Non airbag buckets into a 2010 Reg cab
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yoytoda, Jun 16, 2011.
  1. Aug 18, 2011 at 2:00 AM
    Yoytoda
    Yoytoda [OP] The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    Metric grade 5 I think. I forget the size. I just took one of the others to the hardware store to compare
  2. Sep 5, 2011 at 1:29 PM
    regular taco
    regular taco New Member
    texas
    96 4x2 reg cab (sweet)
    bone stock
    has anybody tried this swap on a 96 regular cab, im ready to chuck my bench ..
  3. Sep 5, 2011 at 1:31 PM
    Yoytoda
    Roland
    completely stock
    it wouls be so easy in a 96... just pull the seat out and find buckets to put in. you may need to shop for some brackets or make some...
  4. Oct 12, 2011 at 8:54 AM
    Yoytoda
    Roland
    completely stock
    Sure. It was a dollar for a pack of 10ohm resisters at radio shack. They didn't have any 3.3 ohm resisters. In fact, where are you going to find a single 3.3 ohm resistor.
  5. Oct 12, 2011 at 9:08 AM
    Yoytoda
    Roland
    completely stock
    Make sure they aren't 3.3kohms Because my radio shack had those.
  6. Oct 12, 2011 at 1:02 PM
    Yoytoda
    Roland
    completely stock
    3.3ohms
    vs
    3.3k or 3,300 ohms
    big difference lol
  7. Dec 13, 2011 at 10:05 PM
    PRERUNN
    PRERUNN Member
    Have you had any issues at all? I found a few off some 2005 to 2007's seats and really want to do this but really want the air bag sensor to work. If i took all the airbag stuff off my 2010 bench and put in on the 2007 seats do you think it will work or is there a issues i don't know of.
  8. Dec 24, 2011 at 10:31 PM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    My write-up should answer all your questions, Especially check out part2 which goes into detail about swapping in the correct hardware with no bypassing at all!!
    See signature below;
  9. Dec 24, 2011 at 10:47 PM
    PRE10
    PRE10 Well-Known Member
    SoCaL
    2010 PreRunner 4Banger
    Thanks I will go back and re-read.
  10. Jan 22, 2017 at 4:49 PM
    1handyguy
    1handyguy New Member
    08 std cab tacoma
    bucket seats
    I just read thru these posts, but never found the write up you referred to. It sounds like it is useful info. My 08 doesn't have functional airbags since I put buckets into it. I'd greatly appreciate a little guidance.
    Thanks,
