Noise question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Forestryguy, Jul 31, 2024.
  1. Jul 31, 2024 at 4:53 PM
    Forestryguy
    Forestryguy [OP] Well-Known Member
    2022 SR5 Access Cab 4x4
    My truck with 17,000 miles has recently began making a valve rattle/ diesel engine noise while accelerating usually around 35-45mph or so that last a few seconds. It doesn’t do it every time but pretty consistent. It seems to have started a couple months ago. I know these 3.5 are noisy but any ideas what this could be and if normal? Thanks
  2. Jul 31, 2024 at 4:54 PM
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    Could be the Atkinson cycle
    RIX TUX likes this.
  3. Jul 31, 2024 at 5:06 PM
    Forestryguy
    I wondered about that. It’s always been noisy while idling and I assumed that was the Atkinson cycle just not sure why I’m just now noticing this noise while driving
  4. Jul 31, 2024 at 5:43 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Try a tank of premium gas.
    If you shift down a gear does the noise go away?
  5. Jul 31, 2024 at 5:52 PM
    Forestryguy
    It usually only last a few seconds then goes away while under a load, slight hill or accelerating. I thought about premium gas but I don’t hear a lot about others on here having to use premium so not sure why mine would need it. I may try that just to eliminate that.
  6. Jul 31, 2024 at 6:24 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    The 3.5 V6 has 11.8.1 compression ratio so it loves premium.
  7. Jul 31, 2024 at 6:36 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    The stated conditions sound exactly when knock would appear.
    (spark knock, octane knock, ping - folks call it different things)
    Try a tank or 2 of premium from a national chain: Mobil, Exxon, Valero, Sunoco, etc.
    Agree, these are very high compression engines, the computer is what allows running 87 octane without knock.
    Also, every now and then you have an engine that "doesn't like" brand A fuel but runs fine on brand B of the same octane. :notsure: Not scientific but it does seem to happen occasionally.
  8. Aug 1, 2024 at 4:29 AM
    Forestryguy
    Is there any damage that can occur by allowing this rattling/ping to continue?
  9. Aug 1, 2024 at 4:42 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    Since the truck is still under warranty I would stop by the dealership service center and have them check it out and document it.
    Chew and Forestryguy[OP] like this.
  10. Aug 1, 2024 at 9:15 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Spark knock has no good side effects, only bad - in extreme cases it can burn/melt pistons. :eek:
    As stated previously this is a very high compression engine, usually the engine management system "hears" the knock and adjusts fuel & ignition to prevent it.
    So there is the underlying question: why isn't the computer doing what is required?
    Try a few tanks of premium fuel from a different national brand and see what happens.
    t0p_d0g likes this.
  11. Aug 1, 2024 at 9:25 AM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    I concur with a name-brand gas. Could be my pea-brain playing games with me but I swear Chevron gas seems to run
    better in the Truck than Costco .... seems to get better gas mileage and more umph as well. I stay away from 7-11 type
    stuff from now on it's either Chevron or Shell. In fact it's on my to-do list to pump some in today. First of the month, all
    bills are paid, credit-card balances are zero - my license to fill it up. I don't run premium just the 87 stuff.
    Run a tank or two and see if it behaves better.
    Forestryguy[OP] and t0p_d0g like this.
  12. Aug 1, 2024 at 7:35 PM
    099 Well-Known Member
    2022 White Tacoma Double Cab SR5
    I run Shell 93 all the time in my 22 SR5. People here say otherwise but I have no transmission studder, quick acceleration and better gas milage. In my defense, it's stock 2wd with stock 245 tires and no hills where I live.
  13. Aug 1, 2024 at 7:53 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    OP, if you decide to use 93 octane it will take the second tank before you get the full effect. The computer has to adjust fuel air mixture and ignition timing for the higher octane fuel.
    Once you go 93 you won’t go back. My truck performs just like 099 describes above and any top tier 93 is good I use Chevron or Shell.
    Forestryguy[OP] likes this.
  14. Aug 1, 2024 at 10:03 PM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    87 all day , everyday since i bought it in 2020. id suggest buying a tesla
    :burnrubber:
  15. Aug 13, 2024 at 4:55 PM
    Clearstrm
    Clearstrm Well-Known Member
    2022 TRD Sport Manual Transmission
    My 2022 started to do this after my 25000 mile service last month. Makes me wonder what the hell they did to my truck! Or I am suddenly getting shitty gas everywhere
  16. Aug 13, 2024 at 6:17 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    I fill my tank with Leaded fuel and if i cannot find it, i add some diesel to my low octane.
    runs like a dream!
