Non Ethanol Gas
Discussion in '3rd Gen. Tacomas (2016-2023)' started by growyourmind86, Mar 10, 2017.
  1. Mar 12, 2017 at 7:43 AM
    CaptainAwesome
    CaptainAwesome Well-Known Member
    Calgary, Alberta
    I'm getting DECENT MPGs off 87 Octane.
  2. Mar 12, 2017 at 3:14 PM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    You might be able to afford to use Trufuel in your weed wacker. Probably too expensive to use in a generator.
    http://trufuel50.com/
    shakerhood[QUOTED] likes this.
  3. Mar 28, 2017 at 4:05 PM
    DakoTaco
    DakoTaco Well-Known Member
    North Coast
    2016 MGM OR Tacoma
    Avid front bumper guard OVtune HPS Intake Tube Meso designs counting
    I get a definite bump in mileage, my other vehicle a few years older it's a solid 2mpg.
  4. Mar 29, 2017 at 9:39 AM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road
    More than the mileage, the best thing non-ethanol gas did for me was get rid of my fuel pump chirping.
    bshammer0 likes this.
  5. Mar 29, 2017 at 9:47 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Agreed. I've been running 87 E0 for the first time this week on my daily driver, and it does seem to feel smoother throughout and the chirping seems to be diminishing a bit. I've seen a solid 2mpg increase on my first tank (and I have a 30/70 blend of 87E10/87E0 in there now). Will continue to use the E0 station close to me for now, but may look into the additive since it's off brand fuel and likely doesn't have the detergents and such that are good for the engines.
  6. Mar 29, 2017 at 10:02 AM
    mako fisher
    mako fisher Well-Known Member
    Michael
    Cape Fear
    2008 Impulse Red 2.7L MT RC 4X4
    Int. wipers, fog lights, cruise control
    The exon I stopped at on the way to work this am offered 0-E87 but it was 90 cents higher ... yikes!
    Inferno500 likes this.
  7. Mar 29, 2017 at 10:31 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    modern vehicle are designed with components to handle ethanol. If you run your vehicle regularly, ethanol will not cause any problems. At 30¢ per gallon it will take a +2 mpg improvement to break even.
    scottalot likes this.
  8. Mar 29, 2017 at 10:31 AM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    I've run E0 91 a few times (only E0 available near me) and I get ~2mpg better across the board. I haven't continued using it however because it's significantly more expensive. Almost $1 more per gallon here.
  9. Mar 29, 2017 at 10:36 AM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    in a truck you drive daily don't worry about ethanol free fuel, now lawn mowers and such that don't get a tank ran out very often then use it. Ethanol when left alone for long periods can make rubber hoses harder and brittle.
  10. Mar 29, 2017 at 10:42 AM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    It also separates into gas and water.
  11. Mar 31, 2017 at 10:46 AM
    imdav2u
    imdav2u Well-Known Member
    St. Louis
    2016 TRD Offroad DCSB 4X4
    I filled up my almost empty tank in Columbia Mo, drove back to St. Louis keeping it at 70 mph and got almost 3 mpg's more than the trip out.Paid about 22 cents more for it. By the way, 70 mph on interstate 70 is crazy, everybody passed me doing at least 80.
  12. Mar 31, 2017 at 10:49 AM
    growyourmind86
    growyourmind86 [OP] Well-Known Member
    2017 trd Tacoma
    Takes a few tanks for the computer to adjust. You dont just throw some in and then see instant results. Myth not busted.
  13. Mar 31, 2017 at 10:54 AM
    growyourmind86
    2017 trd Tacoma
    it took two full tanks for my computer milage to go up. Also you should do it the old fashion way as well. The computer might not be as accurate.
  14. Mar 31, 2017 at 11:03 AM
    growyourmind86
    2017 trd Tacoma
    It all depends, the trucks computer learn how you drive and all that fun stuff, with out the ethanol you will get a cleaner burn, so more power more mpgs, thats my theory. I have no science to back it up I just have noticed how my own truck seems to have gone up since I started using it. For me the the 30 cents isnt not that much more as its the same price for regular in other towns. at .30 cents more around 18 gallons a fill up its 5 bucks more and gives me a piece of mind my engine is running better. No one has to buy if they do not want to. If you see no difference then thats you.
  15. Mar 31, 2017 at 11:07 AM
    #35
    Bob259
    Bob259 Well-Known Member
    Arizona
    2016 Tacoma Limited DCSB 4x4 3.5 V6
    Same here
  16. Mar 31, 2017 at 3:07 PM
    #36
    Overland_Odyssey
    Overland_Odyssey I talk about 4x4s.
    Rich
    2017 Silver DCSB TRD Off Road
    The only time I run ethanol free is for my carbureted motorcycles. It keeps them from gumming up so quickly. No reason to run ethanol free in an FI vehicle. You will get slightly better MPG, but the cost difference usually doesn't pay out.
  17. Mar 31, 2017 at 3:10 PM
    #37
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    U.S.A.
    2023 RAV4 XLE Premium
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    fullsizeoutput_3b4.jpg .
    Corn gas @ 87 octane goes for $1.99 to $2.30 a gallon.
    Non-corn-gas is at least $1.00 a gallon higher and I have seen it as high as $3.89 a gallon.
    growyourmind86[OP] and Storman like this.
  18. Mar 31, 2017 at 8:20 PM
    #38
    growyourmind86
    2017 trd Tacoma
    great meme, but i am paying .30 cents more. Regular gas with ethanol is 3.19 in the town I live in. I go to an other place and its 2.79 for ethanol free.
    SOSHeloPilot[QUOTED] likes this.
  19. Mar 31, 2017 at 9:53 PM
    #39
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    Not really true. Long term fuel trims take some time, but short term fuel trims are instant. STFT monitors the O2 sensor and adjusts real time in order to keep a 14.7:1 AFR (lambda of 1). When STFT is consistently high or low for a period of time, LTFT is incremented to lower the STFT correction. Not certain, but at higher throttle when the computer goes open loop...I think the LTFT tables are used....so in that case it may take a bit to adjust for a different fuel. I don't belive it's a tank of fuel though, but not sure on the Tacoma ECU specifically.
    Ignition advance tables take a bit to update sometimes if the fuel you have been using was causing knock correction. Again, it depends on the ECU with regards to how aggressively it will add advance after a knock correction.
  20. Jan 9, 2022 at 8:10 AM
    #40
    PNWtaco541
    PNWtaco541 @LFG_Tacoma
    Portland, OR
    2020 TRD MT
    Mod: Front Coilovers Spec: 2.5” RR DSC Brand: Fox Mod: Rear Shocks Spec: 2.0” x 12.1” RR CD Adjuster Brand: Fox Performance Series Mod: Rear Shock Relocation Tower Spec: 12-14” travel 2.0” shocks Brand: Archive Garage Mod: Rear Leaf Pack Spec: RXT (Option 1) Brand: Icon Vehicle Dynamics Mod: Ubolt Flip w/ Bump Stop Spec: Active Off-Road Brand: Timbren Industries Mod: Rear Extended Brake Lines Spec: +4” 5 Layer lines Brand: Crown Performance Mod: Rear Leaf Hang and Shackle Spec: 3.6” shackle hammer hanger custom cross tube support bar Brand: Archive Garage Mod: Rear Bumper Spec: HC Tube Bumper "Tilted" Brand: OUTGEAR SOLUTIONS Mod: Aftermarket Wheels Spec: 17x9.0 -25 (4 Inch Backspace) PCD: 6x139.7 Center Bore: 106.1 Limited edition Machined Silver Brand: Summit Off Toad Wheels Mod: Tires Spec: KM3 285/70r17 Brand: BFGoodrich Mod: Seat Covers Spec: Black Perforated Leather and Vinyl Brand: Classio Mod: Cab Mount Chop Spec: DIY Plates Brand: Total Chaos Mod: Upper Control Arms Spec: STRD High Caster Brand: JBA Offroad Mod: Rock Sliders Spec: 80" Brand: DYI Mod: IFS Limit Straps Spec: 15" Brand: TMR Customs / KarTek A few more cosmetic sh*t, will add later…
    FWIW, Costco premium gas is ethanol free.
