 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    There should be zerks on those ujoints...
  19. Jul 8, 2016 at 5:02 AM
    Taco Man in HD
    Ohio
    Just to update, I resolved my squeaking in reverse issues by rebuilding the double-cardan joint using this thread. Much harder than any normal u-joint replacement, even with the proper tools.
  20. Jul 9, 2016 at 12:33 PM
    Albinator
    Utah
    Awesome man glad to hear! That seems like a beast of a job...I just finished some troubleshooting and the sound is coming from the rear ujoint area but the ujoint is solid (no wiggle). We were thinking it could be we need to grease the zerks or a bearing in the differential could be going or needs a change of the rear diff fluid? Not sure...
