Noise when in reverse coming from front right section.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CroTaco, Nov 30, 2016.
  1. Nov 30, 2016 at 7:36 PM
    CroTaco
    CroTaco [OP] Well-Known Member
    Tulsa OK
    2007 White Tacoma PreRunner TRD package
    3 inch lift.
    Whenever my truck is in reverse there is a strong vibration and rattling noise coming from my front right tire area. I read some stuff on identifix at work about a tsb on the brakes that can cause a noise in reverse but I'm just not sure. As soon as I put truck in drive the noise dissapears. I have a 2007 prerunner with A locking rear diff. Any help and or hints will be greatly appreciated!
  2. Nov 30, 2016 at 7:51 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Does it happen when rolling backwards only? Stuck brake pad or caliper? bad spring? Maybe pull the tire and check the brakes, see if anything looks out of place? Or Does it happen when your standing still and just put it in reverse while you still have your foot on the brakes?
  3. Nov 30, 2016 at 7:52 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Is it like a MMMMRRRRRRRRRRRRRRRRRRRRR type sound when you got your foot on the brake in reverse? Ive been having the same sound. Started like a month ago and ive just been living with it since so idk man.
  4. Nov 30, 2016 at 8:03 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Maybe try activating the ABS a couple of times. Go to a grass field or gravel parking lot. Do a high speed reverse and slam the brakes to make the wheels lock up so you slide. Then do the same going forward, slam the brakes and make the wheels lock up so slide and ABS kicks in. try it a few times, see if it helps.
  5. Nov 30, 2016 at 8:05 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    Doesnt make a difference if me and OP are talking the same sound here. my ABS went off like 8 times today.
    CroTaco[OP] likes this.
  6. Nov 30, 2016 at 8:32 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    That dont sound right? ABS is only supposed to be fully activated on hard braking when wheels lock up. Scan it with an OBD or goto autozone and ask them to scan it for ABS codes. If you can borrow a scanner, plug it in and take a drive with the ABS sensors in Live mode, see if all 4 ABS wheel sensors are registering similar RPM?
  7. Nov 30, 2016 at 8:35 PM
    MO Tacoma
    MO Tacoma Well-Known Member
    Castle Rock, CO
    2014 DCLB with a couple mods
    ADS extended travel, 14" 700 lb springs, Total Chaos UCA/LCA, Dakars. 37/12.50r17 Pitbull Radial Rocker. SCS 17" SR8. 4.56s with f&r ARB lockers. Relentless sliders, full skids, debadged. 35% tint on all windows. Katzkin leather w/ heated seats
    You just need to take the wheel off and see what's going on. I'd go as far as removing the caliper and pads to get a better understanding if you don't see anything .
    CroTaco[OP] and jboudreaux1965 like this.
  8. Dec 1, 2016 at 2:00 PM
    CroTaco
    Tulsa OK
    3 inch lift.
    I just had the front brakes and rotors done. It made the noise before and after. Sometimes there is no noise at all, but it'll happen as soon as I put it in reverse, I don't even have to be moving. I just can't future it out. No abs codes stored no lights on.
  9. Dec 1, 2016 at 5:07 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    Nah ABS if fine i was in a mud hole thats all.
  10. Dec 1, 2016 at 8:37 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It don't have anything to do with the brakes then.
    In reverse and not moving... That is a head scratcher...
    I would check the transmission and drive line as in Universal joints and carrier bearing.
  11. Dec 1, 2016 at 8:40 PM
    Paul123
    Paul123 Web-Wheeler
    Paul
    Reno
    2014 TRDOR pyrite mica, 3" lift 33's, 4.56’s
    Get under the truck with a rubber mallet and tap the exhaust lightly but hard enough to make it rattle. See if it makes the noise. I had this noise and it was a rock trapped in my catalytic converter heat shield. 5 minute fix if that's what it is. Usually only made the noise in reverse and rarely it would happen at idle in park.
  12. Mar 28, 2017 at 5:28 PM
    CroTaco
    Tulsa OK
    3 inch lift.
  13. Mar 28, 2017 at 5:31 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    Does it almost sounds like two body panels vibrating off eachother very rapidly? To this day i still cannot find what the hell it is man. I think we are outta luck.
  14. Mar 28, 2017 at 5:39 PM
    CroTaco
    Tulsa OK
    3 inch lift.
    Man it drives me crazy, everything works perfect, the noise is just killing me lol. Could be the body panels, hell at this point it could be anything.
  15. Mar 28, 2017 at 5:45 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    check your intake tube on the inner fender. where in goes into the fender
  16. Mar 28, 2017 at 5:45 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    What we need to do is go to a big parking lot and just have someone drive our trucks in reverse while we listen and can rule shit out. To me it sounds like front right fender ish, but honestly who knows maybe its under the hood. Just cant tell from the drivers seat, even after i hit a pole with my truck (thought it wasnt in the front right) ITS STILL THERE so idk man.
  17. Mar 28, 2017 at 5:46 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    Mothafucker i forgot about that thing, brb going to garage.
  18. Mar 28, 2017 at 5:52 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    Can confirm it is not the intake tube :(
  19. Mar 28, 2017 at 5:57 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    did you try taking to tube off and trying it
  20. Mar 28, 2017 at 6:22 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    I smacked on it a few times, but then realized its like a rubbery plastic. This is like a metal on metal type thing.
