Noisy windshield wiper motor...replacement ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Paulrv6, Apr 26, 2022.
  1. Apr 26, 2022 at 10:53 AM
    Paulrv6
    Paulrv6 [OP] Well-Known Member
    paul
    2005 Tacoma
    I have a 2005 and the motor was replaced on warranty shortly after I bought it new. It sounds like I need to replace it again. Is this a common problem? Is it the motor or could it be something else? What is the procedure for replacing it and is it difficult? What is a better replacement motor than a toyota one? Thanks
    paul
  2. Oct 15, 2023 at 4:45 AM
    Kirt Adams
    Kirt Adams New Member
    Kirt
    Vermont
    01 Tacoma 4cyl
    '77 GMC rear bumper
    Hi Paul,
    I saw your post now in Oct. 2023, but didn’t see any follow up replies. I’m new here, so maybe it’s just me.
    I have a 2001 Tacoma that I’ve had for 170k miles that has noisy, and I think slow wipers. I switched the motor with one from a parts truck with no change in noise. I’m thinking it might be the linkages in the mechanism that drives the wipers. The truck sat for a while, and the wipers only became an issue when I started driving it again.
  3. Oct 15, 2023 at 8:08 AM
    Paulrv6
    paul
    2005 Tacoma
    Thanks for your reply. Maybe it is the linkages but after the first replacement motor it was quiet for a while and now it's louder again. Nothing I can't live with though. Thanks
  4. Oct 16, 2023 at 11:18 AM
    Jerry Bear
    Jerry Bear Well-Known Member
    Jerry
    Mesquite, Texas
    2010 Access Cab
    tint, topper, receiver hitch, trailer wiring, topper lighting, cruise control, intermittent wipers, backup camera, auto-dim mirror
    Here's a dump of my wiper motor notes for my 2nd Gen 2010 Access Cab, 4 cyl, not TRD or Prerunner.
    My problem is that my wipers started making a gear grinding noise after I turned on the wipers while they were frozen to the windshield back in February and they didn't break loose. I never fixed them and they've worked fine since then. They just make a gear grinding noise.
    851100K060, 85110-0K060 is original motor for US and Mexico
    8511004040, 85110-04040 is cold area spec motor
    both fit my TRN225 truck according to parts.toyota.com
    However, the linkages are different part numbers for US/Mexico vs. cold area. Perhaps that means the linkage has to match the motor.
    The motor shaft is metal. The linkage socket mated to a -0K060 is metal.
    There were a few sellers on eBay selling the used cold area motor and linkage as a kit.
    85110-04040 has five pin plug, 3 over 2 contacts, mounts with two flanges, attaches to linkage with a spline/threaded connection.
    Someone on TacomaWorld says all 2010 had cold weather spec parts:
    https://www.tacomaworld.com/threads/windshield-wiper-motor-noise.471734/#post-22845080
    See T-SB-0061-12 for instructions to remove the cowl panel and access the wiper motor and linkage.
    This may be the grease for the wiper linkage:
    DENSO 028770-0010 - #50 GREASE
    Instructions to remove the cowling and replace the wiper motor and linkage:
    https://www.tacomaworld.com/threads/bocsy44s-taco-addiction-build.500411/page-37#post-17387831
    https://www.tacomaworld.com/threads/broken-wiper-motor-arm-fix-with-pics.126985/
    Hope this helps.
  5. Oct 16, 2023 at 1:19 PM
    Kirt Adams
    Kirt
    Vermont
    01 Tacoma 4cyl
    '77 GMC rear bumper
    Thanks for the informative replies. I almost decided I could live with the noise, but the idea of lubricating the linkages is tempting just to prove/disprove where the noise is coming from.
  6. Oct 16, 2023 at 4:35 PM
    Paulrv6
    paul
    2005 Tacoma
    I was thinking the same thing about greasing the linkages to see where the noise is coming from. Thanks so much for the instructions.
