Noisy suspension-problem?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dblcabber, Aug 15, 2017.
  1. Aug 15, 2017 at 6:52 AM
    Dblcabber
    Dblcabber [OP] Active Member
    DCLB
    Sweet air freshener, installed march 2008
    Last week i noticed a subtle popping/clanging/rattling. It almost sounded like the spare tire rattling around, but i checked that and it was tight. Just hit 30K miles, and this truck is a grocery getter/family hauler, no offroad stuff. Its almost all the time, but still a bit random, as in, I can't necessarily make it happen on demand, but if you drive it for 30 seconds, you'll hear it plenty.
    It could quite literally be anything, but at a cursory look-over, this is the only inconsistency, or potentially glaring issue. See video below-none of the other 4 corners make this racket, just the front right.
    https://www.youtube.com/watch?v=a0pjjIMDsnQ
    Either way, I dropped it at the dealer today to have the recalls taken care of and told them about the noise, without any other leading info.
    Any thoughts?
  2. Aug 15, 2017 at 6:59 AM
    Clearwater Bill
    Billy
    Largo Florida
    Lots of threads around here about loose stuff that need to be properly re-torqued.
    Could well be some of that.
    shakerhood likes this.
  3. Aug 15, 2017 at 7:15 AM
    CanyonRunner
    CanyonRunner 100% PENETRATION
    Pacific Northwest
    2016 TRD 4X4 DCSB
    $$$ Money Pit $$$
    GPsevinSixx, nDub and Dblcabber[OP] like this.
  4. Aug 15, 2017 at 9:25 AM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Mine does the exact same thing on the same side ( the creaking mostly), sometimes. It comes and goes. It is difficult to chase. I haven't touched the cab bolts/ mounts or the radiator support yet. Mine is exactly one year old since it came off the lot and I've heard it less than 20 times, but usually on colder mornings going up and down driveways. I do off-road mine once to twice a month and after a good flexing of the body, it goes away. I'm also on aftermarket front coils/ shocks in front since ~1500 miles, but the exact same noise was there not long after I got it. Likely not the suspension, but in the frame/ body somewhere as many have mentioned. Sorry, just some info and not a resolution for you.
  5. Aug 15, 2017 at 9:36 AM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    I think we have a winner.
    If you replace the mount go with aftermarket poly bushings. They'll last longer.
  6. Aug 15, 2017 at 9:48 AM
    Hunter#23
    Hunter#23 Well-Known Member
    2016 White TRD Sport LB
    All - I had my mounts replaced and now the sound is back again (w/in 1,500 miles). Trucks only seen pavement. Sad..
  7. Sep 14, 2017 at 3:24 PM
    ajmogen
    ajmogen Well-Known Member
    Aaron
    Wisconsin
    OR MT TACO T4R YARIS MT Corolla Hatchback MT
    Who did you have replace the mounts? What mounts did they use (OEM or Poly)?
