Noob needs help with lift
Discussion in 'Suspension' started by CDNplt, Jun 8, 2013.
  1. Jun 8, 2013 at 6:42 AM
    CDNplt
    CDNplt [OP] Active Member
    S.FL.
    11 Prerunner 2WD DCSB
    Hey guys/gals,
    I need TW's help. I have read the stickies, read numerous threads and I'm still confused.
    I have a 2011 DC Prerunner 2WD. Obviously, my lift is for looks rather than performance. Since I won't be doing any off-roading, I don't want to break the bank on a hardcore lift, but don't mind spending $$ for the right set-up.
    I just want a higher stance for the Taco.
    Most of you will probably recommend 5100s with 885 and AAL, but do I really need this?
    Searching the various threads, I stumbled onto this cornfed suspension blocks. http://www.cornfedsuspension.com/0511Tacoma.htm Looking at the 3" front and 2" rear with the diff drop. I have read mixed reviews about them.
    Is this something that could work for my truck and needs? What should I expect the drive to be like? Will i need to do an alignment often?
    I plan on getting the FJ Baja black wheels and wrap them with BFG Mud.
    Thanks in advance and go easy with the noob :D
  2. Jun 8, 2013 at 1:18 PM
    CDNplt
    S.FL.
    Haha. I'll assume by the lack of response that the blocks are probably not a good idea and not worth answering.
    So, what should I get based on my needs described above?
    I'm new to lifting, I just need a decent setup that won't give me any problems.
    Thanks
  3. Jun 8, 2013 at 1:27 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I'm not into spacers lifts/blocks and never owned one so I can not comment on them.
    What I can say is you have no front diff (only on 4x4's) so a diff spacer will not be needed.
  4. Jun 8, 2013 at 1:29 PM
    ABregenzer
    ABregenzer Fish
    Alex
    The Dirty Lew, TX
    2004 4X4
    Stickers. Lots of stickers.
    I have had a front spacer before.
    If you like it rough, do the spacers.
    If you like a smoother ride, go with shocks/springs.
  5. Jun 8, 2013 at 1:51 PM
    CDNplt
    S.FL.
    Haha that makes sense. Thanks
    Ps: go Habs go
  6. Jun 8, 2013 at 1:54 PM
    CDNplt
    S.FL.
    Perfect. That's what I needed to know. Don't need a rough ride. So billies 5100s. Should I do 884 or 885?
    I see some kits on Toytec, probably the way to go right. Will I need UCA and LCA if I do 2"? From what I have read, I probably don't.
    Thanks
  7. Jun 8, 2013 at 1:56 PM
    XXXX
    sKiP
    05 Prius
    x2........For 2" of lift I would think you should be A-OK with OE UCA's based on seeing what many others have been able to achieve with similar specs.
  8. Jun 8, 2013 at 1:59 PM
    ABregenzer
    ABregenzer Fish
    Alex
    The Dirty Lew, TX
    2004 4X4
    This.
    I just got Light Racing UCA's because at 3" and full droop I was hitting my springs. And my alignment was whack.
    At 2in, you shouldn't need new UCA's.
  9. Jun 8, 2013 at 5:54 PM
    Toyotachris
    Toyotachris New Member
