Noisy Leaf Springs
Discussion in 'Suspension' started by LoHoNas, Jan 3, 2010.
  1. Jan 3, 2010 at 5:34 PM
    LoHoNas
    LoHoNas [OP] Well-Known Member
    Jeff
    Lake Jackson TX.
    09 4x4 DC TRDSPORT MGM
    Debadged, Fog light mod,Grillcraft, Icons,TC UCA's, OME dakar leaf pack,Procomp 7089,BFG KM2 285/70/17 JVC NAV
    I have a set of OME Dakar leaf packs that preform well, ride good, handle loads better than advertised, and provide the lift I require. Now if I can just get them to SHUT UP!!! I am getting lots of creaking only when they are dry. I can silence them with a little ACF-50 spray but that only last about 3 days. I plan on lifting the rear of the truck cleaning up the leaf packs and applying grease bettween the leafs. Hope this is a more long term cure. Any body got a better suggestion?
  2. Jan 3, 2010 at 5:40 PM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    nope thats pretty much all you can do with it.
  3. Jan 3, 2010 at 5:45 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    ive heard of this before and you r on the right track for sure.good luck to ya.
  4. Jan 3, 2010 at 5:48 PM
    LoHoNas
    Jeff
    Lake Jackson TX.
    Yeah.... that sounds like the standard procedure. They are by far the loudest leafs I have heard, from inside or outside the truck:frusty:
  5. Jan 3, 2010 at 5:54 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    my truck was horrible also but i just have stock with the TSB. I just jacked the back end up and took the biggest screw driver/pry bar u can get your hands on and separate the ends of the leafs where the friction pads are. And apply grease. Works great. Now i am squeak free!!!
  6. Jan 3, 2010 at 5:57 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    x2:) Works like a charm.
  7. Jan 3, 2010 at 5:57 PM
    LoHoNas
    Jeff
    Lake Jackson TX.
    Thanks man....I greasing them up tomorrow. Hope it works:pray:
  8. Jan 3, 2010 at 6:48 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Ahhh ! , I just made my mind up to go with the Dakars . LoHoNas , I've got the exact same rig as yours but in a longbed , do you know offhand what your truck measures from the centre of the wheel to the underside of the fenderwell with the dakars? I'm considering removing one leaf from the pack to keep my rear down a hair .
    Thanks in advance ,
    OZ
